how about that? six minutes!
Discussion in 'Prime Main Forum (2017-2022)' started by priuscatprimeguy, Oct 4, 2017.
  1. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
  2. huskers
    huskers Senior Member
    2,548
    2,488
    Nebraska
    That would be a game changer.
  3. benkhanobi
    benkhanobi Member
    123
    50
    SW Florida
    It doesn't make sense- a Chevy Volt uses about 10Kw of it's battery storage for 50 miles of range- 4x that =40kw for 200 miles. assuming 230volt charging, then E x I = P, so , 230 volts x 173 amps = 40Kw, but wait that is for one hour, so something would have to be 10X greater 6min x 10= 60 min
    no way could you have 1730 amps going into a battery in 6 minutes from a house charger-- nope, it's a news story, but not reality
  4. Washingtonian
    Washingtonian Senior Member
    726
    621
    Time to sell your oil company stock!
    priuscatprimeguy likes this.
  5. Alan Winston
    Alan Winston Junior Member
    38
    30
    Seattle
    This would need to be a fast-DC charger, ala Tesla's supercharger, not a home charger (unless the home charger had a huge capacitor bank to store up them little electrons in bulk until it came time to shove them all out fast).
    But the home model is for charging overnight, and doesn't need six minute fast charging. Six minute charging is for highway trips, commercial vehicles, and for people without a charger at home. The gas station model, without the underground tanks (though maybe with underground capacitor banks for when all charging stations are sucking electrons at once).
    I wonder if in addition to hooking up the electrical charger, you would also hook to up a high-speed coolant circuit. A new global warming fear: battery recharging.
  6. priuscatprimeguy
    2,730
    2,640
    funny story......I got some paper work from Texas about a month ago, turns out a relative from 1910 related to my grandfather on my mother's side owned some 20 acres of land in Texas which has oil on it and me, my son, my sister and a cousin (grandfather's brother had a son) are all heirs to that 20 acres. So far I have received about $600.00 and now another guy from a royalties company wants to buy out my interest in the 20 acres of land.:p oh, the irony:LOL::ROFLMAO:
  7. huskers
    2,548
    2,488
    Nebraska
    So you are an oil baron. (J R Priuscatprimeguy)
  8. bisco
    52,807
    this new battery will start showing up in cars around 2030, i'm keeping my pip until then.
  9. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    6 minute swap would be on par with pumping gas. Batteries are just a stop gap. Little Bush's H2 fueled cars will be here in less than 2 years as part of the new hydrogen economy....
  10. priuscatprimeguy
    2,730
    2,640
    just a tiny smidgen:rolleyes:
  11. bwilson4web
    16,520
    Ok, so let's play what this has to do with the Prime:
    • 25kWh -> 100 miles
    We'll be conservative and assume the same 6 minutes for 25kWh for just 100 miles. This means we need 250kW for 6 minutes:
    volts amps
    1 250kV 1A
    2 125kV 2A
    3 50kV 5A
    4 10kV 25A
    5 5kV 50A
    6 1kV 250A
    7 500V 500A
    So what happens is a tradeoff between insulation size and wire gauge. Did I mention adding a 250kW load could be considered ... problematical.
  12. bwilson4web
    16,520
    So let's assume that the Prius Prime with these new wonder-batteries needs 500V to drive the motor. The ideal situation would be to have 20, 500V strings. Put the all in series and 10kV at 25A would work great. Then put them all in parallel and have a nice day.
    #12 bwilson4web, Oct 5, 2017
  13. bwilson4web
    16,520
    Personally I think the answer are liquid reactant batteries. Not a high-pressure gas like hydrogen although I am OK with liquids that can be reduced to hydrogen. But there are more chemistries available than hydrogen to carry energy.
  14. bisco
    52,807
    we need underground charging, where you simply pull onto a pad, and the high voltage creates an exciting experience for all.
    Trollbait and priuscatprimeguy like this.
  15. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Bolt = 60kWh and 238 miles of range. Charging that to 90% in 6 minutes will require 540kW.
    Normally, 540kW is provided by a 3-phase AC transformer running at 480V and 650A.
    This would obviously be using an external DC fast charger. CCS is specified for up to 200kW with expansion to 350kW in the future.
  16. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    670
    269
    Dodge Co. Wisconsin
    2017 Prius v wagon
    I would be more concerned on heat dissipation from the higher amps required to charge that fast.
  17. bwilson4web
    16,520
    When we get in the range of 500V, spark gap risk becomes important. Again, returning to our Prius Prime with the wonder battery.
    In perfect conditions a spark takes 3,000,000V/meter or 30kV per cm but contamination and sharp points can reduce this by about a factor of 3, giving ~10kV/cm. An inch has about 2.5 cm so a Prius Prime, 'spark gap' charger could handle may be 25kV between the terminals. We're starting to look a pretty large, bulky cable with conductors rated at 10A.
    #17 bwilson4web, Oct 5, 2017
  18. bisco
    52,807
    i'm sure toshiba has already thought all this through, and has a very simple and inexpensive charger and evse to go along with the six minute battery that will be available next year.
  19. priuscatprimeguy
    2,730
    2,640
    next year????? @bisco you're not even out of 2017 yet.:eek:
    Rather than an incremental improvement, this is a game changing advance that will make a significant difference to the range and performance of EV. We will continue to improve the battery’s performance and aim to put the next-generation SCiBTM into practical application in fiscal year 2019.”
  20. bisco
    52,807
