Hitch for a bike rack?
Discussion in 'Gen 5 Prius Accessories and Modifications' started by TgrXtrm, Apr 23, 2023.
  1. black_jmyntrn
    black_jmyntrn Senior Member
    1,729
    410
    2013 Prius Plug-in
    on the bZ4X... I hear, on full charge, soon as you turn on the A/C it drops to 85% or so.. is this true?
  2. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    That displayed value is nothing but an estimate, one which has been revised via software update since rollout. I'm seeing around 4.0 mi/kWh for day to day running around with A/C. From a recent 340-mile round trip mostly highway with A/C, I got (calculated from charger measurement) an average of 3.56 mi/kWh. That efficiency from 65 kWh usable capacity calculates to 231 miles of available range. Since my AWD with 20" wheels is rated for 222 miles, what does that tell you about estimates?
    Back on the topic of hitches... I had been looking into upgrading from the hanger rack I've been using for the last decade to a platform type. Labor Day sales dropped the price 20%, so I pounced on this:
    https://www.rei.com/product/190985/thule-t2-pro-xtr-2-bike-hitch-rack
    #22 john1701a, Aug 25, 2023
  3. black_jmyntrn
    1,729
    410
    2013 Prius Plug-in
    interesting, thank you!
    a 2"inch hitch for the Gen 5 is actively in development btw...
    Blizzard_Persona and john1701a like this.
  4. Jabog6
    Jabog6 Junior Member
    32
    16
    CT
    2024 Prius Prime
    SE
  5. kellyj
    kellyj Junior Member
    45
    23
    Orlando, fl
    2019 Prius
    Looks like if you go to uhauls website they have them cheaper like $750 installed - I did the hitch install on my 2019 myself - wasn't easy about 2.5 hours or so. I did need some replacement body panel fasteners as some broke when removing.
    Jabog6 likes this.
  6. black_jmyntrn
    1,729
    410
    2013 Prius Plug-in
    That's crazy when you can get a PriusOverlanding.com hitch which was built with the Prius owner in mine and install it yourself for less than $450 shipped to your door.
    You know, the PriusOverlanding.com hitch is angled a few degrees towards the sky which eliminates the need for a hitch riser? Also it was the first hitch to be said can handle up to 500lbs tongue weight? Next thing you know, other manufacturers started following suit...
  7. kellyj
    45
    23
    Orlando, fl
    2019 Prius
    Yep due to only one option on market for gen 5 - put a hitch on my gen 4 for $85 (a draw-tite purchased off marketplace that someone never got to install). Install took a few hours.
  8. Jabog6
    32
    16
    CT
    2024 Prius Prime
    SE
    Yeah, I don't remember the exact cost, but both my Gen2 (which I no longer have) and my Gen3 (MY2010, which I still have) have hitches, and I'm pretty sure they were ~$200 or so.
    Maybe I need to wait a few months and see if prices drop a little.
  9. kellyj
    45
    23
    Orlando, fl
    2019 Prius
    Doing the same for now - but waiting is also becoming inconvenient...
  10. black_jmyntrn
    1,729
    410
    2013 Prius Plug-in
    I should have the new to-me 3D scanner by this weekend. The plan is to scan the things I need to finish the 2.0 swap and AWD conversion into my 2013 Prime before the weekend is over.
    now... should all go as I expect and the scans are precise, I plan on acquiring a Gen 5 to 3D scan everything outside, inside and under bumper covers. This would allow for the Gen 5 trailer hitches to be fully tested before the 29th and ready to ship from fulfillment no later than the 16th of the following month... for those of you who want in on one, the initial release price will be very attractive!
    nerfer and kellyj like this.
  11. kellyj
    45
    23
    Orlando, fl
    2019 Prius
    video of 2023 torklift central hitch install very simple - ordered one after watching $492..
    otatrant and PhoS like this.
  12. PhoS
    PhoS Active Member
    258
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    Pretty nice that it's hidden. I'll get one sooner or later, will be nice to not have to load the bikes on the roof.
  13. kellyj
    45
    23
    Orlando, fl
    2019 Prius
    yeah I was going to go that route but feel like roof racks add to road noise and reduce mileage - everytime I've had them I left them on permanently....
  14. PhoS
    PhoS Active Member
    258
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    I use a Sea Sucker and have put some good miles on it. It's not really that noisy but there is definitely a solid hit on the MPGs.
    otatrant likes this.
  15. Dyjital
    Dyjital Member
    91
    63
    Oregon
    2023 Prius
    XLE AWD-e
    blubrid, otatrant and Jabog6 like this.
  16. PHEVGuy
    PHEVGuy New Member
    Ohio, USA
    2024 Prius Prime
    XSE Premium
    I actually just sent Curt a note earlier today.
    As you saw from others, Torklift makes one (which can also be bought through your local U-Haul dealer.) I had a Torklift on my Clarity (though a different style.) It worked well for me. Full disclosure though, they gave it to me for free in exchange for me writing up a review and documenting the install on the Clarity forums.
  17. Xelah
    Xelah New Member
    Michigan
    2023 Prius
    I asked Curt last fall about a hitch for the 2023. They said they will make them if they get enough requests or as soon as there are enough Gen 5's out in the wild.
  18. kellyj
    45
    23
    Orlando, fl
    2019 Prius
    anyone find a way to cut the rear underside diffuser to fit it back on with the torklift hitch installed - the instructions basically leave it off after install.
  19. Dyjital
    Dyjital Member
    91
    63
    Oregon
    2023 Prius
    XLE AWD-e
    There is 3/8 -½" of interference. They both won't fit. The hitch crossbar is lower than the plastic piece diffuser.
    High resolution .PDF. Should show the interference I'm referencing. You can see the center two bumper tabs are pointing downward indicating the receiver is below 'level' where the diffuser was/is.
    #39 Dyjital, Feb 21, 2024
  20. kellyj
    45
    23
    Orlando, fl
    2019 Prius
    Yep, I was wondering about that and if a cut was possible (seemed like it would be just wasnt sure where to begin) - I spoke with torklift and they said their engineer was ok leaving it off and that would be included in new instructions...ultimately your not looking under there but it looks like it was there for aero originally and to prevent stuff getting behind bumper - I thought there may
