HOV stickers almost gone, & CA is almost out of CARB $$ too for PHEVs.
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by DianneWhitmire, Mar 17, 2014.
  1. DianneWhitmire
    DianneWhitmire High PRIUStess
    4,062
    1,123
    64
    Laguna Niguel, CA
    As to the $1500 CA state refund, you get it prorated.
    It's no secret that I have 45K on my 2012 (which I still love) but I also now commute in a 2013 Rav4 EV. I've been holding back selling my PHEV because once the HOV stickers are gone, the value of my car shoots up a bunch. How much, who knows yet. But it will certainly make any prorated CA $1500 bucks "give back" of what $750? ... will make it look like a drop in the bucket! :p
  2. bilofsky
    bilofsky Privolting Member
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    Well, you did yesterday.
    But today's another day. What else do you know? ;)
  3. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    Technically, it says "new" stickers may be issued to holders of any of the original 40K stickers. The stickers are made to be used only once, and while not impossible to remove in one piece if you're careful, the adhesive is history, so they're not "transferable" in the usual sense of the word. However, I'm wondering if they are saving some of the 40K for this purpose, or will they make more as needed? I only use two on my car, but otherwise I would have already had to apply for new ones following an accident last year, so I am wondering......
  4. jopa82
    jopa82 Junior Member
    They will make more past 40000 for replacements.
    I hope you saved the old stickers after your accident. If you ever need to apply for replacements, you need to submit all four old stickers/pieces with the application.
    iPhone ?
  5. srl99
    srl99 Member
    113
    23
    2014 Prius Plug-in
    Nothing good comes from smoking PG&E bills. $1/gallon equivalent?!? Per the Energy Dep't there's 33.8 kWH equivalent in a gallon of dino. Even at PG&E's mythical 10c/kWH, and using CPUC "regulated" math, that comes out to $3.38, no?
  6. wjtracy
    wjtracy Senior Member
    11,365
    3,608
    Northern VA (NoVA)
    Somewhere around 24 cents/kwhr is break-even cost with gasoline refill say on a Prius.
    So 10 cent/kwhr would be less than half of cost at pump. But most people paying more than 10 cent/kwhr especially in CA. Other parts of country EV/PHEV can save money on refill costs.
  7. bilofsky
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    I was a bit low. On PG&E's E-6 time-of-use rate, baseline off-peak usage is about 10 cents. With my solar panels I'm often in that band. I get about 3.5 mi/kWh, so at 50 mpg for gas that would come to $1.43 a gallon-equivalent. I'm actually on an older E-7 rate, so I pay $1.21 per gallon-equivalent.
    In either case, I'm saving a bundle compared to dead dinosaurs.
    Drifting further OT, in July PG&E will widen its lower rate bands from 130% of baseline to 200% of baseline, a sop to Central Valley air-conditioning users which will also benefit plug-in owners.
  8. rogerv
    1,639
    317
  9. rogerv
    1,639
    317
    For some reason my reply posted as part of the quoted post to which I was replying. ??
