How can I mod the DRL to have it on at all time? (for 2013 models)
Discussion in 'Gen 3 Prius Accessories and Modifications' started by m3rhkp, Apr 26, 2013.
  1. Grit
    Grit Senior Member
    6,573
    4,225
    Wilkes Land
    How about including the side parking lights also? I'd like to keep the DRL and parking lights both on all the time. I know I can set stalk to parking lights so both DRL and parking lights to turn on, but the taillights will come on also and that I don't want.
  2. Grit
    Grit Senior Member
    6,573
    4,225
    Wilkes Land
    Did you get a chance to piece together a possible scheme for a potiental mod?
  3. getinthecar
    getinthecar Junior Member
    Seattle, WA
    Sorry the ebay link for that ATM fuse tap expired. Can you provide me with another working one? Want to make sure I don't buy the wrong one.
    Thanks!
  4. xliderider
    xliderider Senior Member
    8,140
    3,274
    Honolulu, HI
  5. Panayot
    Panayot New Member
    Sofia, Bulgaria
    Hello,
    I need an answer. With using of the fuse adapter put in + "ready" mode and the other side in the right place of relay socket will the DRL goes OFF with switching the Headlights ON/AUTO?
    #125 Panayot, May 2, 2019
  6. Exiled conservative
    Exiled conservative Junior Member
    30
    Whittier, ca
    You have it plugged to the top connector instead of the middle female connector. Plug to middle connector and it'll work like a charm.
  7. Exiled conservative
    30
    Whittier, ca
    Bought a wire tap with a fuse and ended up using your paperclip idea. Works great! Thanks for your post. Helped me for sure.
  8. Jo Torres
    Jo Torres New Member
    San Diego
    Hello, I am a newbie here. My wife drives a 2012 Prius, I would like the DRL always on even at night. When you get a chance, can you send a pic for the MOD?. I like the idea of the "poor man's fog light". Thanks in Advance
    whitmanrf and Burna J like this.
  9. Jo Torres
    San Diego
    Hello, Gilbert. I am a newbie here. When you get a chance, would you be able to post a pic of the MOD that you did? Thanks in Advance!
    whitmanrf likes this.
  10. bdirwin
    bdirwin Senior Member
    36
    Phoenix
    Thank you, Thank you, Thank you!!!
    Super Simple, Free, and IT WORKS!!!!
  11. Matth Torrijos
    Matth Torrijos Active Member
    114
    207
    Poway
    What does the blue end look like
  12. bdirwin
    36
    Phoenix
    One end is a standard crimp on spade connector that plugs in where the center pin from the relay used to go, The other is bare wire inserted along with the headlight fuse.
  13. DC919
    DC919 Junior Member
    North Carolina
    I did this mod on my 2013 Prius years ago. It has worked flawlessly over the years. Recently I helped a neighbor do the same on his 2015 Prius. Here are some photos if it helps anyone else.
    MAX2 likes this.
  14. DC919
    DC919 Junior Member
    North Carolina
    If doing the mod be sure the vehicle is off and not powered on to avoid throwing any possible check hybrid system error code. If you should get a message disconnect the 12 volt trunk battery for 15 minutes and the message should disappear.
    Burna J likes this.
