Highway merging & uphills
Discussion in 'Prius c Main Forum' started by jcal0820, Mar 27, 2013.
  1. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    One problem w/the fairly long grades like encountered on the Grapevine is that after not too long, the HV battery is depleted as low of the car will let it go. You're then dependent on the output of the ICE only, 73 hp in the case of the Prius c, until it regains some charge. It'll recharge a bit on the way up and the less steep and level portions, but quickly get depleted again. (It's 76 hp for me on my Gen 2 Prius and I have some more battery capacity than the c.) Essentially, there will be a fair amount of uphill stretches where you have no electric assist (noticeably less acceleration and ICE roaring).
    It's 98 hp for ICE only (134 hp net system power) on the Prius liftback and it has a larger battery capacity (won't help much still, since it'll get depleted pretty early in the climb) but it's also a heavier and larger car. The '12+ HyCam has a 156 hp ICE (200 hp net system power) but it's also heavier than the Prius. Same deal applies to its HV battery getting drained pretty quick.
    IIRC, on the way down, I think you'll wish you'll you had larger battery capacity.
  2. RocMills
    RocMills Active Member
    789
    277
    Las Vegas, Nevada
    I wonder if your dealer would allow you test drive on a good hill... in my case, the dealer let us take the car home and we drove it around (or it sat in the driveway) for most of a day.
    And as others have said, I think it's the length of the grapevine that would be your issue, not necessarily the incline itself. I've not driven the grapevine in a C yet, but have done so countless times in other cars. You'd probably find yourself residing in the "slow" lane the entire trip.
    ChinchillaGirl likes this.
  3. jcal0820
    jcal0820 the 'Stan
    35
    SoCal
    One of the dealerships I'm looking at is in Valencia, on the south end of the grapevine... Going to ask for an extended test drive, 15 minutes up & 15 back down. And not just performance, I can gauge what the fuel usage will be like...
  4. FastZX6R
    FastZX6R Junior Member
    Yep test drive
  5. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    Or rental or demo/service loaner, if they won't let you.
    If I were a salesman, I might be hesitant to let someone take an extended test drive when someone will be revving the hell out of a new engine that hasn't been broken in yet. I guarantee that you will be hitting the max RPM the computer will let the car go to and be staying there. (I've looked at engine RPMs via ScanGauge II while climbing steep grades.)
  6. B2FiNiTY
    B2FiNiTY Active Member
    979
    227
    You gotta do whatever it takes to make the sale. It's a competitive world out there. Plus, whatever happens to the car later, will be up to the new owner and Toyota. Most cars are redlined off the boat, out of the factory etc. how else does each car have some mileage on it?
  7. PFlat
    PFlat Junior Member
    36
    26
    As others (emily and fourenty) have stated: its fine. I have a 50 mile commute each way and its all 2-lane highway, very hilly. I'm averaging 45+ mpg.
    On "the big hill" I let it lose speed to save mpg unless someone is directly behind me. It goes from 72 or so down to under 50 haha bc I don't wanna hear the ICE whine. But it will certainly keep speed up if I make it.
    Also I feel the transmission does well on climbing bc it doesn't hafta shift.
    I'm sure a genIII is probably better with the more HP, buuut I got mine for under $19k, which I'm sure few genIII drivers can say
  8. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    A brief run up to redline isn't too hard on a new engine. A sustained high power high speed run is.
  9. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    A sustained run at any RPMs is bad for a break-in cycle.
  10. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    And a sustained hard run is much worse.
    Varying load is more important than varying rpm during normal break-in driving.
  11. jcal0820
    jcal0820 the 'Stan
    35
    SoCal
    After visiting some dealers, I'm now finding a lot of clearance type deals on Camry's now, non hybrid models, and I can get one for a few hundred dollars more, or even less than a Prius C I depending on my negotiating skills. And even the entry level Camry comes better equipped. Going back to the drawing board to do the math and reassess my priorities...
  12. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Don't forget to add in cost of ownership. The gas differences may not be the only thing to factor. What about maintenance...
  13. B2FiNiTY
    979
    227
    To me, a camry and a prius c really offer different features. If your also shopping for a camry, then that opens up an even larger variety of cars to consider.
    They aren't even in the same class.
  14. KaliforniaKid
    KaliforniaKid 2013 Prius v Five 2012 Priuc c Four
    184
    63
    Nuthern Kalifornia
    2015 Prius c
    I did the Disneyland thing from the San Francisco Bay Area twice last year with four people in the car, averaging 60MPH southbound on the Grapvine. The C can handle hills.
    Loved it most when up and over the Grapvine onto I-5 traffic becomes to a bumper to bumper crawl. That's when EV mode kicks in and the 43MPG freeway starts looking more like 55MPG again.
    (y)
  15. C4me
    C4me Junior Member
    I had a bmw 3 series before the priusc so i may be a tough judge but......on a recent trip on the freeway (I usually only drive in town) i felt that it definately blows around at higher speeds if its windy, which one might want to concider if it also raining. At one point going 60 in the slow lane on a highway incline near Sausolito I felt the car lagging a bit (mind you my bmw would glide effortlessly in this same sort of conditions) as i attempted to press the accelerator further toward the floor it did not budge! It was floored and going no faster than 60 lol that bit. Good thing I got it for "C" as in City driving.
  16. Laurenparkranger
    Laurenparkranger New Member
    27
    Santa Cruz
    2015 Prius c
    Two Eco
  17. bisco
    52,851
    u did not test drive?(n)
  18. mohsin
    mohsin Member
    91
    61
    Dubai, UAE.
    2014 Aqua
    Very true, especially in hilly areas.
    Otherwise the car is capable of handling quite steep climbs.
  19. yogipaolo
    yogipaolo Junior Member
    69
    washington, dc
    Your merge strategy might have to change. I often look for gaps behind cars rather than trying to compete with so many folks in my area that do ten mph or more over the speed limit in the slow lane and don't bother to slow down or move over when they pass an exit.
    On my motorcycle, I lay on the throttle. In the Prius, I use my mirrors to gauge the speed of traffic and adjust my speed accordingly. Most of the time, I get behind faster cars.
    You'll find that you will spend a lot of time in the rightmost lanes in the Prius, but I smile at my 50+ MPG.
  20. tzx4
    tzx4 Active Member
    164
    148
    My '13 C had no trouble at all ascending the steepest longest uphill grades driving west out of Denver on I 70 at 65 on cruise. To my amazement it spent most of the time on those upgrades with enough power to spare that it was even charging the battery.
    I did deplete the battery once, and that was on a trip to Las Vegas. I had the cruise set at 85, and coincidentally just short of the peak of a miles long sustained upgrade, the power suddenly dropped, as did the speed down to about 70. The battery icon was bottomed out. A half a mile later it was downgrade and the battery was recharged in the matter of a minute or two.
