Horns replaced with FIAMM 74100 El Grande
Discussion in 'Gen 4 Prius Main Forum' started by Jon Watkins, Feb 11, 2018.
  1. Jon Watkins
    Jon Watkins Active Member
    127
    113
    Bluffton SC
    The meep meep stock horn on my 17 three that I bought a couple of weeks ago was just plain dangerous. I bought the FIAMM 74100 El Grande on Amazon for $22 as a replacement. It took all of 15 mins to change the horns.
    Remove the 5 connector pins from the plastic radiator top cover. The two stock horns are under the plastic radiator cover. Pull up the center of the connector pins and pull the connector pins out. Unplug the power wire connector from the stock horns. Squeeze the connector and pull it off. The arm part that holds the stock horns to the body has two bolts in it. Remove only the bottom bolt. The new horns come with a new arm piece to hold the horns onto the body. The 2 holes in this arm piece are different sizes. The larger hole is where the bolt that holds the horn arm piece onto the body goes. The smaller hole goes on the post in the center of the horn. Secure the arm to the horn with the nut included in the package. Bolt the new arm onto the body with the bolt that you removed earlier. Plug the power connector onto the spade connector on the horn. Angle the horns so they point down as much as possible so any rain that gets into them can drain out. Make sure the power connector wire has some slack in it. Give a final tightening to the center nut. DO NOT tighten this nut completely yet so you can rotate the horn around to its final position later. DO NOT overtighten the nut that holds the new arm to the new horn or you wil crack the plastic horn housing! You do not need to install the relay included with the new horns.
    Blow the horn to make sure all is good. This FIAMM horn is not incredibly loud but everone will now hear it when you need to make your presence on the road known. Enjoy.
  2. hill
    8,302
    REALLY ? , the Department of Transportation doesn't have ultimate say as to whether a horn is loud & shrill enough?? ... never minding our 2011 leaf is barely over ½ your car's horn's volume? Just saying .. could be much worse. So maybe just buy an aftermarket horn if yours isnt satisfying?
  3. Prodigyplace
    11,709
    11,324
    Central Virginia
    That is exactly what he did! He bought and installed aftermarket horns.They are even listed in the thread title.
  4. hill
    8,302
    Several folks here, when they are unsatisfied w/ their parking lights, dome lights, horn, stock tires, Etc publish pictures or video of what they do, in case someone else wants to do the same thing. Our drl's are aftermarket - & so aftet changing 'em out - now they're LEDs, but never opted for publishing that we thought stock ones were "plain dangerous". Just saying, seemed a tad dramatic.... that's all.
    robsnyder20, RCO and Prodigyplace like this.
  5. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,585
    near Brisbane, Australia
    If it's "just plain dangerous", you should report it to the Department of Transportation or whoever authorises the vehicle's compliance with design rules.
  6. RCO
    RCO Senior Member
    3,709
    5,184
    Cornwall
    It's what's known as hyperbole.
    My dictionary describes it thus:-
    hyperbole noun [ U ]
    UK /haɪˈpɜː.bəl.i/ US /haɪˈpɝː.bəl.i/ formal
    speaking or writing that makes someone or somethingsound bigger, better, more, etc. than they are:
    The blurb on the back of the book was full of the usual hyperbole - "enthralling", "fascinating", and so on.
  7. robsnyder20
    robsnyder20 Active Member
    374
    301
    SW Florida USA
    Good Write up Jon. Great information for someone maybe wanting to swap with a lexus or another louder horn or just replace with the same horn shall theirs ever break. Thanks for the info.
