How avoid injecting old brake fluid into calipers with piston reseat
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Lento47, Jul 18, 2026.
  1. Lento47
    Lento47 New Member
    Colorado
    Preparing to replace the front pads and rotors myself on a 2009 Prius. After I compress the caliper pistons to install the pads, and reassemble the rest of components, I want to avoid injecting old fluid (from the brake line directly before the caliper) into the caliper when the pistons are reset against the new pads.
    If I’ve disconnected the negative battery terminal and/or 2 relays before starting work (according to all the safety advice I’ve seen), can I then just manually compress the brake pedal while opening the front bleeders to clear the front manual hydraulic lines? As I understand, this won’t clear the actuator, ABS, rest of the system, but that’s fine for the moment.
    After that’s done, with both bleeders closed, I could press pedal again several times to reseat the pistons.
    Then reconnect battery and relays, turn car on and hopefully not generate any errors.
    Then I could proceed with flushing the rear lines according to several videos I’ve seen, or bring the car somewhere to have the whole system flushed.
    Note, I do not have any of the tech tools/scanners. Even if I did, it’s not clear they could be used to avoid injecting old fluid into the calipers, given that all the brake replacement work is supposed to be done with the power disconnected. I’m assuming that once power is restored, the system will pressurize and reseat the pistons and likely generate an error code due to the distance they have to travel. Thus the desire to reseat the pistons manually, and also clear the old fluid before doing so.
    Also, I’m confused by the manual’s procedure for flushing the front brakes, where, after you turn car off and remove the relays before flushing the front lines, it has you put the car in IG ON. [As found in the 2004 Prius brake bleeding procedure.pdf, pgs 32-6/ 32-7, 3494/3495, attached]
    Is that needed to flush the front lines, or does the brake system not revert to a pure mechanical state (failsafe) with the battery/relays disconnected?
    Why does the manual have you put it in IG ON? What does this achieve in the brake system with the relays out, but IG ON?
    Any help would be appreciated!
    Thanks!
  2. Tombukt2
    Tombukt2 Senior Member
    13,878
    2,521
    Durham NC
    Before you start all this open a front caliper and remove resvoir top . Once the fluid gets down to the last two or three drops until it disappears and you can't see it in the reservoir anymore add brand new fluid . Let it drip a few more minutes and close that fitting up and go to the other side and open the other fitting let it drip 5 min . Now you have new fluid from the reservoir out of the front calipers and front lines. That don't take much . I'm using dot 5 in one gen2 now. You won't mix the two of careful .
  3. Mendel Leisk
    42,378
    Has the brake fluid ever been changed, to your knowledge?
    Maybe get the dealership to do that, and then don't touch the bleed screws when pushing the piston back in.
  4. Lento47
    Lento47 New Member
    Colorado
    Thanks Tombukt2!
    Is it ok to do this gravity drain with battery disconnected to avoid accidentally triggering the brake fluid pressurization system?
    Or do you have to leave it connected to keep certain solenoids/valves open and even allow this gravity drain to work?
    And if the latter’s the case, should car be off, with key kept away from car and drivers door unopened?
    Either way, would pressing the brake pedal speed this drain up, or create a problem? And maybe that depends on whether the battery is connected or not (ie whether the pump is pressurizing the system or not)?
    Then after the front lines from the reservoir to the calipers are replaced with new fluid, I can proceed with disconnecting battery
    - should I pull relays too?
    Then remove pads/rotors, compressing pistons while bleeding the calipers, put on new pads/rotors and tighten everything down.
    Is that correct to then reseat the pistons by pressing the brake pedal a few times? And then reconnect the battery/relays?
    I was going to stick to DOT 3.
    Thanks again!
  5. Lento47
    Lento47 New Member
    Colorado
    Thanks Mendel!
    If I don’t open the bleed screws when pushing the pistons back in, how would I clear the old fluid within them out of the lines? Won’t that just push the old fluid from the calipers back into the freshly flushed system? From what I’ve read here, that’s likely the dirtiest fluid in the system, since it’s at the bottom of the line.
    As far as I know, brake fluid was changed by a dealer (but don’t know which one) at the 30,000 mile mark, 10 years ago and they put in Valvoline DOT 3&4. Btw, the car has low mileage for its age (only 85,000). So this fluid has ~55,000 miles on it.
    I checked moisture content with a KAIWEETS Brake Fluid Tester Pen, came back at 2.2 %.
    However, the fluid is a lime green color (copper content?) and 10 years old, so figure it should be flushed.
    I called my local dealer and they want $225 for a flush. AND that’s only for a ‘surface flush’. The guy I spoke with (not sure now if he was a Service Advisor, or a floor tech) said they don’t use Techstream (I specifically asked), instead use a machine to suck out old fluid, refill and bleed if needed. He said, as far as he knows, they only flush the reservoir and lines to the brakes. They don’t do the actuator, pressure vessel, etc. To do a ‘deeper flush’ as he called it, would take longer and cost more.
    I will call around next week to try and find an independent shop that does a true full flush.
    Thanks again!
  6. PriusCamper
    PriusCamper Senior Member
    13,476
    5,441
    Pacific Northwest, USA
    Changing old brake fluid in modern cars is unnecessary and some believe that the start of a very expensive brake booster failure began after a brake fluid flush... So if you don't want to spend thousands on a new booster pump keep it simple.
    If you need proof to change or not to change ---> use a moisture test strip to see how much moisture is in the brake fluid...
    As for the rest of it, when you push the pistons in that means the reservoir fills up and in modern cars that rarely have problems with brake fluid you can correlate brake fluid level being low to sigignifican brake pad wear (unless a dummy topped off the fluid level) and when you put the new brake pads on the fluid returns to normal. Thus a smart mechanic never has to bother with changing brake fluid levels because they use it to determine brake pad wear and when new pads are installed the fluid in reservoir returning to perfect level is further confirmation the system is working properly.
    Gen2 Prius are amazing in that regard. I'm got 287K miles out of original front brake pads and still on original fluid that returned to a perfect level once the brake pads were replaced.
  7. BiomedO1
    BiomedO1 Senior Member
    4,639
    2,434
    Left Coast
    I don't understand how your going to prevent brake fluid from entering the front brake calipers; if your going to press the brake pedal? Please clarify your thinking on this; because brakes are designed to apply pressure on all four corners, with or without power - It's a safety design.
    Once your finished with the brakes; you NEED the pump the brake pedal to seat the pads - otherwise you won't have any brakes for the first few pumps. If your young and just press the brake pedal to the floor boards, you'll never stop. Us old timers are thought to pump the brakes during failure.
    Don't need no fancy power brakes or ABS:(:rolleyes::cry:
    PriusCamper likes this.
  8. PriusCamper
    13,476
    5,441
    I think the problem with OP is overthinking... It takes 15-20 minutes per axle to change brake pads from start to finish. I always talk about that with people who tell me they just got ripped off for having brakes changed that weren't even worn out yet! Their mechanic was making more off them per hour than lawyers charge their clients. It's so wrong!
  9. BiomedO1
    4,639
    2,434
    Left Coast
    o_O:rolleyes: My brother runs a shop and hires idiots - because he's too cheap to pay anyone that knows anything. The kids he hire already knows EVERYTHING. This kid does a brake job and is suppose to get a sign-off before putting the wheels back on. He finishes the job in record time, without sign-off. Backs the car out of the stall, can't stop, and hits a parked car.
    ONE guess what he didn't do?????
    I had to rub it in; Asked the smart asset why he didn't go after the parking brakes or pump the pedal????????? You did adjust the parking brakes; didn't you? It was a Fred Flintstones moment; watching him try to stop the car with his feet. I was just lucky to be there when that happened; because I've told my brother on multiple occasions to just pay the mechanics a little bit more for the good ones - that'll improve business, lower your insurance rates, and your ulcers may even go away.:censored::LOL::whistle:
  10. PriusCamper
    13,476
    5,441
    You'd think it'd be obvious that you want to pump the brake pedal a few times so it feels normal again in case the dude that hired you checks out how its going? It's weird these days kids don't grow up worrying about getting in trouble in order to avoid it. They just straight up get in trouble without worrying about nothing.
    BiomedO1 likes this.
  11. Albert Barbuto
    Albert Barbuto Active Member
    119
    108
    Northeast USA
    If you want to "avoid injecting old brake fluid into calipers", flush the line of old brake fluid first. Pop the cover off the brake fluid reservoir, to prevent a vacuum, as fluid level recedes. Now simply loosen the bleeder, and gravity will do the rest.
    Tombukt2 and Brian1954 like this.
  12. Mendel Leisk
    42,378
    When the brake fluid's replaced it's drawn from the bleed screws at the four calipers. The fluid there's as clean as the rest.
