HomeLInk Genie Garage door programing
Discussion in 'Prius v Technical Discussion' started by Baltimore66, Jan 3, 2018.
  1. Baltimore66
    Baltimore66 New Member
    South East
    2015 Prius v wagon
    Im having a terrible time programing my Homelink system in my 2014 PriusV. I have a 2 Genie door openers. Anyoneone lease having the problem or solved it?
  2. walldiver4
    walldiver4 Junior Member
    Denver, Colorado
    2013 Prius v wagon
    I think most of us have had problems figuring out the Homelink interface. I found it helpful to download the instruction set from the Homelink website then CAREFULLY follow all instructions for the particular door opener to the letter. Be aware, this will often take two people to accomplish.
  3. riggone
    riggone Junior Member
    I had a similar problem with my 2012 Prius V. Apparently, there were changes made to the "standards" around Homelink communications between the garage door openers and the car buttons. I was told that they make an adapter (around $50) that can be attached to my garage door opener that will fix the problem. I refused to spend more money since I just spent $150 on a new door opener, so I now use the opener button that comes with the door opener instead of the buttons in my car.
    bisco and Baltimore66 like this.
  4. padroo
    padroo Senior Member
    2,763
    2,250
    The directions should also be in your owners manual.
    Baltimore66 likes this.
  5. Baltimore66
    South East
    2015 Prius v wagon
    So I figured it out. Thanks to a link provided here on this thread. However the caveat is I believe it recommends pressing the home link button three times after you press the learning button on the garage door opener. You have to press the home link button FOUR! Times and now it works thanks so much guys
  6. bisco
    49,379
    great find, i wish there were a way for all home link users to see this!(y)
  7. Mendel Leisk
    38,648
    I got my son to do it. :oops:
