Hood Deflector Installed
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Crazy Canuck, Mar 6, 2010.
  1. Crazy Canuck
    Crazy Canuck New Member
    60
    Calgary, AB
    Dealer called and said the hood deflector and all season mats I'd ordered came in. While I went in to get them installed, I picked up the rear bumper guard too.
    Pleasantly surprised with the look of the hood deflector!
    Prieth, PriusCrazy and Boo like this.
  2. Boo
    Boo Boola Boola Member
    5,051
    485
    97
    Flushing, NY
    I think it looks pretty good on gray Priuses like yours or on black Priuses.
    But on the other colors ....
  3. PriusCrazy
    PriusCrazy Blizzard Pearl for Me
    213
    28
    Triad, NC
    Cool! Thanks for sharing.
  4. F512M
    F512M Member
    415
    Laguna
    Looks great!!!
  5. mhl0125
    mhl0125 New Member
    Medford, NJ
    What was the cost of the deflector...just for the part...not installation?
  6. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    I really do not like the looks on a car
    I have on on my pick up . It does save the front of the hood but the hood is sqaure to the front of the truck not sloped like a Prius
    And I do not believe it save the window shield
    So what is the purpose of the Hood Deflector on a Prius?:confused:
  7. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    These hood protectors seem popular in America but nowhere else. What are they for (other than protecting the hood)? Do they not cause more problems with damp and dirt trapped between the paintwork and the protector? or are they just for use in warm States?
  8. exbauer
    exbauer Active Member
    1,185
    101
    Washington
    Has the hood deflector helped? I am thinking of getting one for my up coming road trip and remove it when I get back. I know the hood is aluminum and any rock chips would not rust. So, maybe I should just forget it. Also, the hood deflector doesn't blend in on a BP.
  9. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    If you like it that is all that matters. I'd never put it on mine. When I looked at your picture my first thought was you hadn't finished taking the wrapper off of your car.
  10. Judgeless
    Judgeless Senior Member
    1,821
    256
    Cleveland, OH
    Hood deflectors often cause more damage to the hood then not having one. Toyota spends a lot of money testing the aerodynamics of the car. I am sure adding this drastically affects all the work Toyota invested in making this care get good gas millage.
  11. epete
    epete Member
    75
    27
    New Jersey
    Hmmm. Just installed mine from PriusChat. You are probably right on all points. The deflector is held in place by 6 poorly somewhat fastened brackets. Two are fastened to the hood in existing holes and four just clip around the hood. The paint is protected by six plastic stickers and two bumpers. It amost feels as if the deflector almost doesn't fit. It is also fastened with somewhat cheap pressure based screws. You press the fastener in than screw in the screw making the fastener expand. The screws seem a bit cheap as some didn't screw in, they just pushed streight in. I purchased several other items from PriusChat. All were excelent quality, this was the only uitem that was slightly dissapointing.
  12. bbqnosher
    bbqnosher Junior Member
    36
    us
    For those who have installed the 2010/11 hood deflector how do you find it working? Does it prevent any damage? Has is come loose at all? Any affect on mpg? I just purchased a 2011 two silver and thinking about buying one but would like to have some real life feedback. thanks
    Prieth likes this.
  13. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    What are the numbers for CD before and after?
  14. donee
    donee New Member
    2,956
    197
    Chicagoland
    Yea, your right. But they are popular in the USA because, if you have ever driven across Texas in June without one, you will quickly run out of winshield washer fluid. They have bugs, called, suprisingly June Bugs. These are 1 cm long, by .5 cm in diameter, and when they hit a windshield at any speed greater than 50 mph, the sploch is about 4 cm in diameter. After enough hits, you cannot see out of the window! With a deflector, much of the bugs get shot over the roof.
    Some years around here we get Cicadas. I remember driving home one day and going through a flock of them. These can be like 2 to 3 cm long, with an oval body 1 by .5 cm. Cars actually spin out on highways from the slick road surfaces when enough of these get run over.
  15. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hmm. The 3rd Gen Prius is allot worse aero drag wise, no matter what Toyota says the CD is. The deflector might make the effective rake angle closer to the second gen and reduce aero drag!? At least in my opinion.
    My guess right now is the lower front rake is resulting in a higher momentum induce flow over the roof, causing a greater effective cross section.
    Or else its the bigger tire openings and wider tires?
    Something is really draging down my 3rd Gen compared to my 2nd Gen at 50 mph! And I have had the alignment checked already....
  16. bbqnosher
    36
    us
    For those who have the 2010 hood deflector shown in the post ...what is the width of the deflector. I know the hood deflector goes the length of the hood but was curious as to the width or depth. Looks like 5-6 inches.
  17. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Tires perhaps? When I switch from different 15s (I've tried 3 different brands) or god forbid my 17s the drag varies a lot.
  18. richard schumacher
    7,663
    1,040
    United States
    And how th' heck do you know that? Show us pix of your wind tunnel or CFD codes, please :_>
  19. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Because it has a larger frontal area and because roffl said so! :)
