Home wind power
Discussion in 'Environmental Discussion' started by bwilson4web, Jan 3, 2026.
  1. bwilson4web
    16,521
    Reduced solar production often occurs in windy conditions when a storm or front passes. It would be nice to harvest that energy. But traditional wind powered generators have esthetic and radio interference issues.
    A tower to put the wind mill generator into faster air faces city housing challenges along with cost, noise, and safety risks:
    The blades generate noise but worse, they can cause a multi path problem (variable reflection of TV and FM radio waves) that can induce unacceptable signal noise to the neighbors. But there may be a better approach, a Darrieus turbine.
    CONCEPT
    A set of cylindrical, Darrieus turbines mounted at each roof top apex:
    • One size for the shortest apex and as many as can fit on any segment.
      • May. include a 'hat' to improve air velocity on top
    • Automotive alternators with custom field controller:
      • A/C synchronous with solar roof, 240 VAC buss
      • Tunes for maximum average power draw (i.e., optimum current)
    • Tuned, helical blades
      • RF resonance tuned for a "dead" band with resistor and capacitor (i.e., ~2.4 GHz microwave oven or 27 MHz CB radio.) Make it a "dead spot' in that band.
      • helical to reduce noise 'pulses' for quieter operation
    BRASS BOARD
    My approach starts with figuring out how to make the Darrieus turbine cylinder. My first effort was to cut and tape a cardboard tube:
    • Two flaps were cut on opposite sides
    • Bent in so one edge forms a curve and the trailing section is taped in a taper
    Not meant for any practical purpose, just testing an approach. The next will print paper template that can be printed and taped into a three blade, helical, turbine, cylinder.
    DEVELOPMENT PLAN
    Once the assembly and dimensions for a sub-scale model are worked out, transfer the paper pattern to a flat aluminum sheet and fabricate a scale model. Use "car window spinner" test to make sure it self-starts and rotates in proportion to the speed.
    Modify the pin wheel cylinder to add a three phase, RC motor to brass board the controller and software. Again, use "car windows" testing to make sure it works as expected. The next phase entails operational dimensions, materials, and fabrication of a test article with alternator and controller. Only now, car roof testing to resolve remaining design constraints.
    Build one full-size test article and test on the roof. Initially on an isolated, 240 VAC circuit not connected to the solar power grid. Then carefully test with the solar power circit but disconnected from grid. Then do an integrated systems test.
    At this point, I should have enough metrics to determine expected power as a function of wind speed and safe operation. In effect, it becomes a wind turbine based, solar panel added to the existing system. Then begin manufacturing optimization and limited production.
    #1 bwilson4web, Jan 3, 2026
    davecook89t likes this.
    52,807
    i would love to have those. winter winds are usually much higher here
  3. fuzzy1
    10,691
  4. Leadfoot J. McCoalroller
    8,279
    7,789
    Pennsylvania
    2018 Prius c
    At low wind speeds you'll get the best energy recovery out of high sensitivity permanent magnet motors driven as dynamos. You can harvest great ones out of treadmills. Been there, done that.
    bwilson4web likes this.
  5. tochatihu
    tochatihu Senior Member
    9,963
    3,846
    Kunming Yunnan China
    2001 Prius
    The multipath problem (EMF vs. moving blades) is the National Security risk of offshore wind turbines (vs. radar) cited by Administration to cancel offshore wind farm leases.
  6. bwilson4web
    16,521
    Ah EMF, remember the old EMI claims against the early Prius?
  7. Leadfoot J. McCoalroller
    8,279
    7,789
    Pennsylvania
    2018 Prius c
    has multipath reception distortion been a factor in anyone's enjoyment of broadcast frequencies in the 21st century?
  8. bisco
    52,807
  9. bisco
    52,807
  10. bisco
    52,807
  11. Trollbait
    12,817
    I suspect the observations for those maps were done more inland, or the band of potentially better generation on the coast is lost in the map's scale.
  12. bwilson4web
    16,521
    My case is smaller. I have a house with solar panels and since the two, 55 year old, 180 ft pine trees are gone, have a SouthWest exposure to prevailing winds. My solar roof produces a maximum of 1-4.8 kW on a clear day. But adding an extra 2 kW of wind from the apex of the house would be nice. Especially on cold, stormy nights.
  13. fuzzy1
    10,691
    Our TV reception is generally dealing with stationary multipath, not the rapidly changing version. In the digital modulation world, rake receivers (if implemented) can actually take advantage of stationary multipath's added signal power to increase their signal to noise margin. This doesn't work with fast changing multipath. I don't know what change rates they can accommodate and still keep the many filter coefficients usefully updated.
    The tin hat crowd was concerned about biological effects of EMF. But even that tin hat crowd never latched on to Trump's claim that the noise from wind turbines causes cancer, so he had to come with some other excuse to stop them.
    A quick search finds this to be an actual issue, but I haven't read enough to learn how significant.
  14. ChapmanF
    18,994
    Does the answer depend on whether defense radar operators derive enjoyment from their work?
    fuzzy1 likes this.
  15. Trollbait
    12,817
    We could just put those systems on blimps.
  16. bwilson4web
    16,521
    Something about a blimp shaped human comes to mind. <rimshot>
  17. bisco
    52,807
    hey! i resemble that remark :cool:
  18. bwilson4web
    16,521
    Something like this:
    At least he is awake.
  19. fuzzy1
    10,691
  20. Trollbait
    12,817
