home a/c efficiency
Discussion in 'Environmental Discussion' started by bisco, Jul 20, 2019.
  1. bisco
    52,807
    the downstairs was completely insulated. upstairs, the hip walls and attic are insulated. the sloped ceilings have 1950's insulation because they were not opened up during the remodel.
    the system is large and efficient enough keep it at whatever i set it at, but not enough to bring it down 5 degrees in the evening. if i try that, it takes some time into the early morning, depending on outside temp.
    74 during the day and 72 at night has been working fine and everyone is happy.
    but that is with temps in the high 80's.
    so today, i only turned it up to 73, since it was 95 out, and getting back to 72 tonight should work fine.
    the 'why' is in the o/p, which way is more efficient, leaving it at one temp 24/7 or notching it up and down morning and evening.
    i could just leave it at 72, but that actually feels too cool during the day.
    Raytheeagle likes this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    It feels too cool until you get used to it;).
    I don’t mind going down to the in law’s for weekend dinners for that reason :).
    5F is tough for a standard unit, but a 2 stage one, it does it no problem(y).
    52,807
    right now, its still 87 out, and i notice the thermo is at 75, so it is struggling a bit to keep up with the current heatwave
  4. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    How’s the outside unit look? Any buildup around the cage? How’s the temp on the fan that blows the warm air out?
  5. Leadfoot J. McCoalroller
    8,278
    7,788
    Pennsylvania
    2018 Prius c
    One of my outdoor thermometers logged 101°F today, hottest I’ve ever been home for in PA. 86% humidity to go with. Somehow the murder statistics didn’t go up with it, but the night is young...
    hill, Raytheeagle and bisco like this.
  6. bisco
    52,807
    it's fine. as i said, they service it every spring. no vegetation or other interference. everything looks clean and running smooth. i expect it wasn't designed for this much heat and humidity.
    how do i get the temp on the fan?
  7. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Even dust on the coils can affect the efficiency ;).
    If you have a compressor for something like filling tires, take it out and try blowing on a section of the coil. I bet some dust is removed :).
    If you have a IR gun, or something similar, you can shoot the area above the fan and see the temp difference. Or just feel it and see how warm it is(y).
  8. bisco
    52,807
    should it be warm, cool, ambient?
  9. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Most A/C units in the home have holes on either side of the A-coil where you can insert a thermometer. This is typically used by the installers to measure the delta-T across the coils, which is a fairly direct measure of how much work the A/C unit is doing to remove heat. For a given airflow, the higher the delta-T, the more heat being removed. This is more accurate than measuring the temperature above the fan unit on the exterior of the home (too many variables out there).
  10. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Warmer than the air it is replacing ;).
    So if it feels the same as the air around it, the efficiency of heat transfer isn’t good:cool:.
    Our unit has air that is typically 15-20 degrees warmer, but I’m not at home right now:).
    Enjoy 73 F indoor temps at the in law’s with some nice red wine(y).
  11. bisco
    52,807
    it feels much warmer on my hand than the 87 ambient. it is what it is i guess, until it needs replacing. hopefully, we won't have too many high 90's days, tomorrow is another though.
  12. bisco
    52,807
    you're looking at a guy with a hammer and a pair of pliers :cool:
  13. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Sounds like your unit is sized according to your house;).
    When we sized ours, we “upgraded” from what was previously there, which gave us more capacity :).
    Even on over 100 degree days out here, it does the job well, but a conscious decision at the time of purchase (y).
  14. Leadfoot J. McCoalroller
    8,278
    7,788
    Pennsylvania
    2018 Prius c
    You sure that isn’t Doctor guy with a hammer and a pair of pliers?
    Around here a fancy setup like that will get you pegged as a neurosurgeon.
  15. bisco
    52,807
    but you regularly have high heat, albeit dry. i don't think you want to size for worst case scenario, do you? maybe with the two step system...
  16. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    The cost to upgrade was $1200. So we went with it;).
    Having a unit run below capacity rather than closer to capacity should yield longer tenure into service :).
    I’m a big picture, total cost of ownership type with a CFO that supports keep things for a long while(y).
  17. bisco
    52,807
    i will try to remember this when the time comes. is it just the outdoor unit? will it work with the high speed system?
  18. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Check with various ac companies at the next replacement interval. We’re multi quoters when it comes to large expenses. So we had 4 quotes on replacements and we didn’t go with the cheapest;).
    Some have knowledgeable sales staff that come out and they talk intelligently about the options they have. Quiz them on what you’re thinking as well as what they would recommend. Then tell them some of the things that bother you about your current setup:).
    Some listen better than others, and their quotes show that(y).
  19. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    The correct way to size an HVAC system is to do a heat gain/loss calculation for the house, then put in a unit that is sized for that load. Sales people aren’t doing this calculation, and they will typically sell you a larger unit. My home has a 3 ton Trane, and the Carrier rep was working hard to sell me a 4 ton. No data to support it, he said it’s what they ”normally install”.
    A perfectly sized A/C unit runs constantly on the hottest day. It doesn’t hurt these units to run constantly when needed, and an oversized unit will have lots of off-cycle losses from starting and stopping.
    Hire an HVAC engineer to do the sizing calc for you, then buy that size.
  20. Leadfoot J. McCoalroller
    8,278
    7,788
    Pennsylvania
    2018 Prius c
    I battled that sort of inertia too. Our house had no air when we moved in. We added minisplits to the bedrooms upstairs, and as soon as I said I wanted those instead of a forced air system I started getting all kinds of pushback from the sales guys.
