Hints Regarding Replacement of 2G Front Struts
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Patrick Wong, Oct 10, 2009.
  1. freemandp
    freemandp Junior Member
    Canonsburg, Pennsylvania
    I replaced struts and shocks on my Gen III around 100K. My advice would be to get the bump stops and dust boots along with the shocks and struts of course but skip the support sub assembly or upper spring seats (the things that turn). When I replace the shocks and struts again at 200K maybe they would need replacing. That's when my Volvo's started to fail. They looked brand new on the Prius at 100K.
  2. billh
    billh Junior Member
    27
    cleveland
    I have been getting my regular service done at a Monroe. Does anyone have an opinion on replacing my shocks and struts there or would I be better off going to a Toyota dealership? 2006 Model 6. Also, does anyone know what my fuel capacity is in winter?? Add fuel light comes on and I usually can just barely add 9 gallons.
  3. dbird29
    dbird29 Junior Member
    23
    Used the VFAQ for front & rear strut replacement.
    Made it easy on myself and did the Complete Struts dot Com complete struts so I wouldn't have to do spring compressors.
    Concise and easy to follow write up.
    Thanks!
  4. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    how can i tell that my struts needs replacing??
  5. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    If they are leaking oil or car bounces if you push the suspension down you need new struts. If they aren’t they will just degrade at accelerating rate. Where’s your odometer at?
  6. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    I just bought my 2010 used this week and currently my odometer is at 235,914 miles
  7. valde3
    2,002
    750
    Finland
    Probably could use new struts if it still has originals. What has the previous owner used it for, since it has already gathered that much of miles?
    P.S. 2010 is gen 3 so you should have posted this on gen 3 forum.
  8. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    my bad. i just noticed i was in gen 2 forum. i do not know what he used it for. I got the car of IAAI. find attached mycarfax maintenance history. not too detailed so its making me worried. do you think its not a good buy??
  9. valde3
    2,002
    750
    Finland
    No I didn’t mean anything like that. I don’t have any idea of the condition of the car or price you paid for it so I can’t possibly have any idea about was it good purchase or not.
  10. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    ooh I did not mean you saying anything bad about the car. I just wanted to get your two cents. I paid roughly $5,000 for it. I am yet to inspect the shocks and batteries.
    #70 fopoku2k2, Jul 21, 2015
  11. valde3
    2,002
    750
    Finland
    Again I really can’t answer to that because I’m not in USA. Here it would have costed more than twice that. Cheapest I could find from statics was 11900e or 13000 US dollars…
  12. zak.kapoor
    zak.kapoor Junior Member
    33
    West Linn, OR
    Replaced the front struts on my 2008 Prius Touring last weekend. The information in this thread was a big help. Few suggestions I would add are:
    1. If you are on the original struts at 90K miles, they need to be changed. I have driven mostly on well paved roads and the struts were in bad shape. It took them more than a minute to go from full compression to full extension. The new ones took around 7 seconds.
    2. I agree with freemandp. The upper strut assembly was is good shape and you can skip replacing it at 100K. Along with the struts I replaced the spring mount (48158-47010) and boots (48157-02070).
    3. Use a sharpie when loosening the strut nut by 1/4 turn. This way I was sure I did loosen it but not by a lot.
    4. Replace the front struts, spark plugs and PCV valve at the same time. I had replaced the spark plugs a few weeks back and it was not easy. I had decided to skip the PCV valve at that time. After I had removed the cowl bracket for installing the new struts, replacing the PCV valve was a relatively easy job.
    5. Make sure you have all the correct parts before you start he job. I realized I has two right (passenger side) struts instead of one left and one right after I had disassembled the left strut. I had to put the car back together with the old struts, return one of the struts and wait for the left strut to arrive before starting againg :(.
    Overall it was worth the effort. The ride is a lot more comfortable and I feel the car is handling a lot better while turning. Next I plan to work on the rear struts.
  13. Troels
    Troels Junior Member
    29
    16
    Sacramento
    thanks for the informative post! I'm wondering if it's always necessary to replace the Support Subassemblys seeing that they are quite pricey?
    TIA, Troels
  14. Patrick Wong
    18,210
    6,523
    How many miles on the odometer? I would replace the top strut mounts if they have logged 150K miles or more.
  15. Troels
    29
    16
    Sacramento
    110K, are you referring to the the Support Sub Assembly? There is a lot of noise when driving over bumps, makes me think the insulators are worn out. Thanks!
  16. Patrick Wong
    18,210
    6,523
    Yes, I am referring to that. If you notice excessive noise, that component may be part of the problem.
    The insulators provide a rubber cushion at the top and bottom of the coil springs. You definitely want to replace the top insulators as they also encompass the pleated covers that protect the strut rods.
  17. Troels
    29
    16
    Sacramento
    Thanks for the detailed info! I'm having a hard time getting the Sears Craftsman MacPherson strut spring compressor to compress the spring enough to replace the shock comfortably. The spring has so few windings that the only way to attach the compressors is with one spanning 3 coils and the other 2, if they are to be positioned 180 degrees apart. When I proceed to compress the spring, applying equal compression on each compressor, I reach a point where the compressor spanning 2 coils can't go any further, but at this point the spring has not cleared the shock.....If I keep compressing the compressor spanning 3 coils, I can get enough compression to uninstall the shock from the spring, but the spring is now so uneven that it's hard to get it seated correctly in the upper insulator when decompressing....Any tips?
    Thanks, Troels
  18. Patrick Wong
    18,210
    6,523
    That has not been a problem for me. One of the photos I posted in my OP shows the spring compressors positioned just as you describe.
  19. Nic D
    Nic D New Member
    16
    Tucson, AZ
    Pardon my ignorance, but if a new strut comes with the spring already mounted why all this business about removing the spring? Can't you just remove the old strut with the spring still on it and install the new strut with the spring already on it as it was shipped?
  20. Patrick Wong
    18,210
    6,523
    IF you buy a strut with the coil spring and top strut mount already assembled, then you are correct that you don't need to worry about the spring installation. That is not the usual case, though. If you buy the correct strut from a Toyota dealer, then you will need to remove and replace the coil spring and top mount.
