HIT bump, check hybrid system message
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by pka222, Jul 21, 2020.
  1. pka222
    pka222 New Member
    vancouver wa
    Four Touring
    I was driving at slow speed and hit a pothole in my 2010 prius- immediately the check engine light and check hybrid system lights came on. I was able to drive 1 mile home, get the car in the garage with a "rough" feeling engine.
    After reading on line I disconnected the 12v battery and removed the orange safety "fuse" to reboot the system. After reconnecting and turning it back on the car will now not shift in to drive or revers- all lights come on.
    Since the warning light and issue came on due to the pothole - I'm looking for a loose wire or fuse or something that I can reconnect. any thoughts would be great.
    52,350
    i would start in the battery compartment, looking for loose plugs, modules and corrosion
    pka222 likes this.
  3. Mendel Leisk
    41,860
    A dealership could hook up Techstream, read the codes, try a reset. Probably cost you around $75.
    My guess is you jarred loose some connector.
    pka222 likes this.
  4. SB6
    SB6 Member
    324
    71
    In addition to loose plugs, I would also check for loose/disconnected hoses. I'm guessing you checked for any fluids leaking.
    Are you 100% sure you put the orange piece back in place? Is the car going into Ready mode? Do you have an OBDII scanner?
  5. ttou68
    ttou68 Active Member
    351
    211
    Did you see "ready" light in dash after you reattach 12V and Orang plug?
    And double check if you slide down the lock after you pushed in the orange plug...
    pka222 likes this.
  6. pka222
    pka222 New Member
    vancouver wa
    Four Touring
    that is my guess as well- I'll have it checked tomorrow
  7. bisco
    52,350
    check the orange safety plug as mentioned above, youtube has a video
