Home Charging
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Tidalflats, Feb 24, 2013.
  1. Yes, I would buy a Prius PHV.
    67.6%
  2. No, I would buy something else.
    5.9%
  3. I would buy a Volt.
    2.9%
  4. I would buy a Toyota Camry Hybrid.
    0 vote(s)
    0.0%
  5. I would buy a Honda Accord Plug-In Hybrid.
    2.9%
  6. I would buy a Tesla.
    11.8%
  7. I would buy a Coda.
    0 vote(s)
    0.0%
  8. I would wait as there are so many new vehicles emerging.
    8.8%
Multiple votes are allowed.
  1. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    Standard household (residential) power in the US is split phase 240V.
    52,875
    andy, you have 6 wires coming into your 240v outlet?
  3. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    . No, there are 5 wires on the standard 110 power cord, for 220-240 there would be 6. Two smaller guage wires are sensors, but where would they hook up going into the house. OR, do they terminate at the brick? I don't plan on taking my brick apart just to see.
    52,875
    there is no brick with level two. whatever you call the unit (charging station? same as brick i guess) plugs into the wall outlet. my outlet has only 3 wires from the breaker box to the outlet, some have 4. you are correct, the wires from the car back terminate at the wall unit.
  5. devprius
    devprius /dev/geek
    979
    291
    Andy, I think you are confusing the number of wires coming out of the EVSE with the number of wires going into it. Only 3 electrical wires are necessary for both the portable 120V EVSE brick and a 240V EVSE. In the case of the 120V brick those wires are the hot, neutral and ground. For the 240V EVSE, 2 hots and 1 ground. The sensor and pilot signal wires are hooked up to the electronics inside the EVSEs which generate the necessary signals.
  6. devprius
    devprius /dev/geek
    979
    291
    In a 3-wire 240V outlet, like a dryer outlet, you have 2 hots and 1 neutral. In a 4-wire outlet, you add a ground wire. Code these days requires a 4-wire outlet.
  7. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    I explained what to do in my post.
  8. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    The poll choices are pretty strange. Coda? Why??? Why is the Rav4 EV and Leaf missing, esp. the Leaf? Why is the HyCam there but not the regular Prius?
  9. bisco
    52,875
    op has been a member for 5 years, and most of his posts have been about how to decide which prius to buy. talk about undecided! i think he is having a hard time getting a handle on the industry in general. i suspect he is still walking.:cool:
    Ken Blake likes this.
