Featured How BEV's may be dangerous to smaller lighter vehicles is an accident
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Georgina Rudkus, Jun 17, 2023.
  1. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    That too.
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,464
    2,427
    Taylors, SC
    An additional one thousand pounds is not minimal it it adds up. Think about the strain on your heart and your knees, if you weighed 25 % more.
  3. pakitt
    2,173
    1,313
    Colorado
    We are talking of EV trucks in the 8000 pounds range... And the USA is full of trucks. If they all start to weigh 2x what they weigh now, see above... (let alone the fact that they also have 2x-3x the HP of a regular gas truck... I see people launching...to the stratosphere...)
  4. Isaac Zachary
    Isaac Zachary Senior Member
    2,548
    1,289
    I can see it both ways. Cars are always weighing more and more. I used to drive cars that were under 2,000 lbs. So yes, there are disadvantages (like road wear and more destruction when you crash) but there are also advantages. I do miss my sub-2,000 lbs cars though. Modern cars weigh too much to be any fun to drive. Maybe I'll get a Miata when the kids move out.
  5. Trollbait
    12,534
    The unit used to represent traffic forces on a road during design is Equivalent Single Axle Load. It is the weight that one axle with two wheels applies to the road. An ESAL of 1 is equal to 18,000 pounds. One axle of a 4,000 pound car has an ESAL of 0.0003
    Roads aren't designed for passenger cars. They are designed for commercial trucks.
    Equivalent Single Axle Load – Pavement Interactive
    "Heavy trucks and buses are responsible for a majority of pavement damage. Considering that a typical automobile weighs between 2,000 and 7,000 lbs (curb weight), even a fully loaded large passenger van will only generate about 0.003 ESALs while a fully loaded tractor-semi trailer can generate up to about 3 ESALs (depending upon pavement type, structure and terminal serviceability)."
    For roads designed to handle 3000 times or more wear than what a single car can inflict, another thousand pound on the car isn't noticed. Maybe the heavier car can lead to more wear of the surface coating, but then so does heavier and more frequent rain. The cost difference between a car and light duty truck for registration fees I've seen is more than is justified by weight difference to road wear.
  6. fuzzy1
    10,447
    ... and we must remember that:
    (*) road weight damage varies with the 4th power of axle weight;
    (*) our major highways are built for trucks weighing 80,000 pounds or more.
    Compared to those heavy trucks -- lots of them, too -- that 4,000 pound SUV is negligible. It does need lane space, so needs to pay for added lanes and other congestion mitigation, but doesn't measurably add to road weight damage.
    #66 fuzzy1, Jun 29, 2023
    Trollbait, drash and Zythryn like this.
  7. Rmay635703
    Rmay635703 Senior Member
    2,669
    1,688
    Somewhere in Wisconsin
    2013 Chevy Volt
    If it means my 1900lb and 900lbs cars become registration exempt I’m all for it.
    Isaac Zachary likes this.
  8. bwilson4web
    16,210
    That is correct because the Tesla OEM tires are performance with low wear rating. Replacing them with 60,000 mi rated tires works just fine. It was one of my first mods and since longer rated tires don't wear so quickly, they often have lower rolling resistance. I did the same with my previous Prius.
  9. bisco
    51,915
    me too. i replaced the oems at 50,000 because one was making a thumping noise, with michelins.
    35,000 miles later, the michelins look brand new
