Hot vs. cold oil levels
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Preeeus, Apr 23, 2019.
  1. Slider2732
    Slider2732 Member
    64
    66
    Arkansas
    Thanks for the fast answer.
    Am good at stalling around, so will do that :)
    Preeeus, Raytheeagle and Mendel Leisk like this.
  2. Preeeus
    Preeeus Member
    258
    60
    Thanks so much Mendel, and for posting the photos. (y)(y)(y)
    Not sure whether or not 8km is sufficient to really heat up the oil all the way. We may try doing a similar test after driving 30mi tomorrow. The only trouble is that traffic is so bad here, the engine will be shutting itself off a lot, which probably doesn't allow the oil to get very hot. Lucky if we average 20mph.
  3. Mendel Leisk
    42,347
    How far was the dealership where you had the test? If just a few miles, maybe we can rule out oil expansion, as a factor in skewing the test?
    I seem to recall you saying the fill oil was dispensed from a bulk tank? (In another thread?) That's definitely not in accordance with the TSB, which says to break open a sealed quart bottle, pour it in.
    Preeeus likes this.
  4. Preeeus
    Preeeus Member
    258
    60
    It was about an hour drive, mostly going 70-75mph.
    Not sure how the oil was dispensed. They didn't do it in front of us. Just speculating that it could have been from a bulk drum, since I think that's how they do oil changes. Not sure if Toyota even stocks 1 qt bottles for 0W20 in their service dept.
  5. Mendel Leisk
    42,347
    Parts should have bottled quarts. Service too, likely stocks both.
  6. Preeeus
    Preeeus Member
    258
    60
    Yes, parts almost certainly has quarts. Don't know about service. Not sure which they actually used, as service is likely more familiar with using the bulk drums.
    It's really, um, mysterious (and frustrating), how the dipstick was just above the bottom dipstick marker (when warm, after sitting for 5-10 minutes), and Toyota claimed it only took 1 qt to fill it above the top dipstick marker after they let it cool down for another 30+ minutes.
  7. Preeeus
    Preeeus Member
    258
    60
    @Mendel Leisk
    Maybe we should really warm up the engine by taking a drive to Northern Northern California. Or as you call it, Vancouver. :):ROFLMAO::):LOL::)
  8. Mendel Leisk
    42,347
    Up here service dept offers both bulk and bottled. And parts or service, it's basically one long counter, lol. I'm able to buy bulk 0W20 Toyota synth, but only because 0W20 is only available in synth. For 5W20 the bulk is conventional oil (which I also buy, for our daughter's Pilot), but if you want service to use synth 5W20, it'd be bottles. And, dealerships are all under one roof; it's definitely not a parts store on the side.
    I guess where I'm going: don't kid yourself they can't find a bottled quart, and with basically a full-blown engine rebuild on the line, the fill really should have been done in front of you. If that dipstick was 1/4" from the bottom mark, that's well over a quart low.
    Express your concerns to the service manager, citing the initial reading of the dipstick? Copy to Corporate Toyota? Some ammo to attach to an email:
    #28 Mendel Leisk, Apr 25, 2019
    Preeeus likes this.
  9. Preeeus
    Preeeus Member
    258
    60
    Thanks, Mendel for the document and for your ideas! We appreciate it very much! :)
  10. CR94
    CR94 Senior Member
    2,830
    1,243
    Northwestern S.C.
    They have no idea it will get hot!
  11. CR94
    CR94 Senior Member
    2,830
    1,243
    Northwestern S.C.
    I disagree too. When I change the oil and filter, 4.4 quarts brings the level only to about 3 or 4 mm below the full mark, checked cold. Hot, it might be closer.
  12. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    When changing my oil, I pull the drain plug, and go away. I come back in 5-10 minutes and look at the draining stream. If it’s still draining, I come back in another 5 minutes. If it has stopped, I put the plug back in. Same with the filter. Let them drain. It’s very hard to estimate .4 quarts from a 5 quart jug, but this last change, I added Lucas Low Vis Stabilizer. So I got 4 one quart bottles and the 12 oz bottle of Low Vis. It’s 13.4 oz for .4 quarts, so it’s pretty close. That puts me at the full mark hot. One thing I have noticed is that overnight, not driven, I am very slightly overfilled, due to drain back from the engine.
    Preeeus likes this.
  13. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    When the oil is hot, it’s all over the engine, coating the can shaft, valves, crankshaft. As the engine cools, this oil drains down into the sump. So reading oil when the engine is hot can give you varying results as the oil flows down into the sump.
    Worse, I’m sure you’ve all seen that it’s difficult to read the dipstick on a Prius, and if you re-insert and re-read the dipstick, it’s usually got oil all over it. I need to let the car sit for ten minutes or so before taking a dipstick reading.
    Gabe Benke likes this.
  14. Mendel Leisk
    42,347
    Pull the dipstick, and then wait ten minutes. When you reinsert and pull out the dipstick it'll have little or no excessive oil, much easier to read.
    The Prius dipstick and guide tube is a poor design, seems to draw oil up the guide tube when you pull the dipstick out. The protracted wait after withdrawing the dipstick allows time for that drawn-up oil in the guide tube to drain back down.
    Gabe Benke, CR94, Preeeus and 2 others like this.
  15. Salamander_King
    Salamander_King Senior Member
    11,024
    8,978
    New England
    Thanks for that tip. I always have a hard time reading an accurate oil level on my cars. I will try your method next time.
  16. Mendel Leisk
    42,347
    I can read it if I check right away, but it's hard, sometimes nigh impossible. Yeah, stall by checking tire pressures while you wait, something like that.
    Salamander_King likes this.
  17. OptimusPriustus
    OptimusPriustus Active Member
    338
    144
    Finland
    Engine is made of metal. It expands as well..
  18. OptimusPriustus
    338
    144
    Finland
    This is why cars with electrical oil level check do not give reading until cars have sit still couple hours. For shop purposes they often have a traditional dip stick hidden under the panels. So checking the level cold is the right way, with new cars it is the only way available..
