How do I drill the box?
Discussion in 'Gen 2 Prius Main Forum' started by phoskins, Apr 8, 2008.
  1. phoskins
    phoskins New Member
    33
    Waterford, CT
    I want to mount my scangauge in the compartment below the CD player and drill a hole to run the wire down to the OBD connection. I can pull off the big plastic trim piece that has the front cig lighter, but how do I get the trim piece off that is right below this compartment? Is ther an easier way to get to that little compartment so I can drill a hole? Thanks.
  2. bogeybob513
    bogeybob513 rtc513
    147
    Myrtle Beach, SC
    I used a long 1/2" drill in a variable speed drill set on very low, then drilled into the back lower left hand corner until it broke through. Then I inserted a plastic rod through the hole, tied a string to it and the scangauge connector, and pulled it through. Good luck-drill slowly!:D
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    This thread wasn't what I was expecting, given the title. :D
    Tom
  4. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    That whole lower panel comes right off, if you pop out the one
    little fastener over around the right side in the passenger
    footwell. Brings the power-outlet and wiring with it, so don't
    pull too enthusiastically before you disconnect that.
    _H*
  5. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    oi
    :rolleyes:
  6. patsparks
    10,664
    567
    Adelaide South Australia
    I think the OP means the panel above that Hobbit. You know, the flat panel that faces the floor under the hidie-hole under the radio.
  7. phoskins
    phoskins New Member
    33
    Waterford, CT
    Thanks Pat - That is exactly the panel I was talking about. Anyone know how to get that off?
  8. phoskins
    phoskins New Member
    33
    Waterford, CT
    I figured with a title like that I would get much more help. Looks like it worked!
  9. dws
    dws New Member
    Corpus Christi, TX
    Take a look at this: http://www.techno-fandom.org/~hobbit/cars/chris-dragon-dash.pdf I am also planning to drill the hole in the compartment as well; however, I would like to drill the hole in the bottom of the compartment without disassembling the dash. I am not sure if there would be anything that could be damaged just below the compartment.
  10. phoskins
    phoskins New Member
    33
    Waterford, CT
    DWS- looks like that is exactly what I was looking for! I have some work to do now. Thanks.:)
  11. davidtm
    davidtm Member
    180
    TJ'ville
    I just realized your name is probably P Hoskins, but, in the spirit of misunderstanding of the thread's topic, I initially read it as "fo-skins".
    (Gotta get a life!!):eek:
  12. patsparks
    10,664
    567
    What is the weather like there today, in the gutter?:p Sorry, first thing that popped into my head and it was typed and posted before I could think.
  13. derkraut
    derkraut Member
    299
    27
    SAN
    That's exactly the way I did mine. And it fits in there very neatly, no wire visible, I can still close the door.;)
