Horn honks intermittently
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Senior Bob, May 22, 2018.
  1. Senior Bob
    Senior Bob Junior Member
    Pleasanton, CA
    I am somewhat new to this forum but I didn't see this problem posted before. I have a 2008 Prius in top shape, low mileage (only 70,000), but has in the last year developed an intermittent honking problem. I have a video I took while this was going on, if I can post it I will. This started when we were in Madras, OR last summer for the eclipse. While driving back in slow traffic and in hot conditions the horn started to beep intermittently - short gentle beeps from 3 to 7 or so in a row. Folks would stare since it sounds like we are signaling impatience or something else. The problem settled down for a while, then resurfaced recently after we had stored the car for a few months and asked someone to drive it occasionally to keep the battery charged. The battery ran down about a month before we returned, and while charging up the car there were several episodes of loud horn honking, notably when the key was in the ignition and the door closed. Then after the car was charged up and after we had the battery checked out at the Toyota dealer, the car started the intermittent beeping again, every couple miles or so, while driving. It is very annoying to us and other drivers in traffic. Again we went to the dealer, but they could not figure anything to do, except they found "alarm was turned off in custom settings, turned alarm back on". This actually doesn't make sense that this would stop an alarm, but for a few days the horn stopped honking. Now however it is back with us full force. Very annoying and frustrating. We have also heard the horn beep like this when turning the car on. Appreciate any ideas on this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    How old is the 12 volt battery?
    What is the reading of the 12 volt battery when it is at rest overnight?
    Have you looked in the battery area to see if there is any water there or at the physical condition of the battery?
    SFO likes this.
  3. Senior Bob
    Pleasanton, CA
    I don't have the reading, but I did have the 12 volt battery in the back checked at a garage, there was no problem.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Replace the 12 volt battery. The fact it ran down and was dead for a month killled it.
    If you had a voltmeter you would be able to clearly see it’s bad. You may also notice it’s throwing a big red triangle on the dash when you boot the car up. It only shows it for a second. That’s the car seeing the 12 volt battery dip below 11.3 volts upon boot.
    The fact the horn going off while charging up the dead battery should have been a hint.
