1. Mendel Leisk
    42,345
    One problem with a light that's gonna be off for years, then come on if there's a problem: what if it's defective from the get go?
  2. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    That's why all of the lights come on in a bulb check when you first power on. No light stays off for years.
  3. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    That only works when the driver checks all 37 bulbs at every car start.
  4. qdllc
    qdllc Senior Member
    1,377
    400
    Different strokes, I suppose. My old pickup had a massive coolant overheat happen (radiator ruptured). Not sure why, but I lost power, and the instant I pushed in the clutch, the engine died. No damage to the motor, but somehow the system cut the fuel supply when it sensed something wrong, and this was a 1985 pickup where the computer only controlled the fuel injection system.\
    I'm not suggesting your car needs to become a brick with 4 tires the instant danger is sensed, but an alarm with a gradual loss of power would be a good way to get you to pull over without being rear-ended by the guy behind you. Heck, it could even turn the hazard flashers on for you.
  5. frodoz737
    frodoz737 Top Wrench
    4,804
    2,560
    33
    Irregardless the side bar, I went almost 3.5 liters low on oil and "if" an idiot light actually did come on momentarily, it wasn't on long or loud enough to draw my attention on the 2010 Prius. Said light and/or chime should remain constant or as a "captured fault" until addressed, especially when the engine is providing the all the power at freeway speeds. Poorly designed master caution and warning system. I still consider myself lucky the Service Director owned up and took responsibility.
  6. Mendel Leisk
    42,345
    Decades back I had a phone conversation with a vet receptionist, and it stuck with me; she said that animals will hide symtoms, maintain appearance of being healthy as long as possible. As a defence against predators, made sense in the wild, but not so much now. Anyway:
    Seems like cars these days follow the same strategy: I'm ok, I'm ok, I'm ok...., I'm dead.
    audiodave likes this.
  7. frodoz737
    4,804
    2,560
    33
    ;)...and then it cost so much (all at once) to repair, they talk you into 1.9% financing on a new one. :ROFLMAO:
  8. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Oil level warnings aren't unheard of.
    My E36 BMW and Chevy Venture both had low oil sending units.
  9. frodoz737
    4,804
    2,560
    33
  10. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    No, I'm talking about an oil level switch.
  11. Former Member 68813
    3,524
    983
    US
    yup, toyota is way behind on proper ergonomics of dash warnings. i just bought a 2003 saturn for my child. while mechanically it's a POS, the cluster has very advanced functions with gong and alphanumerical explanation when some problems are present (like low fuel or high temp or similar).
    contrast this with prius that when it senses a door not securely closed when moving, you get the silly "put in park" prompt. idiots!
    pingd likes this.
  12. frodoz737
    4,804
    2,560
    33
    Yes I can read. Was pointing out what the vehicle in content uses...as most might not know.
  13. bingee3
    bingee3 Active Member
    171
    105
    Michigan
    2000 era Saturn known to , use, oil , besure to have saturn oil checked at each fill up , my daughters 2000sl is now toast
  14. Former Member 68813
    3,524
    983
    US
    yes, the s-series with 1.9L engine had the oil burning problem, not unlike the 1998-2002 corollas. the one i bought is 2003 Ion with 2.2 ecotech. now ecotech is a misnomer, as it gulps gas.
