How can you distinguish 0w20 from 5w20 oil
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by toyolover, Mar 5, 2010.
  1. pjksr02
    pjksr02 Active Member
    532
    226
    Connecticut
    There shouldn't be an issue. In fact, if your Prius is like mine, you won't need to add oil, anyhow. (FWIW, my 2002 Sienna, with 150,000 miles doesn't require oil additions either!).
    That said, some of us cringe at mixing oils of different brands which may have different "chemistries", like say, adding Pennzoil into Mobil. It's probably not a problem, but ....
  2. toyolover
    toyolover Member
    441
    67
    toronto, canada
    Mixing different grade is not a problem if both are of the same type. ie. synthetic with synthetic, regular with regular.
  3. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    there are 3 other dealers under 100 miles away from the one in Bend
    Toyota-Scion Of Bend
    2225 N. E. Highway 20
    P. O. Box 6208 (zip 97708)
    Bend, OR 97701
    (541) 382-4040
    2.0 Miles Away
    Lithia Toyota Of Springfield
    163 S. 9th Street
    Springfield, OR 97477
    (541) 747-3374
    86.16 Miles Away
    Kendall Toyota-Scion
    373 Goodpasture Island Rd.
    P. O. Box 1318 (zip 97440)
    Eugene, OR 97401
    (541) 344-5566
    90.79 Miles Away
    Larry Lassen Toyota
    1205 Price Road Se
    Albany, OR 97321
    (541) 926-4236
    95.71 Miles Away
    Capitol Toyota
    2575 Mission Se
    P.o. Box 12306
    Salem, OR 97302
    (503) 399-1011
    103.06 Miles Away
  4. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    That's right but all of them are on the other side of the Cascades on or off of the I5 corridor--not very convenient. How many are around the SW Portland area? But I'm not having any problems with the Bend dealer and haven't had any problems over the last 3 years. I don't expect to have any problems with them for the next 5 years either. Since I do have a relative in the Portland area that would make more sense. I don't drive 100 miles one-way to sit and wait while someone changes the oil or does anything else on the car for that matter. The relative would be very convenient. If push came to shove I'd rather strike up some confidence with Jiffy Lube. You know, that is pretty much the whole story to this business--to meet and ask questions and feel confident with the people who are actually going to do the work on your car--whether it's a dealer or an independent--that and knowing they have the proper tools and training to do a particular job.
  5. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    I looked at Hood River and Ontairio, (I hang out in Ontario OR more than is statistically likely, given I know no-one and work for no-one there) but the Willamette valley dealers were closer.
    Here is a map of the SW Portland dealers, centered on Tigard OR
    Toyota Dealer Locator Search - Find Toyota Dealer
  6. marshac
    marshac New Member
    29
    Yakima
    Every time I get an oil change at the dealer, I ask "was this 0W20 oil?" and they say "yes" even though it's not written on the receipt anywhere. What makes me nervous is while talking to a sales guy about an extended warranty for my car, I asked him about oil changes, and why they were so 'cheap'.... he then told me that the first oil change is 'always' 5w20 as per the manual... I was like "no, that's not what it is at all"... ever since then I don't fully trust them. They also keep washing my car (and scratching it up!) every time I go in despite my rest NOT to wash it, but that's another matter (along with why my trip odometer is sometimes reset to 0...)...
    I guess the moral is unless you change the oil yourself, or implicitly trust whoever is changing it, you can't know for sure :(
  7. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    I've had my oil/filter changed twice so far on my Prius, at 2 different dealers, and the invoice from both listed the part number and description as 0W-20. And both followed my instruction to not wash my car. Sounds like you need to find another dealer.
  8. New_Yorker
    New_Yorker New Member
    517
    69
    Car Dealers are a dime a dozen. It is all about trust. When they use the wrong oil, and do it without asking permission, and expect you to then pay them for what they were never authorized to do, you need to find people you can trust next time. I never need to question the products used on my new car. I have never had such a thing happen. The question you need to ask is, why do you, not how do you tell which oil they put in the car. It is probably worth mentioning that you can always go to Jiffy Lube if you want the wrong oil put in your car, you don't need to pay dealer shop prices to be treated badly.:eek:
  9. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Now if THAT isn't a snappy comeback to a dick of a Service Manager, nothing is! Good one!
  10. tom1l21
    tom1l21 Member
    268
    East Longmeadow, MA
    I've been running 5w-30 for the life of my car (106k mi) and was considering to switch to 0w-30, 0w-20 or 5w-20. I live in MA so winters can be in low teens and summers are usually in mid 80's. Which oil would be best? I have heard that switching oil on a high mi car can lead to burning oil, is this true? Should I just stick with 5w-30?
  11. jayman
    13,439
    641
    Winnipeg Manitoba
    If the 5W-30 is working ok for you, keep using it.
    As an example, I started using Mobil 1 0W-20 very early on with my '04 Prius, and kept using the oil until I sold the car last summer. Never an issue, no oil consumption, excellent used oil analysis results
    Another poster, Patrick Wong, tried the 0W-20 and started to experience oil consumption. Up to that point, his Prius had NO oil consumption. A single data point isn't helpful, but IMHO is not worth the risk
  12. tom1l21
    tom1l21 Member
    268
    East Longmeadow, MA
    Thx Jayman, Patrick was who I was referencing. The other concern was bc of clanking in the cold winters at startup, I guess I'll just live with it. Probably not an issue right?
  13. jayman
    13,439
    641
    Winnipeg Manitoba
    "Clanking" at temps of low teens F?? I've heard rod knock at -30 F using regular 5W-30, but NEVER in temps as warm as the plus teens
    Otherwise, assuming you change the oil every spring and fall, use a 0W-30 in winter and the regular oil in summer
  14. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    You will get the truth more often if you ask "What viscosity oil did you use?" instead of giving them a clue what the correct answer is..:cool:
  15. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I just bought my Prius yesterday. After I completed my fencing session with the finance manager, I walked over to the service department and asked the service adviser on duty which oil a 2010 Prius used. He told me 0W-40 <_<
  16. jayman
    13,439
    641
    Winnipeg Manitoba
    Huh, another clueless Toyota service department. Who would have thought?
  17. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    My last car was a VW, By comparison, Toyota service departments are staffed by rocket scientists.:eek:
    I don't know whether to pity or envy people who don't know how bad service departments can be.:D
  18. jayman
    13,439
    641
    Winnipeg Manitoba
    Now that is scary
  19. GreenClipper
    GreenClipper Senior Member
    116
    Tulsa, Ok.
    :( Well here's my story from yesterday. I did my first oil change myself at 2.7K. Now with 9700 I had my first of two "free" services done yesterday by my dealer. Would have been $63.15 if I would have had to pay for it. Now for the bad news,....after confirming with the tech writer that it would be 0W-20 oil,.....I failed to tell him to be sure they only put 4qts in the engine! So guess what I got, FIVE qts.! I've driven it home and been checking the oil and find it well above the full mark. Luckily I have an "extractor" which I use on some of my other engines, and I'm pulling ounces at a time out of the dipstick tube till I get the level to the full mark.
    What a bunch of dip*&%$'s! I have never been a fan of letting any "grease monkey" take my car out of sight and do ????? to it! So I will ENDURE this stupidity one more time checking closely afterwords. And tomorrow I will call that tech writer and ask him what don't they understand about refilling a crankcase? Do they put 5qts in everything....irregardless?
    It was all free,......but I don't feel it would have been worth..them paying me...considering my angst!:mad:
    I have always done my own oil changes. Once in a while I try to act like the "other people" and let someone else do it, only to be let down! Like I always thought, and have reconfirmed,.....it isn't these peoples car, so they don't give a #%*$! Sooo, I guess I will be a DIY'er until I can't do it myself any longer. :cool:
  20. Morfeas
    Morfeas Junior Member
    greece
    Hello guys...I have started survey in greek dealers about what kind of oil do they use for prius 2010 and all of them say 5w-30 even though I pointed the manual specific requirements they told me that Toyota hellas provides that kind of oil(I actually saw that on their pc, getting the specification for my car VIN number). I tried to go further and reached a maintenance supervisor in technical support a very kind gentleman who told me that for our temperature range 5w-30 is ideal.
    My question is wise forum members:
    1) Provided that 0w-20 has the same temperature range (as indicated in the manual) with 5-30 so which is their difference and which is better?
    2) Can a thicker oil (like 5-30) gradually damage the engine?
    Any links for oil specifications would be appreciated guys .And for your info our annually temp range is from -5C(worse case in winter) to +42C maximum for summer.
    And finally shall I bypass Toyota and use 0-20 ? They told me I can do it since it is specified in the manual …but they have to order it because its not generally available in Greece…:confused:
