Homelink Mirror
Discussion in 'Gen 5 Prius Accessories and Modifications' started by Robmoo, Sep 10, 2024.
  1. Perfectpacman
    Perfectpacman Junior Member
    85
    24
    United Kingdom
    2024 Prius
    ----UK----
    I've got the FITDVR and run my dashcam and auto dimming rear view mirror from it. Best upgrade I've done. Easy to install and saves being blinded with that cheap standard one.
  2. GuyOthersome
    GuyOthersome New Member
    Chicago
    2025 Prius
    Are auto-dimming mirrors like the Advent ADVGENFLCHLN compatible with the 2025 LE? What kind of power adapter would I need?
  3. bob12345
    bob12345 Junior Member
    30
    Knoxville, TN
    2024 Prius Prime
    SE
    If your vehicle trim does not come with auto dimming review mirror, then there is not adapter already in the vehicle.
    These adapters below will work coming off the TSS 3.0 16pin harness, but they do not support dash cameras "park mode" feature so camera recording is not possible when the vehicle is OFF. Only recording possible when the vehicle ignition is ON.
    Our vehicles uses a 16pin connector for TSS 3.0
    Lane Trace System Dash Cam Power Adapter for 2019+ Toyota – Dongar Technologies LLC
    Dash Cam Power Adapter (16-Pin) for Toyota and Lexus. D3-011 – FitDVR
    I checked my vehicle just now (no auto dimming review mirror like yours) and I was hoping to see the unused review mirror cable tucked behind he headline, but after removing the center light, I could not find any unused cables. Does anyone have a wiring schematic for the 24 pin harness for the overhead light? 1st picture shows the only one cable from the headliner going to the safety camera. 2nd picture is after I removed the overhead light unit and feeling around for any extra wires. 3rd picture is the 24pin harness.
    #23 bob12345, Dec 27, 2025
  4. bob12345
    30
    Knoxville, TN
    2024 Prius Prime
    SE
    What I should have asked is does anyone know the pinouts for the auto dimming homelink mirror, PN: 87840-0W690? From ebay posting images, appears there are at least (6) wires
    #24 bob12345, Dec 30, 2025
  5. otatrant
    otatrant Active Member
    349
    212
    San Francisco
    2023 Prius Prime
    XSE Premium
    For the auto-dimming mirror there are just 3 wires on the car side of the harness.
    Wires 9 and 10 are for some/all digital rear view mirror and are CAN wires not present on the auto dimming mirror with Homelink. In summary the wiring harness for the car has 3 wires in positions 1, 2, and 6. The other 3 wires on the mirror side are attached to pins but do not have corresponding wires on the car side of the harness.
    Here are some pictures
    of the car harness as it comes from the factory for the auto-dimming rear view mirror with Homelink.
    #25 otatrant, Jan 1, 2026
  6. bob12345
    30
    Knoxville, TN
    2024 Prius Prime
    SE
    Thanks Otatrant. I decided instead of buying a used OEM homelink/auto dimming mirror on Ebay for around $200 and then the 10 pin connector and add a fuse kit, I decided it will save me time to buy the below. I still want to buy a add a fuse kit since I want to do zero modifications to any wiring harnesses on my vehicle. I will create a thread later to explain the install process.
    NEW Advent/Gentex Frameless Auto Dim Rear View Mirror w/Home
    otatrant likes this.
  7. Tekz
    Tekz New Member
    26
    British Columbia
    2026 Prius Plug-in
  8. Tekz
    Tekz New Member
    26
    British Columbia
    2026 Prius Plug-in
    I have the SE PHEV and was able to upgrade the basic rear view mirror to the auto dimming with homelink using Gentex Advent brand. I connected it via fuse tap and initially was hard to figure out but afterwards, easily able to wire it and install. Only missing part was the 1” wedge to wedge spacer mounting bracket that I ordered via Amazon which was expensive for a plastic piece but oh well, can’t get any shipped from the US here to Cda
    VelvetFoot likes this.
