Hitch causing trim to melt?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by climateguy, Jun 26, 2006.
  1. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    <div class='quotetop'>QUOTE(darelldd @ Jun 30 2006, 04:14 PM) [snapback]279373[/snapback]</div>
    Why? Devil's Advocate has a U-Haul hitch, not a Curt hitch.
  2. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(ryogajyc @ Jun 30 2006, 04:22 PM) [snapback]279376[/snapback]</div>
    For the simple reason that the U-Haul hitch IS the Curt hitch. The same Curt hitch is the one U-Haul carries and installs.
  3. Devil's Advocate
    922
    Las Vegas, Nevada
    Well I sent a message to Curt, we'll see what the response is. I'll check back in after the 4th.
  4. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(Devil's Advocate @ Jun 30 2006, 06:17 PM) [snapback]279432[/snapback]</div>
    Thank you Mr. Devil.
  5. ryogajyc
    985
    165
    Reseda, CA
    <div class='quotetop'>QUOTE(darelldd @ Jun 30 2006, 04:24 PM) [snapback]279377[/snapback]</div>
    My mistake. The only picture of a U-Haul hitch on U-Haul's website looked nothing like the Curt hitch.
  6. Cheap!
    Cheap! New Member
    1,157
    The force,
    Do you think you could take a temp reading of your exhaust after it is hot and maybe even the exhaust gases coming out and post them for us to see?
    Thanks
  7. jbarnhart
    jbarnhart New Member
    629
    Santa Clara, CA
    I crawled around and took a snappie of my pipe after bending it down. From the photo it doesn't appear as bent as it did when we were under the car on the rack. I hope it's bent enough! (Like the car's owner...)
    [attachmentid=3991]
  8. TJandGENESIS
    TJandGENESIS Are We Having Fun Yet?
    5,299
    47
    ★Lewisville, part of the Metroplex, Dallas, in the
    Huh. Maybe this is why the Toyota engineers did not want a hitch on the car...
  9. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(TJandGENESIS @ Jul 1 2006, 11:18 PM) [snapback]279997[/snapback]</div>
    Welll... there's no question that they don't want anybody towing with the car, but there is certainly NOTHING complicated about making a hitch work properly with the vehicle. Either design the hitch correctly, or bend the pipe down an inch.... not rocket science.
    JB... looks like enough to me. Hard to get a good angle for a photo when the car is on the ground. I probabl did mine TOO much. I dropped it 3/4" below the cross bar, and pointing basically straight down. NONE of that is going to get back up where it doesn't belong. I think I get 5% better gas mileage now too. :rolleyes:
  10. Cheap!
    Cheap! New Member
    1,157
    <div class='quotetop'>QUOTE(darelldd @ Jul 2 2006, 12:03 PM) [snapback]280125[/snapback]</div>
    Darelldd,
    Sorry to hear about your car. This has me giving a lot of second thought to doing a underbelly mod. If it gets that hot, I wonder if a high temp insulation might do well to be put above the pipe the entire length of it. It might keep the batteries and the car cooler. Were you kidding about the 5% better gas mileage, or were you thinking that would create a venturi affect? Please post a pic of your new tail pipe mod.
    Thanks.
  11. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(Cheap! @ Jul 2 2006, 10:18 AM) [snapback]280133[/snapback]</div>
    The battery (the ONE battery) shouldn't be effected since it is up inside the car.
    Yeah... that's what the little rolleye guy was for. Just a joke about all the discussions that revolve around things that just can't significantly change mileage.
    I did a few posts up. Here it is again.
  12. grasshopper
    grasshopper Member
    425
    Myrtle Beach SC
    <div class='quotetop'>QUOTE(darelldd @ Jul 2 2006, 01:03 PM) [snapback]280125[/snapback]</div>
    I get 50% better mileage with my Costal hitch. :)
    1st liar never has a chance. :p
  13. darelldd
    6,059
    389
    Northern CA
    Mine now creates gasoline while I drive.
  14. DaveOrgans
    DaveOrgans New Member
    75
    <div class='quotetop'>QUOTE(grasshopper @ Jun 29 2006, 02:48 PM) [snapback]278708[/snapback]</div>
    I was reading that the 2006 Prius has "A new front spoiler, which is made of TSOP (Toyota Super Olefin Polymer) that excels in recyclability, has been provided under the front bumper for enhanced appearance." (quote from new features documents from techinfo.toyota.com) I wonder if they now make the rear spoiler out of the same new material, and if this problem could be the result of that change. It seems unlikely that the problem should only start apearing now. (Of course, I do not know when the Curt hitch design went on sale originally, it could just be coincidence.)
  15. Devil's Advocate
    922
    Las Vegas, Nevada
    Well I received a reply from Curt...
    I appreciate you writing to inform us of the issue. We have just recently been informed of the possible side effects of installing the hitch. While we at CURT Mfg. are first and foremost focused on designing a quality hitch to serve the customers needs, I assure you that usability and safety are the first steps in the initial design process. We are currently looking at possible fixes or alterations to the current design and feel we can deal with the issue.
    Please let me know if you have other questions or need more information.
    Thank You Again,
    Mike Brunner
    Customer / Technical Service Representative
    CURT MANUFACTURING
    877-287-8634
    FAX 715-831-8712
    Not sure what they plan on doing about it but I told them I bought the hitch at U-haul and Curt didn't say it wasn't their hitch, so I am assuming they did manufacture the hitch. I'll try and get whatever "fix" they come up with. They should at least do that for people who have purchased their hitch.
    The more people that write in the better.
  16. grasshopper
    grasshopper Member
    425
    Myrtle Beach SC
    <div class='quotetop'>QUOTE(darelldd @ Jul 2 2006, 01:39 PM) [snapback]280146[/snapback]</div>
    You Win! :(
  17. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(Devil's Advocate @ Jul 3 2006, 11:56 AM) [snapback]280593[/snapback]</div>
    Thanks, Devil. I can't help wondering what they now think of their initial reply to me. And if they have sold thousands of these like they say... I wonder if they're just a wee bit worried about the issue being bigger than just me complaining.
  18. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(darelldd @ Jun 26 2006, 11:28 PM) [snapback]277254[/snapback]</div>
    Why I hate the ICE Reason# 278
    ~Darell
    Sorry, this shouldn't be happening. I hope that turning the pipe down will work for anyone contemplating a hitch.
  19. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(aaf709 @ Jul 4 2006, 09:10 PM) [snapback]281244[/snapback]</div>
    :D You guys are getting to know me a bit too well. :D
  20. darelldd
    6,059
    389
    Northern CA
    Nobody has heard anything more on this, I assume?
