How about this again p3191 p3101 p3190
Discussion in 'Generation 1 Prius Discussion' started by David Kleinwolterink, Feb 4, 2016.
  1. David Kleinwolterink
    David Kleinwolterink Junior Member
    26
    iowa
    So got new maf sensor ,but notice pool of oil at bottom of the intake ,clean out best i could ,starts right up and no triangle
    Is oil something big ?
  2. usnavystgc
    3,159
    990
    Tucson, AZ
    No, this is normal.
  3. bwilson4web
    16,552
    Once I started leaving about 1/4" under the "F" on the dip-stick, it eventually went away.
  4. David Kleinwolterink
    26
    iowa
    Now wont start at all
  5. DRACO
    DRACO Member
    362
    78
    Rancho Palos Verdes, California
    2002 Prius
    Do you still have the old MAF, clean it with MAF cleaner, let it air dry then put it back in.
    Is the MAF aftermarket or Toyota?
    Also did you insure the connector "CLICKED" in, remove it to see if connectors are straight.
  6. David Kleinwolterink
    26
    iowa
    went back out after 5 hrs started right up no lights ran fine drove 10 miles
    Now what
    I did start and restart 3 times kinda fast could I have flooded it ?
  7. DRACO
    DRACO Member
    362
    78
    2002 Prius
    Don't worry about it, it is good now :D
    Sometimes the the starter will over heat on some cars, a cool down will allow to start again.
