Highway MPGs <40?
Discussion in 'Gen 2 Prius Fuel Economy' started by davito629, Mar 26, 2013.
  1. davito629
    davito629 Junior Member
    Purchased my first Prius a couple of months ago now (new to me '07) after having seen how great my parents Prius did on mileage, and because I recently got a job that includes a 90 mile roundtrip commute each day.
    Despite my commute being >90% highway, I can't get the Prius to return greater than 40 MPGs. My speeds average between 70-80, as there is no traffic and the speed limit is 70, which I understand will cause a hit to fuel economy, but so much so that I can't even top 40?? Temperatures have been warming up (regularly in the 50s here in the Pac NW), but I didn't think that would have much of an effect since my driving is almost all highway. Am I missing something? Could there be something wrong with the HV battery even though no codes are being thrown? In the near future I plan on buying an SG2 to better track things. In the meantime, I've filled out the questionaire below, looking forward to others experiences and tips. I've also taken several trips that involved lower speed driving (driving to the coast on 2 lane... hilly roads) and still couldn't exceed 41-42 MPG at best.. calculated on an Excel sheet based on miles driven/gallons filled.
    - What fuel economy are you getting and how are you determining fuel economy? (trip computer or manual calculations)
    36-40, comparing the Prius computer (about 2.5 mpg high) with manual fill up calculations tracked in Excel
    - What fuel economy are you expecting and why?
    43-45 highway, based on what I've heard and the fact that I was able to get mid 40s out of my families '07 Prius when they owned it (combination of around town and hwy driving)
    - What are the approximate outside air temps?
    mid 40s-low 60s
    - How long are your trips?
    45min-1hr all highway (about 45-50 miles each way)
    - How much of it is city vs. highway? Roughly what's the average speed in overall and and of each segment? Is there a lot of stop and go driving?
    Almost all highway. First/last mile is city stop and go, the middle is wide-open highway (little/no traffic) avg 70-80 MPG
    - What region/state are you in? (if you haven't set your location in your profile)
    Portland, OR/Pac NW
    - What's the terrain like of your drives? (e.g. flat, gentle hills, steep hills, etc.)
    gentle hills, mostly flat (I-5 along the Columbia River)
    - Is your oil overfilled? (i.e. above the full mark on the dipstick)
    nope, though I will change it myself next time
    How old is your 12v battery? What is the voltage reading of your 12v battery after sitting over night? (Method Here)
    Previous owner said he replaced it about 2 years ago...
    ACC mode - 12.4 V
    2nd mode - 12.1 V
    Ready mode - 14.1 V
    Have you had your alignment checked? Any pulling or abnormal tire wear?
    no abnormal tire wear, new tires I am assuming it had an alignment when the tires were replaced about 6 k but I'm not positive
    - Are you using the factory tires and wheels? If not, please indicate tire make, model
    and size (e.g. Goodyear Assurance Fuel Max 185/65R15).
    Bridgestone G019 Potenza's
    - What are your tire pressures?
    40 front/ 38 rear
    - Make, model, year, engine and transmission of previous car? (e.g. 08 Honda Civic Si 2.0L 4 cylinder, manual transmission) What did you actually get on the same trips/commute? (Please give us actual numbers, not EPA ratings.)
    '05 Outback XT (Turbo) about 21-22 MPG similar commute with premium fuel.
    - How are you trying to drive (e.g. trying to stay in electric only?) and how hard are you braking?
    Light braking, especially coasting/easy brakes coming off of the highway. Try to pulse and glide when possible.
    - Are you "warming up" the ICE (internal combustion engine) by letting it idle after powering on?
    No
    - Are you driving using D or B mode?
    D
    - HVAC settings? Are you using the heater, AC, auto mode, etc.? If using auto, what temp is it set to?
    Auto, but A/C unchecked, temps no higher than 70. I will turn it off when I get into the city on cooler nights to get the ICE to shut off at stop lights (sometimes it won't)
    - If reporting a mileage drop, did anything significant change on your car (e.g. accident, hit a curb or big pothole throwing off alignment, oil change/other maintenance/repairs, changed tires or wheels, etc.) or your commute?
    Nada.
    Thanks in advance for your advice/experiences!
  2. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    You need to do the 12v battery test so there are enough facts to make an informed evaluation. Report all three numbers here.
  3. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Two reasons stand out immediately.
    1. All high speed driving. Prius gets best fuel economy at low speeds.
    2. Non LRR tires. In a consumer reports test a few years back "G019 Potenza" scored in their very lowest (worst) category for rolling resistance. This makes it a bad choice if you're interested in good fuel economy, expect at least a 4+ MPG hit due to the tires alone.
    SteveLee likes this.
  4. davito629
    Ok did the battery test which I added to the original post... (cold after the car had sat since last night) and got the following:
    ACC: 12.4 V
    2nd mode: 12.1 V
    Ready mode: 14.1 V
    All seems normal to me?
    An additional side note... I've read the posts about the non-linear tracking of the battery bars, and was wondering if people have experienced the following. On some occasions, usually after the previous trip ended in a lot of electric mode driving, I will start the car the following day and within the first 1/2 mile of driving the battery bars will drop 2, sometimes 3 bars in that short period of time. Sometimes it has gone from 6 bars to 3. It always comes back up within the next mile or two of driving after this. All other times (especially my 95% highway commute) it stays consistent at 7 green bars. During mountainous driving I've noticed it drop (as I would normally expect) to 4 or 3 bars over the entire climb... 2000+ vertical feet. The drop is generally consistent and does not appear abnormal... but I'm no expert.
  5. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Yep good, 12V is ok. :)
    A few of us notice behavior similar to this. It might be normal or or might be a sign of a slight loss of capacity on the traction battery. In any case, the best thing to do is to let the car sit in "P" with the engine running for about 40 to 50 seconds before you drive off. It takes the strain off the HV battery and helps preserve the SOC immediately after cold start. It wont have any determent on your overall MPG so try it. Trust me, IT WORKS!
  6. SteveLee
    645
    180
    North Carolina
    I
    Yes, that looks good. I agree with uart. The high speed and the non LRR tires could result in this kind of MPG. Going with good LRR tires and slowing to 60mph while increasing deceleration distances could make a 5-10 mpg difference. I think I would try to allow the HV battery to build up the last few miles before home. Increasing slowing distance is good here too.
  7. fuzzy1
    10,611
    Outside temperature still makes a difference on the highway. Grill blocking may help, but I suggest waiting until you have the engine monitor (stand-alone SG2, Torque for smart phones, or any of several other competing products) so you can monitor engine temperature and avoid overheating.
    What size? If the size doesn't match the original tire size (listed on the door frame sticker), these could be causing more mpg loss, in addition to the non-LRR characteristics mentioned by others.
    This, and the posted speed limit you mention, suggest to me that your commute is mostly on the WA side of the river. I'm not aware of any particular problems there, but also don't travel above 70 there. My normal is closer to 65, but visits are not during regular commute times.
    New tires always hurt compared to broken-in tires, but at 6k miles you ought to be past this factor.
    This is most effective at low and moderate speeds. Cruising at 60+ mph on flat roads, the Prius engine is already operating in a very efficient portion of its BSFC map, so P&G can add relatively little. This is different than traditional nonhybrids, where ordinary highway cruise is well off the most efficient engine operating point.
    Climate control always costs fuel, though I cannot say how much in your particular case. If you can be comfortable with Auto turned off, lower heat temperature and low fan setting, then try it. For other reasons I must always have some fresh air blowing, but my default is 2 fan speed bars and no heat, or 65-68F when necessary.
  8. fuzzy1
    10,611
    Note that even a Gen3 won't usually top 40 mpg at 80 mph. Your Gen2 will come in several mpg lower than this:
    Updated MPG vs MPH chart
  9. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    No doubt the speed is one of your problem areas. The Prius will NOT give good mileage at those rates of speed. Try limiting the speed closer to 62.
    I also agree that the tires on your Prius are further causing a drop in the mileage.
    FWIW, if I drive our Prius at 75 to 80, I always see 40's. But if I drive the Prius at 62 the mileage is considerably higher, more like 48 to 52 and sometimes even higher. If I limit myself to 55, the mileage even goes higher.
    There are a lot of factors involved, but the two things that stand out the most is your speed and the tires on your Prius.
  10. ewxlt66
    ewxlt66 Active Member
    535
    186
    Dana Point, CA
    No way you'll get over 40 between 70-80mph.
    My best MPGS have been on trips that averaged 40-60 due to traffic.
  11. fuzzy1
    10,611
    Here is the Gen3 LRR tire thread: Low Rolling Resistance replacement tires: Current List
    PS. And the Gen2 thread: Low Rolling Resistance replacement tires: Current List
  12. THF
    THF Junior Member
    71
    MO Ozarks
    I drive mostly highway and only average 45. (MFD always shows 47-49 though.) I'm happy with that, as I drive on rally CRUMMY roads that twist and turn and go up and down. I manage to get the same on flat major roads, though, since they are flatter and better paved, I can go faster for same MPG.
    According to that chart, I should be getting 60 MPG, but I don't come close to that usually. Oh well.
    I would definitely say you MPH is the problem. At 45 miles one way, though, at 60 MPH, you can go that speed and still arrive in 50 minutes I would say. Not bad to save an extra 5-10 MPG.
  13. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    That chart is measured at a steady speed with no wind or rain, on a warm day with a warmed up engine.
    Normal driving has acceleration from a stop and adverse weather and terrain. Maximum is not equal to average.
  14. davito629
    Thanks everyone that's posted. It seems like 40 MPG is to be expected with average driving above 75. I guess my previous experiences driving a Prius were in more congested regions where it was difficult to exceed 70 for any extended period of time.
    I'm bummed about the tires, they seem pretty good for traction especially in wet thus far. They've got maybe 6k on them, so I can't justify changing out almost new tires just because they aren't LRR. I guess if I keep up my driving, I'll be able to look forward to new LRR tires in <2 years! Although by then perhaps I will have upgraded to a Gen III.
    Thanks for the link to the Gen III speed vs MPG graphs. It looked like there was a graph from a Gen II in that post as well. Has anyone done more extensive studying of Gen II MPG vs speed like Bob has? Or is there somewhere that people are posting their results for a larger database? I know there are so many variables to account for, especially rain/wind, hills, and even driving in a flow of traffic vs out on a road with no cars in front of you. I work the evening shift, so I've even found that driving to work (just keeping up with the flow of traffic in the high speed lane) that my readout will suggest 2-3 MPG more than when driving home at similar speeds with no cars to follow in line with.
