how big 12v power inverter can i run off my Prius for generating power?
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Oct 11, 2012.
  1. ski.dive
    ski.dive Active Member
    896
    231
    Hutchinson Island,FL. Mt. Snow,VT
    I want to turn my Prius into an emergency generatot by installing a 12v inverter.
    The Prius with a 12v inverter, would make a great power source during major power outlets that are caused by storms,etc.
    I would like to install a large inverter that can power my refrigerator and other small appliances.
    How big of an inverter can I safelly install on my prius to run some of my appliances?
    ***Anybody done this?
  2. Patrick Wong
    18,200
    6,474
    Bob Wilson had done this a few years ago.
    The most that you should expect is around 1 kW of power from an inverter so you'll need to consider the peak power required when the compressor in the refrigerator starts up.
    [email protected] likes this.
  3. jdenenberg
    jdenenberg EE Professor
    3,852
    1,852
    Trumbull, CT
    2020 Prius
    LE AWD-e
    1 KW is the limit running off of the 12v supply in ready mode. More that that and you risk blowing a Prius fuse.
    You can use a 3-5 KW inverter by carefully running off the 200v traction battery (again only in ready mode). Information can be found at: PriUPS-getting electricity FROM your hybrid vehicle
    JeffD
