how can I eliminate key fob
Discussion in 'Gen 2 Prius Main Forum' started by archibald tuttle, Jul 29, 2023.
  1. archibald tuttle
    archibald tuttle Junior Member
    81
    Rhode Island
    so maybe the FOB came out in the car but it is far enough from the ignition not to be seen now. the car started when i left but doesn't see the key now! Remotely conceivable it came out of my pocket after i parked although short straight walk to house an can't find it. I'm trying to think back to when I left. The car is also very bad about shutting off when you hit the button. you have to hold it hard for maybe 4 or 5 seconds. so sometimes I don't hold it long enough and accidentally leave the car on. And if I just tapped the button when I got in the car, it might have been on already and I didn't notice. Yes, if I was paying attention to dash lights I would know, but I admit that you hit the button by reflex and keep thinking about other things.
    Where precisely is the SKS switch. That would have solved my problem . I wish I knew about it and switched it after i lost the first FOB.
  2. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    464
    Leawood, KS
    I
    See Post 20. on the first page.
  3. Tombukt2
    Tombukt2 Senior Member
    13,848
    2,515
    Durham NC
    So if you're having to hold the button to turn the car off do you also not have a display the shift pattern miles per hour gas gauge usually when you have to hold the button to turn the car off it's because of the display problem?
