Hill start assist is kinda cool
Discussion in 'Gen 3 Prius Main Forum' started by randallintacoma, Apr 4, 2010.
  1. rluser
    rluser New Member
    Portland
    Studebaker may have been the originator, but Toyota had it in cars long before '95. I recall it in the '70 Crown.
    [old threads are the best threads]
  2. Ajvdub
    Ajvdub New Member
    51
    La Crescenta CA
    I just learned about this today, I had no idea. And not to be a jerk, but it would be a lot cooler if it held till you hit the gas to take off.
  3. Tideland Prius
    16,678
    I agree. That way, it's always active. I don't like Toyota's implementation of having to fully depress the brake pedal. Passengers think there's something wrong when there's a blinking yellow light and a beep lol.
  4. Ajvdub
    Ajvdub New Member
    51
    La Crescenta CA
    Yeah, I could imagine people thinking there is something wrong with your car. But two seconds? Great for stop signs, bad for stop lights. My friend's Lexus has a red light feature, holds the brakes for you till you hit the gas, its a nice feature.
  5. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    Holding would be good, I cannot really think of a problem with it; why you'd ever want the car to not resist going backward while it's in drive. As it is I continue to never use the hill hold feature, though. On a car with an automatic transmission it just seems to me a pointless function.
  6. co_prius_3
    co_prius_3 Member
    174
    32
    Colorado, USA
    I agree. It has built-in creep, like most automatics (although the implementation is completely different). Even on a steep hill, just keep foot on brake until time to move. The electric motor has plenty of torque to keep the car from slipping backwards.
  7. Tideland Prius
    16,678
    True that's why I don't really like Toyota's implementation of having to depress further.
    It can still roll down a hill backwards if it's steep enough. Also, in snowy places, you want to gently introduce the throttle and not quickly step from the brake pedal to the accelerator and spin the wheels. In the snow case, it may be easier to apply the parking brake (or use your left foot to hold the brake pedal) as you ease the power in on a slippery hill.
    Yeah, the ((HOLD)) button is a great button haha. Yes, it maybe a lazy man's wish but honestly, after 12 hours at work, you want to go home as effortlessly as possible.
    I'm surprised you said that even though your profile says you're from Colorado. I've had the Gen 2 roll down a parking ramp so it will roll down steeper streets (and there are plenty in my area).
  8. fuzzy1
    10,700
    Like Tideland, I'm also surprised that a Coloradan would say this. While mine doesn't roll backwards on shallow slopes, it roll back on less shallow ones, much less steep than what I experienced in CO.
  9. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    I've never had any trouble with it. There is enough creep to allow a fast switch from the brake to the gas without much back roll.
    On the other hand, I cut my driving teeth on manual transmissions, where technique and speed were essential to prevent rolling back.
    Tom
  10. Maine Pilot
    Maine Pilot Senior Member
    166
    504
    Saco, Maine
    Back in the early '60's when I took my first driving test, MA had regulations that If you took your test on a automatic transmission vehicle, you were restricted to driving only that type of equipped car. However, if you took the test using a manual, (standard) transmission, you had unrestricted privileges, including motorcycles.
    Our local DMV made you parallel park on a hill, shut off the engine and restart. In order to pass, you couldn't roll back more than 2'.
    Now that automatics make up close to 90% of all U.S. vehicles, driver proficiency has deteriorated and we end up with namby-pamby devices like "hill-holding" and automatic parallel parking devices.
  11. fuzzy1
    10,700
    I also find the minor rollback a complete nonissue after decades of driving mostly manual transmissions. But after experiencing what seemed to be a truely seemless no-rollback automatic Subaru a few years ago, I don't want to overstate the lesser system in the Prius to the several readers who do have concerns.
    That Subaru was a sponsor-supplied event support car, so I didn't have time to read the owner's manual. But on the available slopes, the hill-holder brake was set with ordinary brake pressure, not the extra pressure of the Prius version. And it did not have a two second timeout, I sat much longer at a traffic light without it releasing.
    Subaru also had a hill-holder clutch in a car we test drove back in the 80s, but both of us were sufficiently seasoned manual drivers that it held no incremental value. By the time we actually bought a Subaru a decade later, the feature had vanished along with the smaller engines for which it was designed.
  12. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    I disagree. If you are on a hill and let go of the brake, you are going to roll.
  13. Dolce_Vita
    Dolce_Vita Member
    228
    25
    Sydney, Australia
    I've never felt the need for hill-start assist in a Prius? I dont really see any need for it in any automatic car as you can simply hold the brake with your felt foot and accelerate up the hill with your right foot? I also find the Prius holds itself pretty well. The ONLY time i've had a hair raising situation in an 'automatic' on a hill was in a Fiat 500 with the 'dualogic' single clutch robotised manual transmission (a manual with a computer controlled clutch, unlike the torque converter auto on the US 500), THIS rolls back like a manual as the computer engages first gear (it's almost mechanically identical to a MT), but it's nothing a good mash of the throttle and use of the handbrake cant fix.
  14. co_prius_3
    co_prius_3 Member
    174
    32
    Colorado, USA
    I meant it won't roll back once you move from brake to accelerator. The creep alone won't prevent rollback on a hill. But that's true for any automatic transmission car. The hill-hold is more useful on a standard transmission car.
  15. Tideland Prius
    16,678
    Again, this won't work on a slippery hill. I'm not talking about 0 degrees and slushy wet snow. It's -20 or -30 and the snow is hard compact with a thin glazed ice surface that won't disappear until the next snowfall covers it.
    The handbrake method and left-foot-on-the-brake-pedal ones will work. The idea is to gently ease in the power. Even with TRAC, you don't want to slip.
  16. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    That would be a problem for a one legged person.
  17. qbee42
    18,058
    3,081
    Northern Michigan
    We had a turbocharged Subaru with the hill-holder clutch. My wife loved that feature. I didn't need it, but I have to admit it was nice.
    Tom
  18. El Dobro
    El Dobro A Member
    7,103
    3,282
    I was stopped on a steep hill at a light and there was a guy behind me that was practically on top of my bumper. I used the hill hold and it worked great. If it's there, why not use it.
