how can charger hv battery back
Discussion in 'Gen 3 Prius Accessories and Modifications' started by ali3d2004, Aug 10, 2010.
  1. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Re: Where can I buy high-voltage Battery charger
    This is his second thread. There is a high probability that he doesnt need it.
    His 12v died after sitting for 5months, and for whatever reason cannot jump it. I think he did jump it, because the MFD came on showing the HV battery at 1bar. But it came on in READY from what I understand. So he just needs to drive it around.
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Merged the 2 threads together...
  3. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    It is a special charger built for authorized Toyota repair function.
    It is not sold at any generic stores.
    Ken@Japan
  4. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    The car will recharge HV battery itself. You don't need a high voltage charger because the car has built in it already.
    You HV battery is not dead. It still has about 45% charge left. Let the car recharge itself.
  5. sti-nkr
    sti-nkr Prius Ricer
    45
    Tyler, Texas
    He obviously doesn't understand the words that y'all have told him. He said he bought a US car and exported it to his country, the manual is going to be in english. It's probably very confusing given his poor english on here. post up a simple pictogram thingy, picture of jumper cables on the battery in the trunk, then a picture of turning on car, then taking off the leads.
  6. sti-nkr
    sti-nkr Prius Ricer
    45
    Tyler, Texas
    also, if you notice in his pictures, his 12v battery is not really hokked up. he is using the trucks battery to hook to his cars leads.
  7. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    The engine doesnt have a normal 12V starter. It uses the MG to start the car. I think his problem could be that the HV battery doesn't have enough juice to run the MG to start his engine.
    Edit: Enginer PHEV can charge the HV battery
  8. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Would be best to simply tow it to Turkey or Iran and get an actual Toyota dealership to HV charge if that is the issue.
  9. Ct. Ken V
    Ct. Ken V Active Member
    535
    57
    Bolton,CT
    Hi. sti-nkr,
    You're right. In the middle picture (back in post #9 he's got the battery cables completely off of the 12V battery & only those are hooked up to his jumper cables (so he's NOT charging his 12V at all). This would allow him to see the MFD screen (as pictured in the 3rd photo in post #9) & start the car, but as soon as he would shut it off to re-connect the car's cables to his 12V battery, he's hooked back up to an UNCHARGED dead battery that won't restart his car. He either has to charge the 12V battery directly (since he already has access to it) or button everything back up & charge it through the jumper lug inside the under-hood fuse box.
    I too am a little confused about what year Prius Ali has, but I think I might have it figured out. Ali says in his profile that his car is a 2010 Prius V, but in one of his posts in another thread, it sounds like it was damaged in an accident. As ken1784 points out in his post #17, it looks like Ali's Prius is a 2nd generation & Ali's username ends in 2004 so maybe he owns a 2004 Prius. Maybe this one was damaged (& that's why it sat for 5 months) & he's got a 2010 Prius V on order.
    If that is a 2004 Prius in the 1st picture in his post #9, I can't tell if that 12 V battery (in the 2nd photo) is an original Prius battery (I've never looked at that battery in my own 2005) or an after market substitue (it's not like he can just go to a neighborhood Toyota dealer & get the proper one). Regardless, it looks like a new 12 V battery is in order rather than trying to charge what may potentially be a totally useless 12 V presently in the car, but he surely isn't in any way re-charging his present 12 V battery the way the jumpers are hooked up to only the disconnected car's cables. The only thing he may charge that way is the high voltage battery if his car actually starts & he leaves it running long enough. Oh, and if he leaves the jumper cables hooked up that way, he may also charge the 12 V battery of the donor vehicle.
    And to the last 2 posters, I don't think he has a high voltage battery issue at all, since you can see one battery bar in photo #3 in his post #9. That should surely be enough to start his ICE (unless he can't get into "Ready" status.
    Ken (in Bolton,Ct)
  10. ali3d2004
    ali3d2004 New Member
    16
    iraq
    Hi Ct. Ken V
    Thank you for your answer to me my dear friend, my brother and I have two more cars Prius model 2008 and 2010
    And I have the same problem in both cars, and this with my pictures of the vehicles
    I hope to find the solution you've poured a rapid and young people in the forum
  11. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    wow... confusing forum
    your 12v battery is in the trunk.. under the floor on the far right hand side. (pull apart the floor to see it)
    do no disconnect this battery. jump start it directly connected. while hooked up jump inside the car and turn it on. ("Ready" will light up on the dash) you will see that the Hybrid Battery (a huge 250v battery) is low.. that's ok.. the engine will recharge it. the engine shuts off when there are at least 2 bars on your display. to get a fuller battery, drive it.
    your display for the hybrid battery will change all the time. low means you get less power.. full means you get more. gas mileage will change too.
    if your hybrid battery is too low, the car will not turn on... or if it does, the engine will run at a really high rpm to charge it.
    if you do not want to crawl in the back of the car.. pop the hood, and jump start there (uncover the black fuse box and connect the + to the jumper under the red cap) connect the - to the bolt on the front strut tower.
    if english is not your 1st language, let us know which is your native language so we can try to assist you better.
  12. V8Cobrakid
    3,790
    152
    make sure you hold the brake down as you press the START button (or ON.. whichever it is)
    you'll see "READY" on the dash...
  13. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    [FONT=Verdana, Arial][FONT=Verdana, Arial]Ahlan wa-Sahlan[/FONT][/FONT] Ali,
    In post number 9 you have three pictures. ~ في مرحلة ما بعد الرقم 9 لديك ثلاث صور
    In the middle picture you show a 12-volt battery. ~ في وسط الصورة تظهر لك بطارية 12 فولت
    This is the battery for the dead Prius. ~ هذه هي بطارية لالطراز القتلى
    It is the same as any other 12-volt battery. ~ انه هو نفسه أي بطارية أخرى 12 فولت
    Have you tested it? ~ هل سبق لك أن تختبر ذلك؟
    Can you charge that battery? ~ يمكنك أن تهمة البطارية؟
    That battery starts the car. ~ أن يبدأ بطارية السيارة
    If it is dead the car will not start. ~ إذا كان القتلى من السيارة لن تبدأ
    You can put any 12-volt car battery there. ~ يمكنك وضع أي بطارية السيارة 12 فولت هناك
    It is no different th
    an any other car battery. ~ انه لا يختلف عن أي بطارية السيارة الأخرى
    Good Bye. ~ Ma'a Salaama.[/FONT]
    [/FONT]
  14. V8Cobrakid
    3,790
    152
    make a video of you starting the car, the dash, and the LCD screen.
