How do I disable 2016 Prius 12V Battery?
Discussion in 'Gen 4 Prius Main Forum' started by janie, May 9, 2019.
  1. janie
    janie 2016 Prius 3 Touring
    175
    42
    Three Touring
    The last few times I was away and not using my prius, the battery died and after the 3rd time of this happening, my battery was replaced -
    Tonight I attempted to disable my 12V battery, and tried to follow the instructions that the dealer service person told me, but it didn't seem to want to cooperate, he said something about unscrewing this thing and then pulling out the part and putting it in a baggie so it didn't leak out.
    Finally I saw someone who knew a little about cars, and he looked at what I had done and said I had already disabled the battery - he said it was impossible to pull out the little part that the dealer service person told me to pull out . . .
    If anyone can post me instructions with some photos that would be greatly appreciated. I tried to do a YouTube search and there were no video clips to explain how to do this . . .
    Thank you very much-
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Do you mean that you just want to disconnect the battery? Just do the same as if charging the battery (as per the Owner's Manual):
    But I'm intrigued by this:
    upload_2019-5-9_17-20-33.png Amazing MPG for a PRIUS.
  3. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    alanclarkeau likes this.
  4. janie
    175
    42
    Three Touring
    Hmm I don't see a black wire on the top in the photo= I didn't see any wires . . . but I did unscrew the bolts and took off that part that is toward the front of the photo / the car . . . it's confusing. When I return I will go and ask a service department at a different toyota to see if they are more helpful to help me to understand how to disable my battery when I will not be using my car for an extended time. Where I park there is no direct sunlight and no plug outlets . . .
  5. Mendel Leisk
    42,298
    If this is something you'll need to do semi-regularly, there are switches that can be installed, so that you just turn something 90 degrees, and the negative cable is disconnected from the battery. Google "battery disconnect switch". Here's one of the first hits I found:
    Battery Disconnect Switches | Battery Cutoff Switches
    jb in NE, kithmo and janie like this.
  6. janie
    175
    42
    Three Touring
    thanks i will investigate this for next time see if i can pay someone to install it
  7. bisco
    52,804
    have you tried disabling sks on your key fob?
    kithmo likes this.
  8. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Bottom wire, nearest one in the picture (and nearest to the front of the car), has a red cover over it (cover is open in the picture), leave that one alone, the top battery wire (connected to the other battery post) is exposed, that is the one to disconnect.
  9. Leo
    Leo Leo
    84
    Ottawa, Canada
    If you disconnect the battery, what is the result when you reconnect it? What settings are lost?
  10. Mendel Leisk
    42,298
    For sure:
    1. Radio presets
    2. Trip meters
    Possible:
    1. Auto up of one or more windows. You may need to "retrain" them: run them down while holding the switch, then all the way up while holding the switch, and continue to hold the switch, when it's up, for at least a couple of seconds more. That should fix it.
    Sneaky:
    1. I've noticed, for the next few start ups, an odd rev-up of the engine, for a few seconds. Seems like something is getting recalibrated.
    That's all the specifics I can think of for third gen; fourth gen maybe has more?
  11. krmcg
    2,592
    2,393
    Whittier, CA
    When I had my battery changed out the only thing I lost is the time of day on the clock. Radio pre-sets, and trip meters were intact.
    jb in NE and Mendel Leisk like this.
  12. Mendel Leisk
    42,298
    So the one thing I forgot, is the one thing that actually gets lost? :oops:
    bisco and krmcg like this.
  13. alanclarkeau
    7,045
    7,593
    Mendel Leisk, Prodigyplace and krmcg like this.
  14. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    How long is the car unattended? Are the temps very low? My Prius is a 2012, still on original 12V battery, and I’ve left it a week or more without difficulty. I’m wondering if a fault is draining your battery excessively. Yes, SKS consumes power, but probably not enough to drain a AAA battery in a month. You’ve got a far larger battery than that.
  15. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    The simplest solution is not to disconnect the battery (and lose radio presets, etc), since even when disconnected a lead-acid battery will self-discharge. Get a Battery Tender charger and clip that on to the battery terminals when you are away. This charger will keep a small trickle charge on the battery and won't overcharge it. About $25- $45 depending on the model (even the Junior will meet your needs) online. I have one that I use for my convertible from November to April, and have replaced the battery on that car once in 13 years.
  16. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    See post #3
  17. janie
    175
    42
    Three Touring
    Thanks for the various suggestions - my car is parked in an underground parking garage of an apartment complex, and there are no power outlets in any part of the garage.
    When I returned from my trip, I had a very difficult time trying to get my battery back together, as every time I tried to put the red part cover back on, it would start honking very loudly . . . Ended up I had to call AAA to help me get it back together -
    but on a good note, the battery didn't die out like in previous trips (anywhere from 1 to 3 + weeks).
    I have an email sent to an automotive body shop that has helped me with other things in the past, to see if they could assist me with putting on a battery disconnect switch -
  18. Mendel Leisk
    42,298
    Typically you disconnect the negative (black) cable.
  19. janie
    175
    42
    Three Touring
    the problem is I don't see a cable black or any other color . . .
  20. bisco
    52,804
    if you look closely with a flashlight, you will see + on one battery post, and - on the other.
    and, the negative post/cable goes to a nut on the fender body.
