Hood: Paint chips
Discussion in 'Gen 4 Prius Main Forum' started by yeldogt, Jul 28, 2019.
  1. yeldogt
    yeldogt Active Member
    810
    313
    NE
    All the 16's are black .... at 60k they all have many hood chips. White primer .... black paint ... bad combination.
    Must be the weird angle of the hood .... all cars get them obviously. The Gen 3 much less ..same with the CT's. Although we only have two CT's
  2. krmcg
    2,592
    2,393
    Whittier, CA
    My white 2016 Prius has a black undercoat and my black 2014 Avalon has a white undercoat - go figure...
  3. Seamaster
    Seamaster Member
    123
    70
    GB
    2019 Prius
    Excel
    The switch to water borne paints several years ago didn't help. The paint on most modern cars is soft as butter.
    Mambo Dave and krmcg like this.
  4. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    The color coat is waterborne. The clear coat is urethane. You want the clear coat to be somewhat soft, to absorb impacts. Car paint and windshields tend to chip worse in the winter when they are colder and more brittle.
  5. fuzzy1
    10,676
    Plus, there is a lot more sand and gravel on the roads in winter, spread there intentionally during icy conditions to improve traction.
  6. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Yes, the actual road surface is a contributor, but it can depend a little on how you drive as well. My Dad incessantly drove much closer to the car in front than I felt comfortable with - and his bonnet was covered in stone chips. My cars had almost none.
    Data Daedalus, fuzzy1 and kithmo like this.
  7. fuzzy1
    10,676
    My household also gets that too-close problem occasionally too. But it gets to be a household political problem when, as passenger, I request a backing off to protect the front, and get told that if we go any slower, we'd be going backwards. But when that is immediately followed by a handful of loud stone strikes, she will relent and back off, though clearly very unhappy about it.
    Winter is different, there is so much debris on the road that on-coming traffic throws a very significant amount across the centerline, so chips are inevitable.
    Data Daedalus and alanclarkeau like this.
  8. yeldogt
    810
    313
    NE
    It's the car ... we have different drivers. all the Gen4's have way more chips vs other cars in the fleet. We have Gen 3's with 200K+ with way less.
