Hood sticking in closed position.
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by MattStevenson, Nov 20, 2017.
  1. MattStevenson
    MattStevenson Member
    57
    35
    US
    I can get my hood open by messing with the release and pulling up on the hood but it's not easy. I read penetrating oil works well to lubricate it and get it back to normal. Any of you had to deal with this and had a good solution?
  2. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    Does the hood release button move freely and snap back when you operate it from the driver's seat with the hood already up? If so, turn all your attention to the latch mechanism. Work some grease into all parts of the latch, not just the lever.
    A Rule of Life: If it spins, use oil; If it slides, use grease.
    Andyprius1 likes this.
    52,860
    just looked at mine, the mechanism seems to be covered with some kind of grease. and make sure the spring is working properly.
  4. Yea Right
    Yea Right Active Member
    232
    115
    Seattle
    2014 Prius Plug-in
    White lithium grease
  5. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    A large screwdriver for leverage may release
  6. bisco
    52,860
    or a bloody mary.
  7. Andyprius1
    2,327
    859
    Cool CA
    Not on hood! but release lever.
  8. bisco
    52,860
    don't drink and drive!
