Hit Ice Chuck, Check Engine Light On
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by ykbj, Nov 14, 2019.
  1. ykbj
    ykbj Junior Member
    24
    2018 Prius
    Technology
    Hit a chuck of ice the size of a soccer ball. Right tow cap is blown off. Lower Grille bended inwards a little bit and it's mostly on the right side. The plastic cover underneath have some damage but nothing serious. Also, a lot of hard ice between the grille and Impact bar (?).
    Still able to drive home without issue. Except now I can't attach the tow cap back into place. Now, the CEL is on, what to do? More updates follow.
  2. ETC(SS)
    7,554
    Toronto, huh?
    Yeah.
    They have ice there, for sure.
    You're "probably" going to want to find out why the CEL light is illuminated "fairly quickly."
    I would probably try to get a OBDII code reader and access the port and pull the codes.
    It's super easy, super cheap, and if you have another car you can get a reader EASILY for under $20
    If you're armed with some information then we can all figure out next steps.
    As is true with everything these days, if you do not have another car Amazon will deliver one to your house.
    No.
    Not another car...but an OBD-II reader.
    Good Luck!
  3. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    The radar that is under the big emblem is probably damaged and throwing codes.
    ykbj and krmcg like this.
  4. ykbj
    ykbj Junior Member
    24
    2018 Prius
    Technology
    wait, electrical component related to engine problem?
  5. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    Sorry to hear your mishap. How did the ice end up so high to hit your bumper? Did a semi or something drop it off?
    Anyway, CEL can turn on by errors totally unrelated to the engine. It is a coverall warning light. As mentioned, your first step is to plug in a good quality code reader to find out what code is being thrown. I use Bluetooth OBDII reader OBDlink LX, but if you don't have one handy, you can pick one up at a local auto shop. Corded ones are usually not very extensive on Prius specific errors.
    #5 Salamander_King, Nov 14, 2019
  6. davecook89t
    davecook89t Senior Member
    1,093
    832
    Washington State, Florida
    Isn't it possible that the shutters on the grill are now bent or clogged with ice and cannot open or close? I agree with the suggestion to get an OBDII code reader to be sure, but I believe others have had the problem of stuck grill shutters throwing a check engine light.
    Raytheeagle, kithmo and ykbj like this.
  7. bisco
    52,854
    check engine is only for emissions, iirc, but that covers a lot of things
    alanclarkeau and ykbj like this.
  8. davecook89t
    1,093
    832
  9. Salamander_King
    11,024
    8,978
    New England
    Is that true for Prius only? Or for other makes too? I have not had any CEL or any other warning light other than TPMS come on my PRIUS (Gen 3 and PRIME), but for several Civic I have owned, CEL came on with error code related to transmission and IMA battery issues.
    ykbj likes this.
  10. bisco
    52,854
    i would suspect every car, but its only what i recall reading here. i could be wrong.
    shutters might be considered an emissions part due to warm up cycle
  11. ykbj
    ykbj Junior Member
    24
    2018 Prius
    Technology
    There's no other warning messages other than the warning light. I also thought it could be the grille shutter.
    I just came back from a 50km trip. Everything worked fine. New rattles in the cabin discovered. Front and center of the dashboard.
    I'll buy a OBD scanner tmr and update with some pictures of the damage.
  12. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I'd also check all fluids, just in case a hose etc is leaking. But the Grill Shutter is probably the most likely. If it were other than engine-related, I'd have expected a "Malfunction" error displayed.
  13. ykbj
    ykbj Junior Member
    24
    2018 Prius
    Technology
    Update #1:
    Is it safe driving without the tow hook cap?
    The lower grille was damaged also , hard to see in picture.
    Need help on this one!
    P.S. DRCC is working, all front parking sensors are working.
    Salamander_King likes this.
  14. CooCooCaChoo
    962
    544
    Cow-lee-fornia
    2023 Prius
    Yeah, the active grille shutter is damaged. Just googled that DTC and that is what comes up.
  15. alanclarkeau
    7,045
    7,593
    Tow hook cap - doesn't do anything except look like it's got a cover over the tow hook. You see cars quite often with them missing.
    krmcg likes this.
  16. ykbj
    ykbj Junior Member
    24
    2018 Prius
    Technology
    #16 ykbj, Nov 21, 2019
