household A/C from J1772?
Discussion in 'Prime Plug-in Charging' started by nusrat, Aug 14, 2017.
  1. nusrat
    nusrat New Member
    Southwestern-most Connecticut
    Is there any way to, for example, power an A/C vacuum to clean my car while at a charging station?
    52,792
    welcome!
    nope.
  3. nusrat
    nusrat New Member
    As the psychotherapists say, "Can you say more?" Is there some fundamental technical reason that some kind of adapter / converter to do this couldn't practically be devised?
    52,792
    i would say that nothing is impossible. how much time/money do you want to invest in vacuuming your car?:)
    PrimeDan and mercat68 like this.
  5. nusrat
    nusrat New Member
    I meant... I spent a while googling to see if something like this already exists, but found nothing. So I'm wondering if searching for it is a waste of time -- for example, if there's some technological or economic bar which might explain why it isn't made by anyone. After all, most household electrical items are 15 amps / 1500 watts or less. So, why couldn't some combination of transformer / inverter / rectifier in a single gadget do this?
  6. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  7. drysider
    drysider Active Member
    823
    336
    Liberty Lake WA
    You can hook an inverter up to the 12v battery and, leaving the car in Ready Mode, get 800-1000 watts output. The J plug provides energy to a charger, which then charges the battery.There is no reverse path from the battery through the charger. I saw a J plug with a 110v outlet on it somewhere on the internet, but it may have been faked. There are inverters available that will connect directly to the HV battery. Google is your friend. Remember to leave the car in Ready Mode if you go the 12v route.
  8. drysider
    823
    336
    Liberty Lake WA
    This is the best solution. Putting a 110v outlet at the charging pedestal. I would have assumed that this is standard procedure...I guess not.
  9. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I was surprised how rare it is.
  10. nusrat
    nusrat New Member
    Yes, but I was looking for something which would handle all the interfacing needed to be able to plug-in to a public station. Sorry, should have been more specific in my OP.
  11. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I can only offer what is doable, sorry. A L1 charger will have 120v, but an L2 charger will not.
    #11 JimboPalmer, Aug 15, 2017
  12. nusrat
    nusrat New Member
    I know I'm starting to sound like a "princess" here, but I was hoping to avoid needing to mess with the battery. I already have an inverter, but it maxes at 400w, and I would have liked to be able to use 1200-1500w devices. Oh, well, unrealistic me....
  13. drysider
    823
    336
    Liberty Lake WA
    The only way to get that much energy out is to interface with the HV battery. It is not hugely difficult, just expensive. How about a small generator?
  14. 3PriusMike
    3,101
    2,421
    Silicon Valley
    Yes, there is.
    Some (not all) ChargePoint stations have both an L1 and L2 charger in the same pedestal. The L1 is just a (locking) cover over a regular 110v outlet. When you tap your card the L2 cable is unlocked and so is the cover hiding the L1 outlet. But I don't know if the relays for both will stay closed unless you tap another valid card.
    And, of course even if you have to pay, this is very economical in many cases. Places where you have to insert quarters to use a vacuum only give you 5 minutes or so for a dollar or two. With the CP station you get a whole hour! You just need to bring your own vacuum.
    These stations are pretty rare now since most new ones I've seen have two L2 cords.
    Mike
    Team ChargePoint likes this.
  15. bwilson4web
    16,515
    Dyson has a number of battery powered vacuum cleaners. If you feel compelled to vacuum when charging visit us:
    9011 Randall Rd,
    Huntsville, AL​
    #15 bwilson4web, Aug 16, 2017
  16. Prodigyplace
    12,710
    11,848
    Central Virginia
    I thought Mr. Dyson was in the UK... <confused>
  17. rjparker
    rjparker Tu Humilde Sirviente
    11,027
    6,916
    Texas Hill Country
    A 1500 w inverter run off of a 12v battery takes over 110 amps. A huge number which also requires very large diameter cables on the 12v side, especially for continuous duty.
