Hot Weather Driving?
Discussion in 'Gen 2 Prius Main Forum' started by Taye Marshall, Jun 27, 2013.
  1. Taye Marshall
    Taye Marshall New Member
    I am going to be driving from San Jose, Ca to Austin, Tx on Aug 1st. Is there any reason I should avoid the fast route of going through S. Arizona. It might be 110 degrees.
  2. jdenenberg
    jdenenberg EE Professor
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Just use the AC to keep the HV Battery (and you) cool.
    JeffD
    xpcman likes this.
  3. Patrick Wong
    18,210
    6,517
    I assume you are taking I-5 south to I-10 east in Los Angeles. No reason to avoid the route. I am living with that high temp on a daily basis during the summer...
    Make sure that your engine compartment fluids are correct and that your tires are properly inflated and have sufficient tread depth, prior to starting your trip.
    Mochabuzz and krmcg like this.
  4. jefe
    jefe Member
    169
    50
    Cary, NC
    DON'T DO IT!! YOUR BATTERY WILL EXPLODE!!!
    Nah.. there are probably good reasons to avoid S. Arizona but it has nothing to do with your Prius. haven't you seen Breaking Bad?
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Breaking bad.....best tv ever. Jonesing for new bad....
  6. jefe
    jefe Member
    169
    50
    Cary, NC
    I'm only through whatever is on Netflix. So, that scene.. at the end. with the guy.. and the thing.. :eek:
  7. kammssss
    kammssss Member
    287
    86
    SoCal
    Just crank up your AC. I just arrived in Vegas from Los Angeles. It was 102-113F throughout the 15 freeway. My AC was set on medium/75 degrees, and there was no battery fatigue, not even on the 16mile climb of death after Baker. Car was traveling 65-70 MPH. When the HV battery is cool, nothing can stop the mighty Prius, not even high temperature and 239k on the engine...love this car.
