How accurate is the “Dr. Prius” app?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Reesmaxwell, Dec 10, 2018.
  1. jacktheripper
    jacktheripper Senior Member
    268
    536
    ouch, sorry to hear the low score, you should be getting the P0A80 at anytime, although it is just a warning code, some state (ex: CA) won't let you pass the smog, FYI.
    Jack
  2. StarCaller
    StarCaller Senior Member
    1,277
    729
    Cedar Crest, NM, USA
    but everything resets once the app is disconnected, right?
  3. Mendel Leisk
    41,486
    Good question. I'm thinking the fan speed override would stick? Similar to single beep reverse?
  4. jacktheripper
    268
    536
    Currently the fan speed won't stick once you close the App ( I actually feel safer this way, don't want any App to drain my cell phone battery), but I'm working on making the App to run at the background, will make it configurable. FYI.
  5. StarCaller
    1,277
    729
    I guess there's no way to make it 'really' stick, like having it always run on level 3 without ne phone connection ?
  6. landspeed
    landspeed Active Member
    361
    209
    NZ
    2003 Prius
    I just got 81.5% in my 2008 Gen 2 with original battery; am quite pleased as I have 260,000km on the clock, original battery although voltage sense harness is newer (after last,one shorted out)
  7. landspeed
    361
    209
    NZ
    2003 Prius
    A warning about controlling fan speed...
    A while ago I did an experiment where I set the heater to ‘max’, and the batteries really heated up; I monitored the fan speed and it went from 1 to zero, stayed zero for ages, and did brief periods at level 1. The battery ECU seems to try to only cool the battery if the cabin air is cooler than the battery (which makes sense)
    I would be worried about forcing the fan to max; if the battery is colder than the cabin, the battery will get covered in condensation. And probably corrode badly etc... so, I would leave the fan as-is, and only activate forced cooling mode once the battery has warmed up, and only when air con is on, to prevent condensation....
    jacktheripper likes this.
  8. jacktheripper
    268
    536
    A rule of thumb is, NiMH battery enjoy operating at right about human body temperature (95~100), so if you feel hot sitting in the cabin, your battery is feeling hot too !!
    The best time using fan override is during traffic jam, where the ECU turn off fan to reduce the noise, while reducing the battery life at the same time...
  9. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    Wow that’s some seriously low capacity! How many miles has this car driven, and has it seen extreme heat?
  10. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    No extreme heat, 190k km, already sold it, traded it in for 1 year old gen4. It could be a measuring error.
    I drove some hilly terain, but not daily, just ocasinally.
  11. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    Damn that’s not that many miles. My sister has 2010 with 268k (miles) and still gets good mpg and seems to have good capacity left. Just bought an OBD adapter so I’m anxious to see how the battery looks.
  12. fomenter
    fomenter Junior Member
    michigan
    My 08 with 125k (recently purchased) has a 66% of life expectancy. Is that a good number. How do I interpret this result? Will keep it for 1.5 years or so.. thanks
  13. fomenter
    michigan
    Well,i just did the test again, in fact twice.
    1) The capacity was at 66% last week (battery was charged at 8 bars as instructed on the app,used gas pedal to keep the needle in the green area while it was in reverse)
    2) A week later is down to 60.1% (battery overdraw from time to time, but compromised, did not use gas pedal this time)
    3) 10 minutes later it is down to 56.4% (the battery was almost full (7 bars not 8) so it skipped step 1 automatically, did not use the gas pedal.
    I am not sure which one I should rely on as I dont think the batter degrades from 66 to 56.4 in one week. Worrying about reliability of this test
  14. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    Apps will never be consistent or accurate. Hybrid assistant app connected to my car and then status showed “TELSA”.
    I’m starting to miss those “Just drive it” folks.
    Aaron Vitolins likes this.
  15. Lord Claverton
    Lord Claverton Junior Member
    Bath, UK
    2007 with 235,000 miles, original battery. Just had discharge and rebalance o_O LifeTest_2020-04-24_02-38-18.jpg
  16. ArmyChief
    ArmyChief Junior Member
    71
    50
    North Port, FL
    Believe it or not, NIMH batteries love about 76 F.
    BTW, love your app and bought the Garage Pkg... I do LOT's of car diagnosis.
  17. Umair90
    Umair90 Junior Member
    34
    Pakistan
    Can anyone tell me what’s going on with these 2 Screenshots?
    I mean I’m confused, either i be worried or not?
  18. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    Looks bad, you don’t have 5G or LTE service. Change carrier soon as you can, you can get better deals else where.
  19. Umair90
    34
    Pakistan
    sorry dear but I didn’t get you.
  20. Max Taiwan
    Max Taiwan Active Member
    428
    384
    Taipei
    2018 Prius v wagon
    Try cleaning your battery fan and clear dust from the air path going through the battery.
