Hooking up aftermarket stereo to Battery
Discussion in 'Gen 2 Prius Audio and Electronics' started by BubbaVO, Dec 9, 2008.
  1. BubbaVO
    BubbaVO New Member
    53
    Philly
    I'm one of those few unfortunates that had the aftermarket stereo system installed to the starter battery. According to the Toyota tech, there are 13 Amps being drawn from the battery. All I know is that the I've needed to jump start my car every morning - that's after a 50 mile commute home from work that should have recharged everything.
    Does anyone have detailed instructions (and pics) on how to properly hook up an amp/subwoofer to the battery so as to avoid such drain? Is the "starter" battery the right one to access for such power?
    I assume that that the amp and subwoofer are drawing on the battery when the vehicle is off? Any ideas on how to stop that in the first place?
    Any help would be appreciated.
  2. EZW1
    EZW1 Active Member
    722
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    Hate to bust your bubble but most high power amps are wired directly to the battery ans have constant voltage applied. Now, when the audio system is off, there is minimal draw off the battery - say less than 0.1 amps. I'm thinking your amp may be drawing more than 0.1A static current or your normal playback is pulling the battery down faster than the inverter can keep it charged. For example, if you have a 500W amp that will draw nearly 40amps from the battery and the inverter is setup to push what the car will typically draw, say 25amps, then you're going to suck the battery down every time.
  3. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    There are probably 3 power wires
    Yellow wire (usually labeled Batt.) Is the battery wire goes directly to the + positive on the 12V Aux (starter) battery. This wire also supplies power to the radio when vehicle is off to store station presets, settings, and the clock.
    Red Wire (sometimes Orange) (usually labeled as Acc.) There are several ways to hook this wire up, anyway you decide it Needs to go to a power lead that turns off when the car is turned off. I would probably connect it to one of the 12V car lighter plugs if I wasn't using the factory radio wiring.
    Black wire is the Negative Ground. (usually labeled as ground or -) This wire needs to be bolted to a piece of metal attached to the chassis of the car, if you are unable to find a suitable spot run a wire of the same guage (thickness) as the power wires to the negative terminal of your battery (I prefer the spot where the battery bolts to the car usually about 6 inches or so from the battery on most cars.
    The amp also has three wires
    The Amp needs to be connected
    12v+ directly connected to the positive on the 12v positive on the battery
    Ground 12v- directly to the 12v Negative on the battery
    Remote wire to the Blue remote wire on the back of the radio, (if you do not have this connect it to the same wire you used for your Accessory (red wire) when hooking up your radio
  4. BubbaVO
    BubbaVO New Member
    53
    Philly
    Thanks MorpheusX and EZW1 for your posts. Perhaps this can clarify things further...
    I've got a Kenwood KSC-SW1 powered subwoofer and a Blaupunkt THA475 amp (450 watts of max power). I just want a clean detailed sound. Don't need the BOOM heard round the block.
    MorpheusX - if wired the way you suggest, will this take care of the draw down when the car is off?
    EZW1 - you've raised an interesting point about the use drawing down the power faster than the inverter can keep it charged while driving around and "cranking" the stereo. What are the solutions around that as I've read about other vehicles on this site whose power needs appear to be greater?
    Thanks again gentlemen.
  5. morpheusx
    1,555
    81
    Akron, OH
    Yes, because the radio will turn off if the car is turned off. If the car is on and you power off the radio it would also turn off the amp.
    Are you using an aftermarket in dash radio radio.
  6. EZW1
    EZW1 Active Member
    722
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    Not too much you can do. The typical alternator in a non-Prius has the capability to push out up to 80-100A for brief periods of time. I don't know the spec on the inverter charging the 12V battery, but I would suspect is was setup for the typical 12V load in the car - and that would be a worst-case scenario: headlights on, wipers running, A/C blower motor on high, and you're stopped at a light with your foot on the brakes. I would guess the number to be around 20-30A.
    Now consider your high power amp may peak at 42-45amps at the loudest passages with the audio cranked all the way up, its average is likely pulling 20-25A continuously off the battery.
    Your solution: keep the audio down to a reasonable level or parallel the Pri battery with a larger capacity one.
    Footnote: constantly sucking any battery down to where you've got to put it on a charger to bring it back up will shorten its life.
  7. BubbaVO
    BubbaVO New Member
    53
    Philly
    MorpheusX - I'm using the stock radio.
    EZW1 - Would a audio capacitor help control the drain on the battery? Assuming Morpheus' idea is in place, does the capacitor store electricity like a battery or is it constantly drawing power to provide energy in bursts when needed?
  8. morpheusx
    1,555
    81
    Akron, OH
    stock radio changes quite a bit of what I posted above.
    Completely ignore it, it was for a head unit and amp.
    Here is what you want to do, and this is how I have my amp set up. Its a 4 channel 600W RMS amp, I transplanted it myself over a year and a half ago (about 35,000 miles ago) and have never once had to get jumped.
    12v+ Needs to go directly to the 12v + Positive of the battery, (make sure you have a 30A fuse in this power line closer to the battery is preferred and a nice thick guage of wire that will match the power demands of your amp)
    the Ground (Negative 12v-) I chose to connect mine right next to the small Auxillary battery where the negative cable from the battery connects to the chassis of the car.
    the remote turn on (this is where you are killing your battery)
    this needs to connect to something that turns off when you turn off the car. I connected mine directly to the fuse box, initially I was going to use the car lighters, but ended up choosing to connect to the fuse for the rear wiper. (they sell in autoparts stores a fuse that has a wire coming out that makes this easy)
  9. direstraits71
    direstraits71 Member
    367
    64
    Central Coast California
    The Prius 12 volt battery is charged by a dc-dc converter that takes the traction battery voltage of approximately 200 volts dc and converts it to about 14 volts dc which keeps the 12 volt battery charged and also runs all the 12 volt equipment in the car. The Prius in ready mode will keep the traction battery and 12 volt battery fully charged automatically as long as you have gas in the tank. According to this thread the dc dc converter in the Prius should be able to output about 75 amps at 12 volts for a total capacity of 12*75 = 900 watts:
    http://priuschat.com/forums/prius-technical-discussion/54601-dc-dc-converter-output-limit.html
    If you only run your amplifier/equipment when the car is in the ready mode and it requires less than say 50 amps, the dc-dc converter should be able to run your equipment, the car, and still charge the 12 volt battery. In the ready mode you will be running your equipment and the 12 volt equipment in the car off the power provided by the dc-dc converter.
    As was stated before you will have to make sure the amplifier is really off and not drawing any current when you turn off the car and leave the ready mode. Additionally you cannot run the car in accessory or ign on mode for very long if your amplifier is on as the Prius dc dc converter doesn't operate in these modes. In these modes the Prius is running completely off the 12 volt battery which as you have discovered, has a pretty small energy capacity.
    If you mean an audio capacitor is a capacitor placed across the 12 volt input to your equipment, such a capacitor will limit the current peaks drawn from your 12 volt system, but will not change the energy available from the battery. In other words your equipment will still run down the battery just as fast if you're not running in the ready mode.
    And as stated above, fuse your wiring at the 12 volt source (battery) and run your power wiring directly to the battery through that fuse.
  10. maseace
    maseace Prius enthusiast
    191
    Poulsbo, WA
  11. EZW1
    EZW1 Active Member
    722
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    BubbaVO, as others have stated above, adding a cpacaitor will not change anything. The capacitor might provide for an increase in instantaneous surges but it will do nothing for the long run. Remember, those 45A you're pulling for your amp has to come from somewhere, and that is your battery.
    Others above have provided some very good input. If you can get ahold of an ammeter from someone, try to measure the current draw from both of your amp inputs: 12V main and 12V remote. NOTE: If you've wired the 12 remote directly to the battery, then your amp is on all the time and don't try to measure the 12V main or you'll likely blow the ammeter. Disconnect the 12V remote BEFORE you measure the 12V main.
    Good luck and keep us posted here of your findings.
  12. BubbaVO
    BubbaVO New Member
    53
    Philly
    Great suggestions! Thanks so much.
  13. BubbaVO
    BubbaVO New Member
    53
    Philly
    Good news. The dealer replaced the 12v battery under warranty. I wish they would have months ago, but at least things ended up well.
    Thanks again.
  14. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    They have given you good advice. :)
    You shouldn't be having charging issues even with a "large" amplifier (which yours is not). I've had 2 amplifiers hooked up for some time now and never had an issue pop up althought I cannot verify the life expectancy change due to such large current draw on the 12v battery and the associated components used to keep it charged.
    My amplifers have a max current draw of:
    Diamond Audio D61500.1 1500w rms (160amps)
    Diamond Audio D9800.2 400w rms (80amps)
    It is doubtful the Prius system can supply the current I need to run these amps correctly but everything sounds great, the system runs at an appropriate temperature, the headlights don't dim (lol), and I've had no issues with the car. Does that mean I will never have a problem? Who knows. :)
  15. PaulthePriusAddict
    PaulthePriusAddict Junior Member
    26
    San jose
    Using low profile fuse splitter, can you put fuse box cap back on?
    I drive a Gen 2, it doesn’t look like I can put the lid back on
