How can I stop this?
Discussion in 'Prime Main Forum (2017-2022)' started by will the engineer, Dec 3, 2019.
Tags:
  1. will the engineer
    will the engineer Active Member
    238
    119
    LA
    2019 Prius Prime
    How can I stop my Prius from always starting in EV mode? It's nice in all, but at times I wish the car would start up in hybird mode
    did I over look an option? I couldn't find a solution anywhere
  2. meeder
    meeder Active Member
    239
    163
    Doesburg, The Netherlands
    There is a HV/EV button if I'm correct.
    Verstuurd vanaf mijn LYA-L09 met Tapatalk
  3. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    You need to remember to do it manually. There is no setting to have it always start in HV mode.
    I suppose you could let the traction battery run down. Dealers seem to have that perfected before test drives. :(
    broncobilly_69, TGrracie and meeder like this.
  4. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    No automatic way of doing this. You just have to make habit of hitting HV/EV button right after you push the START button. I do this every winter morning, so I don't use traction battery for heating my car.
  5. will the engineer
    238
    119
    LA
    2019 Prius Prime
    I was hoping that was not the case.
    I wonder if carista has an option to always start the car in hybird mode
  6. bisco
    52,858
    would it be difficult to enter the software that controls this function?
  7. Salamander_King
    11,024
    8,980
    New England
    Don't think so. At least currently no such option listed.
    Toyota Prius PHV/Prime/V 2nd gen | Carista OBD2 supported vehicles | See what’s available for your car - Carista
    Dings & Warnings
    Reverse-gear beep
    Beep once / Keep beeping while in reverse
    Seat belt warning ding (driver)
    Enabled / Disabled
    Seat belt warning ding (front passenger)
    Enabled / Disabled
    Seat belt warning ding (rear passengers)
    Enabled / Disabled
    Ding when key is left in the car
    Enabled / Disabled
    Ding when key is out of the car and ignition is on
    Yes / No
    Ding when headlights are left on
    Yes / No
    "Master caution" light
    On / Off
    Remote low battery warning
    On / Off
    Driver Assist
    Pre-Collision System (PCS) sensitivity: remember last state
    Enabled / Disabled
    Default distance for Pre-Collision System (PCS) alarm when the PCS switch is turned off and back on
    Far / Remember last distance
    Default distance for Pre-Collision System (PCS) alarm when the ignition is turned on with the PCS switch off
    Default distance for Pre-Collision System (PCS) alarm when the ignition is turned on with the PCS switch on
    Heater & A/C
    Remote-start A/C from remote via…
    Off / Double long press / Long press / Double click / Single click
    Remote-stop A/C from remote via…
    Auto-turn on A/C when AUTO button pressed (if needed)
    Yes / No
    Auto-turn on recirculate mode when A/C is on
    Yes / No
    Open vents to outside air when ignition is turned off
    Yes / No
    Auto-increase blower speed when front defroster is on
    Yes / No
    Open air flow to footwell when AUTO button pressed
    Yes / No
    Ambient temperature calibration
    -3°C / -2°C / -1°C / Normal / +1°C / +2°C / +3°C
    Fan speed reaches its target…
    Slowly / Normally / Fast
    A/C ECO mode
    Enabled / Disabled
    A/C compressor noise reduction
    Enabled / Disabled
    S-Flow function
    Enabled / Disabled
    Instruments: Displays & Nav
    Instrument lights dimming sensitivity
    Darkest / Darker / Normal / Lighter / Lightest
    Instrument lights restoring sensitivity
    Engine start indicator
    On / Off
    Speed limit in dashboard
    On / Off
    Display odometer after ignition is turned off for…
    30 seconds / 1 minute / 10 minutes / Off
    Lights: Automatic
    Automatic High-beam System (AHS)
    Enabled / Disabled
    Auto headlights activation threshold
    Headlights in residential area mode
    Yes / No
    Lights: Exterior
    Lane-change turn signal auto-flasher count
    Off / 3 flashes / 4 flashes / 5 flashes / 6 flashes / 7 flashes
    Turn signal click volume
    Low / Medium / High
    Coming-home lights duration
    30 seconds / 60 seconds / 90 seconds / 120 seconds
    Lights: Interior
    Interior light control
    Enabled / Disabled
    Turn on interior lights when you shut off engine
    Yes / No
    Turn on interior lights when you unlock doors
    Yes / No
    Turn on interior lights when smart key in range
    Yes / No
    Dim interior lights after…
    7 seconds / 15 seconds / 30 seconds
    Interior footlight (bright when doors open, dim when driving)
    Yes / No
    Turn on interior door-handle & center console lights dimly (flood lights) when ignition is on and shifter is not in park (P)
    Yes / No
    Locking: Automatic
    Wireless door locking
    Enabled / Disabled
    Re-lock doors automatically if you unlock, but don't open a door within…
    30 seconds / 60 seconds / 120 seconds
    Locking: Beep & Blink
    Blink turn signals when locking/unlocking with remote
    Yes / No
    Locking: Doors & Alarm
    Max number of consecutive lock/unlock cycles via touch sensor
    Unlimited / 2 times
    Warn (beep) when door can't be locked because it's still open
    Yes / No
    Warn (beep) when a window is still open when locking doors
    Yes / No
    Warn (beep) when sunroof is still open when locking doors
    Yes / No
    Locking: Smart Key
    Stop monitoring for car key signal after…
    0 - 5 days
    Touch-to-unlock-doors minimum duration
    Off / Short / Medium / Long
    After locking with smart key, don't allow re-opening within…
    0.5 seconds / 1.5 seconds / 2.5 seconds / 5 seconds
    Smart key location to start car
    Front seats / Anywhere in vehicle
    Open trunk via smart access button
    Disabled / Double click / Long press
    Mirrors
    Auto fold side-view mirrors (req. power folding mirrors)
    With ignition / With door locks / Disabled
    Windows & Sunroof
    Open windows and sunroof via long-press on remote
    On / Off
    Close windows and sunroof via long-press on remote
    On / Off
    Open windows and sunroof by turning and holding key in door lock
    On / Off
    Close windows and sunroof by turning and holding key in door lock
    On / Off
    Beep when opening/closing windows with remote
    Yes / No
    Open driver's window using single button press
    Yes / No
    Close driver's window using single button press
    Yes / No
    Open passenger's window using single button press
    Yes / No
    Close passenger's window using single button press
    Yes / No
    Open rear left window using single button press
    Yes / No
    Rear-left window single-touch-close
    Yes / No
    Open rear right window using single button press
    Yes / No
    Rear-right window single-touch-close
    Yes / No
    Passenger window single-touch-open from driver's switch
    Yes / No
    Passenger window single-touch-close from driver's switch
    Yes / No
    Rear-left window single-touch-open from driver's switch
    Yes / No
    Rear-left window single-touch-close from driver's switch
    Yes / No
    Rear-right window single-touch-open from driver's switch
    Yes / No
    Rear-right window single-touch-close from driver's switch
    Yes / No
    Wipers & Washer
    Automatic wipers (using rain sensor)
    Yes / No
    E-GINO and Tideland Prius like this.
  8. Tideland Prius
    16,681
    What the heck is this?
    Yes / No
  9. Salamander_King
    11,024
    8,980
    New England
    Yeah, there are few items listed on Carista web site specifically under PRIME customization that seem not to apply.
    Like...
    Mirrors
    Tideland Prius likes this.
  10. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    I can see how it might be nice to start in HV in certain situations. But the car is designed with low emissions being the primary objective. Hence there is no option to change that even with Techstream.
    Salamander_King likes this.
  11. Tideland Prius
    16,681
    The trunk one should work (I believe that is customisable)
  12. Salamander_King
    11,024
    8,980
    New England
    Oh, does it means unlock the trunk with the fob? I thought it meant power lift to open the trunk with the dedicated key on the fob, which PRIME does not have.
  13. Tideland Prius
    16,681
    I assumed it was the SKS unlock in the trunk
  14. Salamander_King
    11,024
    8,980
    New England
    Hummm, I looked up the manual. It seems SKS can be configured to open just driver door or all three. I wonder with Carista, you can selectively disable just trunk from SKS or change the way to open it to Double click or Long press instead of default single press to open all three doors? Carista list has no mentioning of other doors (Driver's and Front Passenger Doors) being customizable.
    From Carista:
  15. Tideland Prius
    16,681
    Ok now I'm not sure lol.
    I've done both - press and hold and double press on the rear hatch to open so both methods work as far as I know.
  16. Salamander_King
    11,024
    8,980
    New England
    I bought Carista recently, but have not installed the app yet. When I do, I have 30 days to play with it. Maybe when the weather is better, like next spring, I will let you know the answer.;)
    I have not changed any of SKS setting myself since. I have to try it later, but IIRC, it came with single click to unlock all three doors. I almost never use the fob button to open the door or trunk. So it guess it really does not matter to me double or long press.
    #16 Salamander_King, Dec 6, 2019
  17. Tideland Prius
    16,681
    Just to clarify, I'm using the SKS button on the hatch itself to release it (double tap or long press). I almost never touch the fob either (except for remote A/C... we don't have Entune here).
    I left mine with the default driver's door but shortened the interval from 2.5 secs to 1.5 secs on the "linger" to open all doors. (i.e. I grab the driver's door handle to unlock the driver's door and continue to hold for an additional 1.5 secs before the car will unlock all doors)
  18. Salamander_King
    11,024
    8,980
    New England
    Oh, I thought double click or long-press on the fob. On the hatch button, I don't remember ever doing dobule click, so it must be a long-press, but it may be a single press. I don't remember. I don't lock my car that often.
  19. Tideland Prius
    16,681
    My charging cable is in the trunk so I open and close the hatch at least twice a day.
  20. mister2cool
    mister2cool Member
    98
    52
    New Jersey
    2020 Prius Prime
    That's to turn off auto High beam when car is below 25MPH. It's assumed that you are driving through residential area and shouldn't need to shine high beam through people's windows.
    If you see your auto high beam turns off when you slow down at a turn, that's what this is.
