Hot Water Heater Timers
Discussion in 'Environmental Discussion' started by JSH, Feb 12, 2009.
  1. bisco
    52,862
    I have read that propane is more costly than oil per btu, but I don't know details.
    52,862
    has anyone looked into Mr. Cool DIY systems. I've been reading and YouTubing, but results seem mixed. I might be able to gear myself up for the simplest installation which would be our MBR. first floor, the outdoor unit would be directly below the indoor, 120v nearby.
    $2,000. for materials vs $7,000. pro istall, but I would have no service.
  3. fuzzy1
    10,710
    These mentioned ductless issues are not unique to minisplit heat pumps, but common to all types of un-ducted, zoned HVAC systems. My home was built with zoned electric resistance heat, no cooling, no ducts, a very common type in this region.
    The "poor conditioning in adjacent spaces" issue is more a winter than summer issue here. My building envelope upgrades have helped considerably, new code-compliant construction should be better still.
    Only very recently did AC adoption climb above 50% of housing units in some Western Washington counties, while others still remain slightly below 50%.
    Census Bureau Releases New Local Estimates of Air Conditioning Access
    https://www.seattletimes.com/seattle-news/data/king-countys-cooling-divide-new-data-maps-our-ac-haves-and-have-nots/
    I can't speak to dehumidification issues as I've never lived in a climate zone needing more than simple exhaust fans (ideally on programmable timers) next to water sources, such as bathrooms and laundry. Inland from here for probably over a thousand miles eastwards, they have the opposite problem of natural humidity being lower than desirable. Last month my spouse's doctor even recommended getting a humidifier to increase our home humidity. (I declined after asking for a numeric target, and received an answer that we already met.)
    #63 fuzzy1, Jun 27, 2026
    52,862
    i thought 50% was ideal. dehumidification is a big deal around here in summer, and humidification in winter, although our house with a boiler and radiators is more humid than our ild house with warm air.
    but the humidifier on that furnace was an ongoing maintenance problem
  5. bisco
    52,862
  6. John321
    John321 Senior Member
    1,536
    1,446
    Kentucky
    some friendly advice on Mr. Cool systems - look at the you tube reviews after the systems are a couple of years old.
  7. Leadfoot J. McCoalroller
    8,290
    7,805
    Pennsylvania
    2018 Prius c
    You can get all the big brands as DIY if you want.* I really like the Fujitsu we most recently installed. Our oldest one is a Lennox, probably wouldn't get that brand again.
    *There will probably be limits or even total exclusions on warranties
  8. rjparker
    rjparker Tu Humilde Sirviente
    11,116
    6,974
    Texas Hill Country
    Mr Cool with precharged line sets and quick connects on those lines force you to coil up excessive length. Typically its cooled vertically behind the condenser. This causes multiple undesirable oil traps.
    It would better to coil excess length horizontally, ideally in an attic. But no one does as it complicates the line set routing.
    I would get a minisplit (only for an addition or garage) that allowed brazed or pressed connections and size line lengths as needed.
    fuzzy1 and bisco like this.
  9. bisco
    52,862
    I might be able to use all of the 16', I'll have to measure it
  10. fuzzy1
    10,710
    From the Lowe's description page:
    "2-Year compressor and 1-year parts warranty when registered and when installed by a licensed professional"
    Seems awfully short.
    Seems low by today's standards. Though I'm still calibrated more to the old HSPF scale, not the newer lower-reading HSPF2 scale. And I seem to remember from somewhere that these lower figures are partly a consequence of the pre-charged lines of the DIY models. A traditional system where the lines must be vacuum pumped before charging were said to end up with less non-refrigerant air so performed better.
  11. rjparker
    11,116
    6,974
    Texas Hill Country
    Ten years warranty on a compressor and most parts is normal on products from Rheem. Others are 5 years these days. One year on labor covered by the installer. Most mainstream manufacturers will sell a comprehensive 10 years parts and labor warranty.
  12. Trollbait
    12,831
    The loss of the federal 30% tax credit is a big blow to adoption of such efficiency and carbon cutting improvements.
    Which is great for homes with forced air heat or central A/C already installed. Otherwise it is a much bigger and costlier job, and likely only worth considering if gutting the house.
    Mini-splits have their downsides, but there is a lot of houses out there with hydronic heating and no central air.
    Is that one the same or different than the units that fit in the ceiling?
    It is going to depend on the prices being compared, like there is an almost $2 difference between them right now. The price of propane is close to that of gasoline, while having roughly 30% less energy. Heating oil compares to diesel(essentially the same thing) in price with a little more energy than gasoline. There is more to consider for costs though.
    In comparable units, the propane one is likely more efficient in using its btus. Propane units are natural gas ones with a few different parts for handling the differences in the fuels. The oil one will also use electricity for the fuel pump. Which is balanced by tank costs. Pressure vessels going to cost more than a steel tank for liquids; leasing propane tanks is common. Siting requirements for a propane tank are stricter, which is why it is common for them to be installed away from the house.
  13. Leadfoot J. McCoalroller
    8,290
    7,805
    Pennsylvania
    2018 Prius c
    Different. You are probably thinking of the "ceiling cassette."
    The one we have is called the "Slim Duct" and it is packaged the same as a traditional air handler, but it has connections and control systems that are compatible with a minisplit system. One of our systems has one outdoor coil driving two indoor units- one is that slim duct air handler, and the other is a white wallmount in the next room.
    This was a great solution for our living room because there just wasn't a wall appropriate for a wallmount, given the arrangement of windows and fireplace. The duct unit can go under floor or over ceiling, the installers just have to put in a few feet of ductwork and cut a few vents as appropriate.
    Most minisplit manufacturers have an equivalent device.
    Here's an example.
    Trollbait likes this.
  14. Trollbait
    12,831
    Actually, the mini-cassette looks new to me. Might even be a a better fit for my situation, with smaller holes cut in plaster than the slim duct.Guessing more care for both needed for drainage than a wall unit.
    Really, I'm looking for ways to get cooling to the upstairs bathroom while keeping the outside unit on the opposite side of house. Sucking it up, and leaving it hot in the summer is looking like the only reasonable option for this:p
  15. Leadfoot J. McCoalroller
    8,290
    7,805
    Pennsylvania
    2018 Prius c
    I can understand that. We do not condition the air in our upstairs bathroom or hallway, they just get a little spillover effect from the three bedrooms up there.
    Doing it over again from scratch, I would probably use wallmounts in the larger two of the bedrooms and a slim-duct in the attic crawlspace over the smallest, with short ducts extending to the bathroom and hallway to give them a little something. But that upstairs system was the first one we installed, most of 10 years ago. Learned a lot since.
    We also lack conditioning in the laundry room and the downstairs bathroom. The first was a deliberate choice- we tend to close that room off, crack a window and let the dryer pull in outside air and vent it back out again. I'm due to replace the vent fan in the bathroom and I'm likely to install one that adds a heat mode. Panasonic makes fantastic ones that are extremely quiet, none of that "Broan groan" to be heard.
  16. bisco
    52,862
    ai says the coils should be horizontal if above the unit:
  17. bisco
    52,862
    not sure about how this would look: 'from reddit, avoiding the coil':
    I did neither. I zigzagged the lines down the outside wall ensuring a downslope.
  18. fuzzy1
    10,710
    I replaced my first noisy beast bath fan, too loud for sleeping, with a Panasonic Whisper-series 24 years ago. It was a huge improvement. Later putting in a programmable fan timer (replacing a single-cycle timer) greatly helped with moisture management. It is now about time to pull it out for cleaning again, something I do about every four or five years.
    Didn't do the same to the little-used other bath's fan until years later.
    After some bad wildfire smoke seasons here, when people in homes without central air filters were cobbling together furnace filters and box fans to improve their indoor air, I decided to extend that idea to make some permanent air filters, running full-time year-round. The common room filter products seemed too noisy for full-time use. I took several of the quietest and most energy efficient Panasonic bath fans available (though expensive), built a plywood box around them, with one face holding a 20"x20" MERV 13-14 furnace filter, and put one each in the master bedroom, dining room, and living room. They greatly helped during the severe smoke summers, and have considerably reduced household dust. Sitting on the floor with exhaust pointed up, they also produce significant vertical mixing, reducing temperature stratification in rooms (or seasons) without an operating minisplit heat pump.
    #78 fuzzy1, Jun 28, 2026
  19. bisco
    52,862
    this gets the creative juices flowing:
    EG4 Solar 12K BTU Hybrid Minisplit Kit 1.64KW Solar Panels
    $2,256.99
  20. rjparker
    11,116
    6,974
    Texas Hill Country
    Its interesting that down south we have conditioning in all rooms, hallways, baths, walkin closets and laundry rooms by default in virtually all homes built since the mid sixties.
    Shortly after spec houses all had ac, we had air conditioned baseball and football stadiums. A Six Flags style amusement park next to the Astrodome had covered outside waiting lines with ac blowing on the customers. AC transformed the south.
    Almost all southern cities and adjacent suburbs have cheap natural gas which is used for heating in an integrated air handler designed for ac duct systems.
    For those of us in more rural locations, expensive propane is a heating option but heat pumps with supplemental heat strips are far less costly to operate. Heat pumps have been common with the same upfront costs as straight ac since the 80's.
    People who want better insist on separate systems for each floor of a two story house. For the last 25 years many specify extra dehumification strategies controlled by the thermostat.
    Almost all are traditional split systems with gravity fed drain lines. Minisplits might be used for an addition, shop or a garage, all higher end options.
    Quite a few hvac tradesmen have built quite lucrative year round operations regardless of their education or status as a small one man operation or as a medium to large scale employer. Prosperous enough that private equity investors are starting to buy them up.
    #80 rjparker, Jun 28, 2026
