History of overheating, do I have a bad head gasket now?
Discussion in 'Gen 3 Prius Technical Discussion' started by suirPPrius123, Jul 20, 2021.
  1. Mendel Leisk
    41,496
    Replacing head gasket and ignoring cleaning of the EGR system (and intake mainifold) might well be why the replacement gaskets are promptly blowing.
    Just my 2 cents: the clogged EGR is the cause of head gasket failures: miles pile on, EGR clogs, head gasket blows. And almost invariably it fails at cyl 1 or 2, which is the end of the intake manifold whose EGR passages clog first.
  2. suirPPrius123
    suirPPrius123 Junior Member
    22
    Usa
    Makes sense! So maybe I could replace the head gasket, and just have the mechanic clean the EGR. Does that mean this might be completely unrelated to my car overheating a lot a few months ago due to a failed thermostat? or could they both be working together to make the problem worse? FWIW my OBDII said engine misfire in cyl 1, 2, and 3.
  3. Mendel Leisk
    41,496
    Are you thinking to replace head gasket yourself, have mechanic do Exhaust Gas Recirculation cleaning? If so, I’d be inclined to do the opposite: the head gasket replacement is a big job, and egr cleaning relatively easy, but time con$uming. More info on the latter in my signature.
    ASRDogman likes this.
  4. ASRDogman
    ASRDogman Senior Member
    7,604
    3,915
    Do both, a lot of money NOT spent....
    Grit likes this.
  5. suirPPrius123
    22
    Usa
    I'm a medical student and just don't have the time, I also have no mechanic skills or tools. I would pay a local mechanic to do both.
  6. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    Easy, since there’s no budget constraint mentioned, not a diy’er and no alternative travel work around listed, just sell the car as a project and buy an entirely new 2021 prime. No down time to anything and will last for many years.
    #26 Grit, Jul 27, 2021
    suirPPrius123 and Mendel Leisk like this.
  7. PriusCamper
    PriusCamper Senior Member
    12,790
    5,179
    Pacific Northwest, USA
    Yeah... that would definitely explain what the mechanic had a problem with in previous efforts and probably offering that info to 'em will make them more willing to do another head gasket the right way this time!
  8. Tideland Prius
    16,559
    *threads merged *
    Mendel Leisk and PriusCamper like this.
  9. PriusCamper
    12,790
    5,179
    In terms of a long term plan for regular maintenance of the EGR, you could but a new EGR and have the mechanic install that and then keep your old EGR and clean it yourself and then when it's time have your mechanic swap EGRs again. I know some mechanics don't like cleaning stuff and over-charge for that kind of work.
  10. suirPPrius123
    22
    Usa
    I saw in a separate thread that if you drove with a bad head gasket much (which I have done!) it may have done permanent damage to the engine, so you may not want to just replace the head gasket. Is this true? I fear that if I replace the EGR and head gasket, maybe the engine is already extremely damaged and will need replacement soon anyway?
  11. PriusCamper
    12,790
    5,179
    Bent piston rod is possible and can mostly be checked by putting each piston at top dead center with head off and making sure pistons are in exact same spot on all four of them.
  12. Mendel Leisk
    41,496
    EGR “replacement” is overkill, typically. Unless it’s a hopeless lump of carbon. And just moderately difficult DIY. More info in my signature.
    Raytheeagle likes this.
  13. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Pressure washer gets the job done;).
    Of the dozen I have done, the pressure washer has gotten them all clean every time:).
    And there have been some seriously clogged coolers:eek:.
    Something to consider (y).
    kc410, Mendel Leisk and PriusCamper like this.
  14. Jack Cates
    Jack Cates Junior Member
    Phoenix, AZ
    Three Touring
    Does it mess up the coolant system for sure? My idiot mechanic didn't ask me, he just put some block sealant in my cooling system.
  15. ChapmanF
    18,248
    Never a better time for locking up your car than when a shop mechanic is around.
  16. Mendel Leisk
    41,496
    With at least one of the sealants, a 50/50 mix of water and (regular household white) vinegar will dissolve the goop. If you can extract some coolant, get some with evidence of goop, you could test it with this mix.
  17. ASRDogman
    7,604
    3,915
    He did something you didn't approve, and it can cause damage ot other parts.
  18. rjparker
    rjparker Tu Humilde Sirviente
    10,164
    6,319
    Texas Hill Country
    Depends what he used and how much he used. Old school sealer only works with a flushed system filled with distilled water and flushed again after a period of time. Both flushes requires multiple passes and several hours of time before adding the approved antifreeze concentrate. These are pretty safe but most mechanics and owners go for the easier antifreeze "compatible" sealer and just leave it in. Sometimes adding two or three times the sealer when it does not work. Those guys plug heaters, pumps, thermostats and or radiators.
    No matter what type, the sealers all fail in a few weeks to a few months. Just enough run time for scammed owners to report good results and help sell more. Flush it out. Several times.
