How accurate is the MFD Average MPG?
Discussion in 'Gen 2 Prius Fuel Economy' started by gamma742, Apr 11, 2015.
  1. gamma742
    gamma742 Member
    178
    73
    Luxury
    It says I'm averaging 53.5 MPG and I got 511 miles on this tank before the last pip started flashing..
    I've had this car for about 4000 miles now and it just turn 90K.
    This 2008 Prius is amazing!!
    52,665
    it's a bit optimistic. at the pump, that will translate to around 50-51 mpg. the '04 thru '09 has a rubber bladder inside the gas tank, and every fill up is a bit different. best way to get a good average is over multiple fill ups, the more the better.
  3. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    Seems about right to me. I calculate the tank mileage with the gallons I just put in.
    Last fill up comes to 9 gals after 1click.
    52,665
    that's pretty dang good!(y)
  5. Mochabuzz
    Mochabuzz Junior Member
    46
    SoCal
    I think it's pretty accurate... especially if u have stockISH tires on it. Way to go!
  6. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    but that's a gen 3 display and your avg MPH is only 18 over 500 miles? you must never leave your neighborhood or go on a highway...
  7. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Mine is off by less than 0.5% on average. I have the European module without gas bladder so no tank has been off by more than 1 l or 0.23 gal. That inaccuracy is mostly due to differences in fuel pumps.
  8. priusrecon
    priusrecon Member
    130
    45
    Upstate NY
    I've always tracked my milage from tank fill to tank fill (odo/gals filled) with all my cars.
    I have an '04 now, and the MFD estimate has always been within about 0.3 mpg of my tank to tank results.
  9. gamma742
    gamma742 Member
    178
    73
    Luxury
    So it sounds to me like the MFD Average MPG is fairly accurate.. Good to know because I have never gone to the trouble of manually calculating the Odometer from the Pump.
    and yes, as we can see from Sergiospl's Pic ....the 3rd Gen. Prius does do better on MPG over the 2nd Gen. I drove my wife's car for a week while she was out of town. I was impressed with it but not enough to trade Ole' Bronze in :sneaky:
  10. Mendel Leisk
    42,160
    On my 3rd gen the error is 7.5%.
  11. fuzzy1
    10,652
    Note that several responders in this thread have Gen3s. The typical accuracy seemed to change from Gen2 to Gen3, becoming more 'optimistic'. So when you see impressive Gen3 displays, keep in mind that the displayed gain is composed of two components. Part is a real mpg gain and part is an increased dose of 'optimism'.
  12. Mendel Leisk
    42,160
    I didn't specify it was optimistic. How'd you know? :whistle:
    fuzzy1 likes this.
  13. CrazyLee
    CrazyLee Member
    153
    24
    Muskegon, MI USA
    I have an old 2004 Prius. I usually get 50 MPG on the MFD but the display is usually 2-4 MPG low.
    I was getting 45 MPG this spring, (from 36 MPG this winter) and after a long trip from Muskegon, MI to St Louis,MO and back, the old Prius got out of its funk of low MPG's to normal 50 MPG's. (At 70 MPH)
    I think you have to drive a Prius hard to keep it in tune!
