How can i know if the HV battery is original
Discussion in 'Gen 2 Prius Technical Discussion' started by nidalls, Jan 11, 2017.
  1. nidalls
    nidalls New Member
    Amman
    Hello,
    Is there a way that i can know if the Prius HV battery is original?
    I have a Prius 2006, and i need to replace the battery with a new one.
    Agency battery price of nearly $ 2,542, without wages required for installation. (New battery)
    And the price of a local garage $ 2,260, including installation fees. (New battery).
    I am a very confused, if the battery from the garage, original.
    Is there a specific code on the battery to make sure it?
    ( I'm from Jordan)
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    It could be a Toyota battery.
    They should be able to buy parts from Toyota and then install them in your car.
    The local garage may charge less than the Toyota dealer.
    You could ask to see the part ahead of time, or some sort of paperwork showing that it is a new Toyota part.
    nidalls likes this.
  3. nidalls
    nidalls New Member
    Amman
    Thank you very much ^^
    but is there a way to be sure it's an original one, from any code on the battery on the modules in it?
    52,888
    welcome!
    i would think a new toyota battery would have a correct serial # and matching modules inside. would definitely take some investigative work before installation.
    nidalls likes this.
  5. nidalls
    nidalls New Member
    Amman
    Is there a Chinese batteries (fake) :3 ?
    Is Toyota still make the second-generation batteries?
    And can I install a third generation battery on my prius 2006?
    thank you very much :))
  6. bisco
    52,888
    i haven't heard about fake batteries, but the cells inside might be a different story. can you ask the agency and the local garage any questions?
    i think eric can answer your 2nd and third generation battery question.
    #6 bisco, Jan 11, 2017
  7. dolj
    dolj Senior Member
    8,652
    4,404
    Wellington, New Zealand
    Yes, there are "generic" Chinese manufactured modules, so be very careful. Reputable battery rebuilders in the USA will not use them as they are too unreliable and have a high (25%) rejection rate straight from the supplier.
    Technically no, the original modules are no longer manufactured. However the latest generation modules are used to build a new Gen II battery packs.
    Yes, it can be done as long as you use all 28 modules from the (same) Gen III pack to replace all the Gen II modules. It is not advisable to mix Gen III and Gen II, if you desire to build a long lasting battery pack.
    nidalls likes this.
  8. dolj
    dolj Senior Member
    8,652
    4,404
    Yes, there should be a date code within the pack serial number on the outside of the pack. There is also a date code as part of the serial number on each of the modules inside the pack. So, if you are able to open the pack up, you can check each individual module. If it is genuine pack the modules should be closely sequential and the month should be with 3 months of each other.
    This diagram will show how to decode the serial number on the outside of the pack:
    This diagram will show how to decode the serial number of each module inside:
    hope this helps.
    #8 dolj, Jan 12, 2017
    nidalls and Mendel Leisk like this.
  9. nidalls
    nidalls New Member
    Amman
    Thank you very much, very useful and intersting information.
    The last question. Chinese modules/batteries is there any way to identify them?
  10. dolj
    dolj Senior Member
    8,652
    4,404
    They will not be Toyota branded. The only place to get Toyota modules is from Toyota's supplier and nobody, but Toyota, can buy genuine Toyota modules. Toyota do not sell modules individually, so be very suspect of New Toyota Branded modules, they could well be counterfeit.
    DLC82SV likes this.
  11. dolj
    dolj Senior Member
    8,652
    4,404
    I am updating this old thread with some updated information with regard to the battery pack serial number. Newer packs have labels as shown in the attached image. The decode information is also shown in the image.
    The is a further newer label that has come up in threads more recently but there is no decode information for them so far.
