Hood latch cable replacement?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by glennonrp, May 1, 2021.
  1. glennonrp
    glennonrp Active Member
    178
    199
    Fontana, CA
    Four Touring
    Over the winter I noticed my hood wouldn’t open when I pulled the release under the dash. I was able to get it open. But the cable came off the latch release thing under the dash. I couldn’t get it back in place. So, today I went to the dealer to get an oil change and I asked them to look at the hood latch issue.
    They told me the cable got stretched and has to be replaced, costing $600.
    This upsets me because this is a 2016 Prius. I’m the original owner. Personally, I’ve opened the hood maybe five times in five years. The only other times were when I took it for service. How in the @$&# does a hood release cable stretch so badly in 5 years that it needs to be replaced?
    I was told most of the cost was labor. No, duh. I'm so irritated. This isn’t normal wear and tear.
    Any advice? I’m not mechanically inclined. Usually when I work on a car, I have to get angry, bleed, and cry before the job is done. So, I don’t, usually, work on my car.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Maybe contact TOYOTA - they should last the life of the car - I've had 30 yr old cars with issues - but never a Hood latch cable issue.
    Elektroingenieur likes this.
  3. Elektroingenieur
    2,515
    3,288
    Three Touring
    It’s not clear to me why this should be a $600 job. In addition to @alanclarkeau's kind suggestion to seek goodwill consideration from Toyota—I agree, this isn’t a part that should wear out with normal usage—I’d suggest trying another Toyota dealer or an independent shop.
    The parts are not expensive: as shown in catalog Figure 53-03, Hood Lock & Hinge, the hood lock control cable assembly (part number 53630-47080) has a list price of $34.94, and the hood lock control lever sub-assembly (in black, 53601-52010-C1, or neutral warm gray, 53601-52010-P2) has a list price of $47.58. Due to design changes, both parts might have to be replaced together.
    As for labor, one edition of Toyota’s Flat Rate Manual allows 1.0 hours for removal and replacement of the hood lock control cable assembly (operation number 530121; ZVW50 series).
    alanclarkeau likes this.
  4. glennonrp
    178
    199
    Fontana, CA
    Four Touring
    @Elektroingenieur Thank you! The sales manager just emailed me to ask if I want to trade in my car. I am telling him no way since they think it’s acceptable to quote me $600 to replace a cable that shouldn’t need to be replaced already. I would like to quote your post, if that’s ok.
  5. Elektroingenieur
    2,515
    3,288
    Three Touring
    You’re welcome, and please feel free.
  6. alanclarkeau
    7,045
    7,593
    Hmmm - reminds me of a friend who had had a series of BMWs, but tried an AUDI. Took it for it's 3 year service just before it came out of lease (was just out of warranty). Workshop gave her an extensive list of items which needed repair, which horrified her - quite a few $1000s.
    As she walked out the workshop, she commented to the Service Manager "I was just about to go up to <SALES> re the lease of a new AUDI - but I'll go back to BMW. "Oh, Madam, I'm sure we could work something out". She went and got a new BMW 4 Series.
  7. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,530
    2,552
    Taylors, SC
    The cable replacement is an easy job where everything is readily accessible in the ingine compartment and under the dash.
    I have included instructions for opening the hood, if this happens and the hood won't open.
    First, you must open the hood to examine the cable. The "T" shaped "dog" could have slipped out of the slot in the hood latch release lever. I advised a friend of mine in Florida how to do this and he successfully did it in less than 30 minutes.
    It might be a good idea to examine how the cable releases the hood latch on another Toyota.
    First, raise the car up on ramps or jackstands.
    Remove the engine under cover to gain access to the space between the radiator and the engine.
    With a flashlight and laying on your back, find the hood latch and see if the cable end's "dog" has been detached from the slotted end of the release latch.
    Having found the slot, use a long screwdriver or a thin metal rod, push the slot with it's end from the bottom until the hood latch releases.
    If the "dog" had slipped out of the slot at the end of the hood latch release lever, move the slotted end of the lever toward the driver's side and re hook the cable.
    Have a friend pull the hood release and see if it it releases the hood latch.
    Tie a string to the hood latch release lever and lead it out above the driver's side fender. This is in case that the latch will not release again, when the hood is closed.
    In case this doesn't work the cable is easy to replace as it threads into the firewall to connect to the under dash release.
    If everything works after several test, remove the string and you're done.
    #7 Georgina Rudkus, May 2, 2021
