Hood light
Discussion in 'Prime Accessories and Modifications' started by Michael Fang, Nov 12, 2021.
  1. Michael Fang
    Michael Fang Junior Member
    17
    24
    Orange County, CA
    I've install a cheap dyi hood LED light so one can see in the dark. Total cost is $5 and that included the LED, switch, fuse, wire and wire loom.
    Here's all the parts and tools you'll need.
    52,697
    beautiful, well done!(y)
  3. Michael Fang
    17
    24
    Orange County, CA
    Decided to put one in the trunk as well because the stock one isn't bright enough.
    Off
    On
  4. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    Did you get that LED lights off of eBay do you have any Information on the seller.? It looks really good.
  5. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    1) Where did you tap the power from?
    2) Can you provide a link to the switch used?
    3) What is the orange thing at the end of the wires at the upper left of the picture, a fuse?
  6. Michael Fang
    17
    24
    Orange County, CA
    I got the LED and all components from Amazon. 10 pack for $20.
    1) Where did you tap the power from? In the hood, direct to battery. In trunk, tap the OEM trunk light and added an additional switch.
    3) What is the orange thing at the end of the wires at the upper left of the picture, a fuse? Yes, 5 amp fuse.
    I connected the switch to the ground wire so I'm able to get away with using a low amp switch, not that the light is high power. The LED is under 5 watts and output 580 lumens.
    #6 Michael Fang, Nov 13, 2021
    xliderider likes this.
