Horn Constantly Sounding
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Roscorsese, Nov 9, 2021.
  1. Roscorsese
    Roscorsese New Member
    London
    Hi all,
    First time posting. I have a 2010 Prius, roughly 150k miles. Saturday night after having just returned from a short drive I was sitting in the car, parked, but with the car still running. Suddenly the horn starting blaring. Not honking, sounding constantly at full volume (it was 11pm so I woke up the whole street). It sounded constantly like this until I figured out how to unplug the fuse box. I could not simply turn the car off to stop the problem.
    Things I have done since:
    • I checked the fuse box. It was not the alarm system as I removed that fuse and plugged the box back in only to have the horn immediately begin sounding again.
    • I removed the horn fuse and that stopped the problem, however the horn fuse is connected with several other systems so I can't just remove only that fuse. The fuse didn't appear to be blown, but maybe I don't know what I'm looking at.
    • I opened the steering wheel (safely with the battery disconnected) and checked that the plastic tabs that you depress to make contact with the horn were all still in place.
    My current solution is that I have directly disconnected the horns at the horn itself, and now I can plug everything back in and drive just without being able to use the horn.
    Mechanic (without having taken anything apart to check) thinks replacing the clock spring might fix the problem. It's a cheap replacement part aftermarket so I'm not too bothered by trying that solution, but does anyone else have any ideas here?
    Additional details: Earlier that same day, we visited friends outside of the city and ended up needing to drive down a bumpy and muddy path. The brakes have been squealing at low speeds since then.
  2. jimontheocean
    jimontheocean Member
    53
    46
    SC
    I know this is an old post, but did you ever find a solution. I just had this happen to me.
    I checked the steering wheel horn mechanism and it is fine.
    Clockspring replaced and it still happens.
    douglasjre likes this.
  3. Eddie25
    Eddie25 Active Member
    503
    213
    MI
    Check to see if the horn switch circuit is getting grounded out somewhere. If you can find any of those connectors and disconnect them you could narrow it down. 1G might be a pain to get to, I feel like it's in the integration relay, but that's what I'd be trying to get to first (I've never done it). If pin 18 is grounded towards the steering wheel then it's probably the clock spring or switch and if it's grounded towards the integration relay then it's probably the integration relay.
    How did you test the switch?
  4. gmyatko
    gmyatko Junior Member
    Palm Bay, Fl.
    2014 Prius v wagon
    Thanks Eddie,
    Now I need to find the "Integration Relay".
  5. Eddie25
    503
    213
    MI
    It's in the under-hood fuse box.
    I'm not sure where connector 1G is, but I imagine it's somewhere around there as well.
  6. ChapmanF
    19,056
  7. hamzeh sharif
    hamzeh sharif New Member
    jordan
    hey , did you solve the problem ? .
    I have the same with my car , changed the integration relay 2 times and the horn get running after this , I noticed this happen at the second time when I came into a street bump with a high speed , and the third time (after change the second integration ) when i only open the lights its happen . know one of the electrician knows how to do anything here in jordan .
