Hood does not open
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by gatorback, Aug 17, 2025.
  1. gatorback
    gatorback Junior Member
    60
    I would like to open the hood. I pulled the lever and heard the expected release. The hood did not budge. I tried pressing on it. What is the procedure to open the hood, given that I have already pulled the hood-lever?
  2. Tombukt2
    Tombukt2 Senior Member
    13,867
    2,519
    Durham NC
    And now if you touch the hood release lever there's nothing but play so mechanical are undone ? Rust belt car ? Damaged front end as in noticable ?
  3. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    If the cable didn't brake(break?), it's likely the latch is stuck.
    Sometimes "popping" the hood with the side of your fist it might pop it loose.
    Sometimes pulling up on it a little then popping it will release it. It could also be a little
    out of alignment and it's snagging.
    After you get it open, use some spray grease on all the moving parts and around the hook on the hood.
    #3 ASRDogman, Aug 17, 2025
    NutzAboutBolts likes this.
  4. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,789
    Bay Area
    Yep, I had to bang on the hood for it to pop up. Overtime the latch becomes sticky, so it won’t release as if it was new.
    ASRDogman likes this.
  5. Tombukt2
    13,867
    2,519
    Durham NC
    Tweak it in place .
  6. ASRDogman
    8,067
    4,089
    Were you able to get it open? Any update???
  7. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    The plastic seal gasket on the outer edge between the hod cover and engine bay can be stuck when pulling the hood open lever. Pull the lever and then physically grab the hood right before the seal and pull the hood up, you will hear the unpeeling sound of the gasket and it will lift.
  8. Mendel Leisk
    42,355
    I took a look at the hood latch on ours yesterday, noticed there's a second release tab and guide, on the underside of the latch. That one you need to more the opposite direction, since it's on the underside of the pivot point. Pretty sure it's for use with right-hand drive models.
    You could tie a string to that, run through the adjacent guide slot, then maybe find a way to snake it down to the underside of the car, for use if the regular cable broke or seized.
