Horrible racked noise at start up
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Erin Riel, Jan 16, 2018.
  1. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    Seems like the knocking is caused by moisture, ie when you start the car to move it and shut it off then without letting it warm up. The next time, the water that's collected in the intake makes it sound like a diesel. That's my theory anyway. Otherwise, why would Toyota redesign the intake? And every time I've gotten the noise, it was from that exact scenario
    iPhone ?
  2. Prodigyplace
    12,720
    11,852
    Central Virginia
    The current theory is condensation & oil. Those liquids do not compress as well as the fuel, creating the knock
  3. trentofdestiny
    1,104
    227
    Harrisburg, PA
    I don't understand why oil would have anything to do with it unless it's coming from blowby from worn piston rings
    iPhone ?
  4. Prodigyplace
    12,720
    11,852
    Central Virginia
    From PCV valve, I believe
    Bay Stater and Mendel Leisk like this.
  5. trentofdestiny
    1,104
    227
    Harrisburg, PA
    Ahh, I see. Again, IMO shouldn't be a problem unless there is excessive blow-by. I guess it combines with the moisture though and ends up being one and the same fluid.
    iPhone ?
    Prodigyplace likes this.
  6. danlatu
    danlatu Senior Member
    533
    1,367
    maryland
    I have not cleaned the egr system at all on our 2010 prius and have had an occ in place since 80k with 117k currently. The 2011 has had a rebuilt engine with complete egr system, intake plenum cleaning and occ done since 297k with 306k currently. Both cars run smooth. Both prius' trap more water in the winter with a small mix of oil and fuel in the occ. In the warmer weather I see more oil. Either way I see it, I do not want any of this contaminant in the intake plenum. I do not think it will be necessary to clean the egr system with 68k and just install an occ.
  7. Beachbummm
    Beachbummm Senior Member
    1,160
    393
    you forgot to ask how old the 12 volt is :)
  8. bisco
    52,878
    i was going to, but disabused myself of the notion.
    Mendel Leisk, scona and Prodigyplace like this.
  9. cipsaz187
    cipsaz187 Member
    150
    43
    I have experienced this a few days ago. It was a cold morning, and I drove short distance, about 10min. Normal operational as usual. Got back to the car after an hour and bah, the diesel noise was present and it lasted up to 10sec. I’ve never gotten this noise before, so it was definitely weird.
