Hose hang under engine
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Robmoo, Dec 2, 2019.
  1. Robmoo
    Robmoo Junior Member
    55
    2024 Prius
    As I was driving home from work today I heard several banging sounds. At the time I figured that it was a backfire from the truck several car lengths ahead. When I got home I looked under the vehicle and there was a hose hanging down. It looks like either a windshield washing fluid hose or a vacuum hose. With a vacuum hose missing I'd expect a check engine light. Do cars now-a-days even use vacuum hoses? It was hanging out a small hole in the under panel. I pulled on it gently and it came out. WTH? WIN_20191202_18_50_20_Pro.jpg WIN_20191202_18_50_26_Pro.jpg WIN_20191202_18_50_38_Pro.jpg
    52,804
    was it under the engine bay?
  3. Robmoo
    55
    2024 Prius
    Was towards the back.
    52,804
    no dash lights? car runs fine? rear washer works?
  5. rjparker
    rjparker Tu Humilde Sirviente
    11,040
    6,920
    Texas Hill Country
    My guess its something you picked up off the road from someone else. Looks like a diy tape job holding it in.
    Raytheeagle and Mendel Leisk like this.
  6. Mendel Leisk
    42,298
    The one hose I can think of running from back of the car to front is venting the gas tank. That said, from the funky appearance, I think @rjparker's guess is more likely.
  7. Robmoo
    55
    2024 Prius
    Hopefully road debris that got caught it the under side of my car is all.
  8. Robmoo
    55
    2024 Prius
    The car runs fine. The hose must have been road debris.
  9. Fred_H
    Fred_H Misoversimplifier
    562
    488
    28
    Germany
    Perhaps the condensate drain tube from the air conditioning? Is there a wet spot on or under the carpet near the firewall?
  10. Fred_H
    562
    488
    28
    Germany
    12 Volt battery vent tube?
