Homelink Mirror Auto Dimming (or not?)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by eglmainz, Aug 11, 2009.
  1. Tideland Prius
    16,554
    how's an auto-dimming mirror a safety issue?
  2. compac
    compac PSU, Metallic Blue Ribbon
    52
    VA, Blue Ridge mtns
    Besides the question if its a safety issue... Dooh
    Noticed that if the dash dimmer switch is dimmed low, the Rear view mirror seems to dim a bit more quickly,
    Not sure if it just that is because there is less light on the sensor that is on the back of the mirror or if the 2 systems are inter-connected.
  3. CheeseheadPrius
    CheeseheadPrius Junior Member
    59
    Northern Wi
    2016 Prius v wagon
    This seems like the easiest solution to the prob. You can buy the glue at any parts store for an easy DIY. Getting the button off may be tricky since it's so new. If you try it just mark the windshield with a marker so you know where to position it.
  4. tracuco
    tracuco Junior Member
    Madison
    I have had my Prius for less than two weeks. I have been trying to figure out how the auto dimming works. My wife's toyota has auto dimming and works fine. The auto dimming on my Prius seems not to care if there are bright lights behind me.!?
  5. compac
    52
    VA, Blue Ridge mtns
    For a one word snide reply... not.
    For a fuller opinion:
    So it doesn't do it well at best.
    It dims only w/ a car too close. Make sure the power button is on. Other than that it is slow to react. I asked about the mirror at a service check, was told there is no adjustment from the dealer side. It was one of the few major design problems w/ our Pri. :confused:
    Haven't seen any way to adjust the sensitivity either.
    Even back in the 80's Ford had an auto dimming mirror w/ adjustable sensitivity...
  6. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    It doesn't dim much because the spoiler blocks the direct light to the sensor.
  7. GeorgeS
    GeorgeS Junior Member
    Minnetonka, Minnesota
    2013 Prius v wagon
    We have a 2013 Prius V and do not like the auto dim mirror. It does not dim soon enough for me. Also it seems to revert to day too soon. How can the sensitivity be controlled? If I turn the auto feature off, how do I force it to the night setting?
