Hissing, puffing sound when pressing brake pedal
Discussion in 'Gen 3 Prius Technical Discussion' started by Steelholder, Oct 6, 2023.
  1. ppatel
    ppatel Junior Member
    orange, california
    I did bit more checking, so here is my conclusion.
    When the car is off you dont hear the on and off of the pump, that part stops eventually but you hear the hissing when you press the brake even when its turned off.
    Another thing i noticed is, i turned the car on and just sat there for a bit, didn't press the break, during this time the pump constantly came on and then off, and then after a bit again on and off. This activity kept happening. Should it do that?
    Now do i need to change both the booster and the actuator or just one of them is bad? I am really considering not driving the car until its resolved or just sell the car and move on before i have to sink more money into it.
    Fyi the break still works as it always has and there are no codes. Miles is at 110k.
  2. ASRDogman
    ASRDogman Senior Member
    7,571
    3,905
    Eventually, it does bleed down. I believe that is normal.
    When you open the drivers door, the pump runs to pressure the system.
    After I shut of the car, I do hear the pump running, why? I don't really know. Maybe it's
    just keeping pressure in case you decide to get back in and drive.
    No one can tell you how long your system will last before it fails.
    And it is a good idea to replace both at the same time. The cost is a lot less than doing just
    one at a time. It's the labor that costs the most...
    It all depends on how much money you have to spend, and want to spend.
    Getting a new car, no matter what it is, will cost you more, but then you shouldn't have to worry
    about parts wearing out for a long time. If you buy used, you really don't know what you are getting.
    If you can do the work yourself, that's a lot less money you are spending....
  3. ppatel
    orange, california
    Can you be soo kind and test something for me? If you turn your car on and just sit there without pressing your brakes, how often is your pump running? And if you dont do anything does it eventually stop cycling? Mine keeps cycling every 15 seconds when i am just sitting there doing nothing.
  4. PTS
    PTS Member
    89
    39
    Austin, Texas
    2013 Prius v wagon
    Repeated cycling is not normal.
    Some get away with changing only the "master cylinder" (brake booster) part.
    Until it codes it will function as is but the reality is it could fail suddenly and lose power braking and some braking force resulting in longer than expected stopping distances.
    You also lose your regen braking and charging which significantly reduces mpg.
  5. ASRDogman
    7,571
    3,905
    Mine cycles every 20 seconds, give or take a second.
    It's been doing that for about a year, I think...
    It's due to be replaced. But I'm going to wait as long as I can. And hope it will be
    cooler weather to do it in....
  6. ChapmanF
    18,147
    I just read my last sentence there again and saw how it could look like I meant "with the car in reverse".
    I didn't mean it that way; I just meant you could also hear the hiss/puff when you're releasing the pedal and the fluid is moving the reverse direction, back to the reservoir, with the bubbles expanding again.
  7. SpeedDemon
    SpeedDemon Junior Member
    31
    Los Angeles
    Did you ever get your car's brakes serviced and find out what the issue was? My car has been doing almost the exact same thing with a hissing/gasping sound down at the brake pedal. Even when I'm parked or with the car turned off, if I press the brake pedal it makes a gasping/pumping sound.
    My car still brakes, but it seems to have a slight jerk feeling like I'm pumping the brakes.
  8. ChapmanF
    18,147
    Post #5 should answer your question (with the clarification in post #26).
