Horn Only Works With Steering Wheel Turned
Discussion in 'Gen 3 Prius Technical Discussion' started by osher, Jun 1, 2018.
  1. osher
    osher Junior Member
    israel
    Hello everyone
    First I am glad to join that wonderful forums. So thanks for all the info and tips.
    As my subject says what i did is I remove my steering wheel and got to the clock spring got the part number: 89245-74010
    Now my toyota dealer ask me for new part including the work for like 430$
    I found the part for like 10$ around the internet... so my question is there is any kind of diffrent? To be honest I'm little afraid from cheap part that handle my airbag connector
    Please advise.
    Thank you, Osher.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    Welcome to your first post on Prius Chat (y).
    The cheap clock springs offer mixed success:(.
    I’d go with the genuine part, but shop around to ensure you get a good price on the part;).
    Good luck and keep us posted (y).
  3. analoggirl
    analoggirl Member
    131
    26
    Asheville, NC
    Hi Osher,
    Have you found a fix for the horn? The horn on my 2011 stopped working and the dealership is telling me it costs $800 for the horn/airbag assembly!? The horn worked when the steering wheel was turned to the left. Now today the radio doesn't turn on with the regular knob but if I press one of the station selectors the radio turns on and off, all of them to the same station. There seems to be some electrical short somewhere. The Toyota dealership near me is a scam and I'm lost as to what to do. What did you end up finding out/doing? Thanks!
  4. ChapmanF
    18,870
    Hi ,
    Though I'm not Osher, you've got a common problem, nearly always meaning you need to replace the "spiral cable" in your steering column, often also called "clock spring" because of what it looks like.
    The part itself may be a few hundred dollars at the dealer. Replacement isn't hard if you can use a torque wrench and have access to a steering wheel puller, which a local auto parts store may have for you to borrow. Fifteen dollars'll get you in to the repair manual at techinfo.toyota.com to see the procedure. Be sure the part about making sure the airbags have no power before taking the wheel apart is clear to you.
    Some people report they can manhandle or beat the wheel off the shaft without the puller. I'd still borrow the puller.
    There are non-Toyota spiral cables on eBay for much cheaper, but for as infrequently as it wears out, I'd spend the money on the real one and be done with it for a good while.
    -Chap
  5. analoggirl
    analoggirl Member
    131
    26
    Asheville, NC
    Thanks ChapmanF! The dealership says the part itself is $800. The service itself isn't that much. Is there a way to replace just the cable and not the entire assembly? They tell me I can't just purchase the cable from them, I need the entire airbag/cable assembly. And then today the radio is shorting out. It seems there is a bigger issue or maybe they didn't seat the assembly back it well enough? What do you say? Thanks!
  6. Mendel Leisk
    42,164
